I am having updated to iOs 5 too and everything works but the address book.
The address book is available but without all the entries, only a searchable group. All it comes up with is a search bar to enter names which will then be queried and the results returned.
Same as the exchange global address book.
I am on dev trunk.
You either have to re-create your addressbook account or edit it to use
the following URL: /egroupware/groupdav.php//addressbook/ as I
announce now /egroupware/groupdav.php/addressbook/ as directory gateway.
If the account was previously autodetected, you’ll be using
//addressbook anyway.
Regards,
Ingo
Ist your software up to date? There was one change necessary for iOS 5.
I use egroupware since many years now and ist’s my favorite’s groupware…
I use egrouware 1.8 from svn and I synchronise somme iphone without any
problem since ios 5.0 upgrade.
I think that Apple have change the way they connect into cardav and caldav
servers. With Tasks+Cal 2.6.7 I have the same problem…
Do I need to modify my .htaccess with a correction like with ios 4.3.2 ?
Can you help me to find a solution to reactivate syncml synchonisation ?
Best regards,
EG
View this message in context: http://egroupware.219119.n3.nabble.com/Problem-with-ios5-tp3419171p3419171.html
Sent from the egroupware-users mailing list archive at Nabble.com.
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2d-oct
