Bonjour à tous,
j’ai mis sur mon ordinateur easy php 2.Ob1 afin d’installer egroupware.
après avoir fait le test d’installation, j’ai mis le fichier header.inc.php.
et voila ce que j’obtiens
Warning: include({SERVER_ROOT}/phpgwapi/setup/setup.inc.php) [function.include]: failed to open stream: No such file or directory in C:\Program Files\EasyPHP 2.0b1\www\egroupware\header.inc.php on line 105
Warning: include() [function.include]: Failed opening ‘{SERVER_ROOT}/phpgwapi/setup/setup.inc.php’ for inclusion (include_path=’.;C:/Program Files/EasyPHP 2.0b1\php5\pear’) in C:\Program Files\EasyPHP 2.0b1\www\egroupware\header.inc.php on line 105
Warning: require({INCLUDE_ROOT}/phpgwapi/inc/common_functions.inc.php) [function.require]: failed to open stream: No such file or directory in C:\Program Files\EasyPHP 2.0b1\www\egroupware\setup\inc\functions.inc.php on line 53
Fatal error: require() [function.require]: Failed opening required ‘{INCLUDE_ROOT}/phpgwapi/inc/common_functions.inc.php’ (include_path=’.;C:/Program Files/EasyPHP 2.0b1\php5\pear’) in C:\Program Files\EasyPHP 2.0b1\www\egroupware\setup\inc\functions.inc.php on line 53
est-ce que quelqu’un peut m’aider?
merci beaucoup
wanda
