Hi!
I got the following invitation:
BEGIN:VCALENDAR
PRODID:-//Microsoft Corporation//Outlook 11.0 MIMEDIR//EN
VERSION:2.0
METHOD:REQUEST
BEGIN:VEVENT
ATTENDEE;ROLE=REQ-PARTICIPANT;RSVP=TRUE:MAILTO:hjtappe@localhost
ORGANIZER:MAILTO:webmaster@localhost
DTSTART:20081125T160000Z
DTEND:20081125T161500Z
TRANSP:OPAQUE
SEQUENCE:0
UID:040000008200E00074C5B7101A82E00800000000B0633F9AFD44C9010000000000000000100
0000009826B9AC6E7284B9AD57A9DD6943FCC
DTSTAMP:20081112T183356Z
DESCRIPTION:Zeit: Dienstag, 25. November 2008 17:00-17:15 (GMT+01:00)
Amsterdam, Berlin, Bern, Rom, Stockholm,
Wien.\n\n*~~~~~~~~~*\n\n\n
SUMMARY:Follow-Up discussion
PRIORITY:5
X-MICROSOFT-CDO-IMPORTANCE:1
CLASS:PUBLIC
BEGIN:VALARM
TRIGGER:-PT15M
ACTION:DISPLAY
DESCRIPTION:Reminder
END:VALARM
END:VEVENT
END:VCALENDAR
During import by the web frontend, it says “Successfully imported” but
the data does not show up. The same for Lightning; while this even
produces a database error.
These are the messages from the error log.
==> Web-UI:
VALARM field:ACTION: HAS NO CONVERSION YET, referer:
http://localhost/groupware/index.php?menuaction=calendar.calendar_uiforms.import
VALARM field:DESCRIPTION: HAS NO CONVERSION YET, referer:
==> Lightning via caldav.php:
Unrecogniced GroupDAV client: HTTP_USER_AGENT=‘Mozilla/5.0 (X11; U;
Linux i686; en-US; rv:1.8.1.17) Gecko/20080925 Thunderbird/2.0.0.17’!
Database error: db::column_data_implode(’ AND ‘,Array\n(\n [uid] =>
null\n [0] => (cal_user_type=‘u’ AND cal_user_id IN
(‘5’,’-1’,’-2’))\n [1] => recur_type IS NULL AND
cal_recur_date=0\n)\n,‘1’,
Array\n(\n [cal_id] => Array\n
(\n [type] => auto\n [nullable] => \n
)\n\n [cal_uid] => Array\n (\n [type] => varchar\n
[precision] => 255\n [nullable] => \n )\n\n
[cal_owner] => Array\n (\n [type] => int\n
[precision] => 4\n [nullable] => \n )\n\n
[cal_category] => Array\n (\n [type] => varchar\n
[precision] => 30\n )\n\n [cal_modified] => Array\n
(\n [type] => int\n [precision] => 8\n
)\n\n [cal_priority] => Array\n (\n [type] => int\n
[precision] => 2\n [nullable] => \n
[default] => 2\n )\n\n [cal_public] => Array\n (\n
[type] => int\n [precision] => 2\n
[nullable] => \n [default] => 1\n )\n\n [cal_title]
[precision] => 255\n [nullable] => \n [Thu Nov 13
09:36:48 2008] [error] [client 127.0.0.1] [default] => 1\n
)\n\n [cal_description] => Array\n (\n [type] =>
text\n )\n\n [cal_location] => Array\n (\n
[type] => varchar\n [precision] => 255\n )\n\n
[cal_reference] => Array\n (\n [type] => int\n
[precision] => 4\n [nullable] => \n [default]
=> 0\n )\n\n [cal_modifier] => Array\n (\n
[type] => int\n [precision] => 4\n )\n\n
[cal_non_blocking] => Array\n (\n [type] => int\n
[precision] => 2\n [default] => 0\n )\n\n
[cal_special] => Array\n (\n [type] => int\n
[cal_etag] => Array\n (\n [type] => int\n
[precision] => 4\n [default] => 0\n
)\n\n)\n
nothing known about column ‘uid’!
#0 /var/www/groupware/phpgwapi/inc/class.egw_db.inc.php(1447):
egw_db->halt(‘db::column_data…’)
#1 /var/www/groupware/phpgwapi/inc/class.egw_db.inc.php(1883):
egw_db->column_data_implode(’ AND ‘, Array, true, false, Array)
#2 [internal function]: egw_db->select(‘egw_cal’,
‘egw_cal_repeats…’, Array, false, false, false, NULL, ‘calendar’, 0,
‘JOIN egw_cal_da…’, NULL)
#3 /var/www/groupware/phpgwapi/inc/class.egw_db.inc.php(1939):
call_user_func_array(Array, Array)
#4 /var/www/groupware/calendar/inc/class.calendar_so.inc.php(340):
egw_db->union(Array, 340, ‘/var/www/groupw…’, ‘cal_start’, false, 0)
#5 /var/www/groupware/calendar/inc/class.calendar_bo.inc.php(376):
calendar_so->search(NULL, NULL, Array, 0, ‘all’, Array, false, 0, NULL,
true)
#6
/var/www/groupware/calendar/inc/class.calendar_groupdav.inc.php(95):
calendar_bo->search(Array)
#7 /var/www/groupware/phpgwapi/inc/class.groupdav.inc.php(215):
calendar_groupdav->propfind(’/calendar/null’, Array, Array, 5, ‘null’)
#8 /var/www/groupware/egw-pear/HTTP/WebDAV/Server.php(555):
groupdav->PROPFIND(Array, Array)
#9 /var/www/groupware/egw-pear/HTTP/WebDAV/Server.php(216):
HTTP_WebDAV_Server->http_PROPFIND()
#10 /var/www/groupware/groupdav.php(70):
HTTP_WebDAV_Server->ServeRequest()
#11 {main}
PHP Warning: Header may not contain more than a single header, new
line detected. in
/var/www/groupware/phpgwapi/inc/common_functions.inc.php on line 1446
What could cause this and how could we probably become Outlook-aware in
this direction, too?
Regards,
Hans-Jürgen
BadBadOtherOs
