Hi Kano,
Dear Ralf,
Thanks for your quick reply. Yes, I used recommended way of the installation
via your package.
I used the path which you suggest and it works! Thanks a lot!
But I got another error immediately:
Database error
Invalid SQL: SELECT SQL_CALC_FOUND_ROWS 1,egw_addressbook.n_given AS
n_given,egw_addressbook.n_family AS n_family,egw_addressbook.contact_id AS
id,egw_addressbook.contact_created AS
created,egw_addressbook.contact_modified AS modified,egw_accounts.account_id
AS
account_id,coalesce(egw_addressbook.contact_email,egw_mailaccounts.mail_value)
as
email,account_lid,account_type,account_status,account_expires,account_primary_group,account_description
FROM egw_addressbook RIGHT JOIN egw_accounts ON
egw_accounts.account_id=egw_addressbook.account_id LEFT JOIN
egw_mailaccounts ON egw_accounts.account_id=-egw_mailaccounts.account_id AND
mail_type=3 WHERE egw_addressbook.contact_owner=0 AND (account_expires IS
NULL OR account_expires = -1 OR account_expires > 1468497738) AND
(account_type IS NULL OR account_type!=‘u’ OR account_status=‘A’) AND
(contact_tid != ‘D’ OR contact_tid IS NULL) ORDER BY account_lid
Unknown column ‘account_description’ in ‘field list’ (1054)
Looks to me you have an old database, not (yet) updated to 16.1.
If that is the case, because you eg. restored a dump from an old
installation, you need to go to setup:
https://domain.com/egroupware/setup/
And update it to 16.1 database schema.
And there is no option for any repair.
Interesting is, that conversion was successful…
Thanks for any reply.
Regards
Tony
