I upgraded from release 8.1 to 14.1
(egroupware-epl-14.1.20141113-1.1.noarch) via yum on my CentOS 6.2 server.
It upgraded with everything else when doing an upgrade to CentOS 6.6. I’m
still running the CentOS 6.2 kernel though.
Since the upgrade we’re experiencing a problem with the Time sheet
component. The “unit price” drop-down list options are no longer
available (only available option is “none”) when creating an entry until
you “Apply” or “Save” the document. Once the document is saved, you can
then select the “unit price” drop-down menu and find the desired option
you’re looking for.
Any ideas on how to resolve this?
