Hi JSmith,
I upgraded from release 8.1 to 14.1
(egroupware-epl-14.1.20141113-1.1.noarch) via yum on my CentOS 6.2
server. It upgraded with everything else when doing an upgrade to
CentOS 6.6. I’m still running the CentOS 6.2 kernel though.
Since the upgrade we’re experiencing a problem with the Time sheet
component. The “unit price” drop-down list options are no longer
available (only available option is “none”) when creating an entry
until you “Apply” or “Save” the document. Once the document is saved,
you can then select the “unit price” drop-down menu and find the
desired option you’re looking for.
Problem has been reported by a customer and we are working on a fix.
