The code for check_all() is in
http://svn.stylite.de/viewvc/egroupware/trunk/etemplate/js/etemplate.js?view=markup
Stéphanie Junguené schrieb:
Hello everybody!
I have a little probleme with the toggle_all function.
I am developping an application, and I have a grid containing some
informations, and the last colomn of my grid contains actions’buttons!
One of them is a checkbox button! (like addressbook.index template)
I added, as for the adressbook.index template, a check_all button with
the javascript code (personalised onClick) : toogle_all(…) to check
and un-check the checkboxes.
My problem is that my actions’buttons are in a grid not in a hbox like
in addressbook ( for some needs for my applications)
The name of that grid is ${row}[action], and inside i have my checkbox,
which name is : checked[].
If i put in the onClick field :
toggle_all(this.form,form::name(‘checked[]’)); return false; to check
and uncheck the checkboxes,
If you use ${row}[action] for the grid, the name of each individual box
is different: 1[action][checked][], 2[action][checked][], …
toggle_all(this.form,form::name(‘checked[]’)) returns a wrong name and
check_all finds no matches.
Only solution, either use an identical name, or write your own check_all
function. Thought you allready need to collect the checked flag from
different locations, as you use different names.
it won’t work because my checkboxes’buttons are in a grid with a name,
if I don’t put a name for this grid, it will work!
But i need this grid name!
Is there a way to solve this problem? what can i put instead of
’checked[]’ in the toggle_all function to make it work?
ps: sorry if my english is not good!! hope i am understable!
thanks
Stephanie Junguené
VO2LABS
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
http://p.sf.net/sfu/devconference
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
