I use export because GroupDAV is for some reason not working,
It seams to work with an ICal, but on an Iphone the calendar doesn’t appear (IOS 3.1.2 or 4.0).
I have tried both http:///egroupware/caldav.php (IOS 4.0) and http:///egroupware/caldav.php/calendar/ (IOS 3.x).
Here is what I have on the access log for groupdav with IOS 4.0 :
[21/Jul/2010:11:45:31 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:11:45:32 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:11:45:32 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:11:46:22 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:11:46:54 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:13:41:06 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:13:41:06 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:13:41:07 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:13:42:31 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:13:43:01 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:13:49:35 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:13:46:15 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:13:49:35 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:13:45:33 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:13:49:36 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:15:27:42 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:15:27:42 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:15:27:46 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:15:27:46 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:15:27:47 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:15:29:41 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 94605
[21/Jul/2010:15:32:01 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:15:32:01 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:15:32:06 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 401 91
[21/Jul/2010:15:32:06 +0200] “PROPFIND /egroupware/groupdav.php/ HTTP/1.1” 207 1063
[21/Jul/2010:15:34:00 +0200] “PROPFIND /egroupware/groupdav.php/calendat/ HTTP/1.1” 401 91
[21/Jul/2010:15:34:19 +0200] “PROPFIND /egroupware/groupdav.php/calendat/ HTTP/1.1” 401 91
[21/Jul/2010:15:35:01 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 401 91
[21/Jul/2010:15:31:23 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 207 93497
[21/Jul/2010:15:35:20 +0200] “PROPFIND /egroupware/groupdav.php/calendar/ HTTP/1.1” 401 91
I have enabled debug on the code, here is what i got on the error_log :
[Wed Jul 21 15:35:28 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::_parse_path called with (’/calendar/’) id=, app=’’, user=
[Wed Jul 21 15:35:28 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::_parse_path(‘calendar/’) returning false: id=’’, app=‘calendar’, user=‘2287’, user_prefix=’’
[Wed Jul 21 15:35:28 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::PROPFIND: user=‘2287’, app=‘calendar’, id=’’
[Wed Jul 21 15:35:29 2010] [error] [client xxx.xxx.xxx.xxx] groupdav_handler::app_handler(‘calendar’, ‘/egroupware/groupdav.php’, ‘http://egw.example.com/egroupware/groupdav.php/principals/users//’)
[Wed Jul 21 15:35:29 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::: user=‘2287’, app=‘calendar’
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav: $_SERVER=Array([UNIQUE_ID] => 5IfmOcCoCiIAAFF4T3IAAAAP[SCRIPT_URL] => /egroupware/groupdav.php/calendar[SCRIPT_URI] => http://egw.example.com/egroupware/groupdav.php/calendar[HTTP_HOST] => egw.example.com[HTTP_USER_AGENT] => Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.9.0.19) Gecko/2010033100 Iceweasel/3.0.6 (Debian-3.0.6-3)[HTTP_ACCEPT] => text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8[HTTP_ACCEPT_LANGUAGE] => en-us,en;q=0.5[HTTP_ACCEPT_ENCODING] => gzip,deflate[HTTP_ACCEPT_CHARSET] => ISO-8859-1,utf-8;q=0.7,*;q=0.7[HTTP_KEEP_ALIVE] => 300[HTTP_CONNECTION] => keep-alive[HTTP_COOKIE] => last_loginid=; last_domain=default; sessionid=c92efdb2c52c39492c42bfff4d940aa1; kp3=iznWSXWXn7kFhKeewrNwLiAf; domain=default; eGW_remember=%40default%3A%3A%3A%3A%3Dv4ewejZ%3A%3A%3A%3Atext[PATH] => /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin[SERVER_SIGNATURE] => Apache/2.2.3 (Unix) DAV/2 mod_ssl/2.2.3 OpenSSL/0.9.8d PHP/5.2.0 mod_apreq2-20051231/2.5.7 mod_perl/2.0.2 Perl/v5.8.7 Server at egw.example.com Port 80[SERVER_SOFTWARE] => Apache/2.2.3 (Unix) DAV/2 mod_ssl/2.2.3 OpenSSL/0.9.8d PHP/5.2.0 mod_apreq2-20051231/2.5.7 mod_perl/2.0.2 Perl/v5.8.7[SERVER_NAME] => egw.example.com[SERVER_ADDR] => 192.168.10.34[SERVER_PORT] => 80[REMOTE_ADDR] => xxx.xxx.xxx.xxx[DOCUMENT_ROOT] => /opt/lampp/htdocs[SERVER_ADMIN] => admin@example.com[SCRIPT_FILENAME] => /opt/lampp/htdocs/egroupware/groupdav.php[REMOTE_PORT] => 57027[GATEWAY_INTERFACE] => CGI/1.1[SERVER_PROTOCOL] => HTTP/1.1[REQUEST_METHOD] => GET[QUERY_STRING] => [REQUEST_URI] => /egroupware/groupdav.php/calendar[SCRIPT_NAME] => /egroupware/groupdav.php[PATH_INFO] => /calendar[PATH_TRANSLATED] => /opt/lampp/htdocs/calendar[PHP_SELF] => /egroupware/groupdav.php/calendar[PHP_AUTH_USER] => [PHP_AUTH_PW] => xxxxxxxxx[REQUEST_TIME] => 1279719404[argv] => Array()[argc] => 0)
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::GET(Array([path] => /calendar))
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::_parse_path called with (’/calendar’) id=, app=’’, user=
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::_parse_path(‘calendar’) returning false: id=’’, app=‘calendar’, user=‘2287’, user_prefix=’’
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::PROPFIND(Array([path] => /calendar[depth] => 1))
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::PROPFIND: user=‘2287’, app=‘calendar’, id=’’
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav_handler::app_handler(‘calendar’, ‘/egroupware/groupdav.php’, ‘http://egw.example.com/egroupware/groupdav.php/principals/users//’)
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] groupdav::: user=‘2287’, app=‘calendar’
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] calendar_groupdav::propfind(/calendar/,Array([path] => /calendar[depth] => 1),2287,)
[Wed Jul 21 15:36:45 2010] [error] [client xxx.xxx.xxx.xxx] calendar_groupdav::propfind(/calendar/,2287,) filter=Array([users] => 2287[start] => 1271079405[end] => 1311255405[enum_recuring] => [daywise] => [date_format] => server[show_rejected] => 1)
[Wed Jul 21 15:38:53 2010] [error] [client xxx.xxx.xxx.xxx] calendar_groupdav::propfind_callback(/calendar/) took 128.841967821 to return 83 items
[Wed Jul 21 15:38:55 2010] [error] [client xxx.xxx.xxx.xxx] calendar_groupdav::propfind_callback(/calendar/) took 1.43781709671 to return 0 items
But I found nothing on it that could give me a clue on what is going wrong.
Actually users use ics export, if someone can give me a working groupdav, why not. but AFAIK it is not functionnal (and from what i read on the forum/bug report, I am not the only one).
To return to my main problem, the two event that i have found with the same UID are have the same name, but one is a recurring event, the other is not (the user told me they are distinct events they just have the same name but one appends only 1 time on a wednesday the other was a recurring event all the fridays).
