Ver 1.6.002.
I’ve download and install EGW v1.4 and now i can export the calendar.
I think it was a problem with pear (even if all the chart about pear (at the installation) was green.
But now, i’ve got a new problem with EGW v1.4 and icalsrv with thunderbird lighting.
thunderbird ask me the login and password but even if it’s the good login and password (and the right rules on the admin panels), i don’t know why.
It’s Ok about it, egw was blocked my ip (i’ve read the acces log).
Now i can view my calendar in thunderbird, but i can’t modify it from thunderbird (even if the case READ ONLY is empty)
I’ve got the following error :
Publishing the calendar file failed
Status code: 403: importing in groupcalendars is not allowed
Thank you
