J’ai oublié
docker logs -f egroupware-nginx 2>&1 | sed ‘s/PHP message/\nPHP message/g’ donne
2020/04/05 16:32:57 [error] 6#6: *158150 FastCGI sent in stderr: “
PHP message: PHP Warning: session_set_cookie_params(): Cannot change session cookie parameters when session is active in /usr/share/egroupware/api/src/Session.php on line 1690
PHP message: #1 /usr/share/egroupware/api/src/Session.php(1690): session_set_cookie_params(0, ‘/’, ‘zelec.homelinux…’, true, true)
PHP message: #2 /usr/share/egroupware/api/src/Session.php(264): EGroupware\Api\Session::set_cookiedomain()
PHP message: #3 /usr/share/egroupware/api/src/Egw/Base.php(130): EGroupware\Api\Session->__construct()
PHP message: #4 /usr/share/egroupware/api/src/Framework.php(186): EGroupware\Api\Egw\Base->__get(‘session’)
PHP message: #5 /usr/share/egroupware/api/src/Framework/Ajax.php(160): EGroupware\Api\Framework::link(’/api/avatar.php’, Array)
PHP message: #6 /usr/share/egroupware/api/src/Egw.php(476): EGroupware\Api\Framework\Ajax::link(’/api/avatar.php’, Array, NULL)
PHP message: #7 /usr/share/egroupware/api/src/Contacts.php(772): EGroupware\Api\Egw::link(’/api/avatar.php’, Array)
PHP message: #8 /usr/share/egroupware/api/src/Contacts.php(741): EGroupware\Api\Contacts->photo_src(‘1’, false, ‘’, NULL)
PHP message: #9 /usr/share/egroupware/api/src/Contacts/Storage.php(749): EGroupware\Api\Contacts->db2data(Array)
PHP message: #10 /usr/share/egroupware/api/src/Accounts/Sql.php(534): EGroupware\Api\Contacts\Storage->search(Array, Array, ‘account_lid’, ‘account_lid,acc…’, ‘%’, false, ‘OR’, Array, Array, ’ RIGHT JOIN egw…’)
PHP message: #11 /usr/share/egroupware/api/src/Accounts.php(292): EGroupware\Api\Accounts\Sql->search(Array)
PHP message: #12 /usr/share/egroupware/setup/inc/class.setup.inc.php(1137): EGroupware\Api\Accounts->search(Array)
PHP message: #13 /usr/share/egroupware/setup/index.php(458): setup->accounts_exist()
PHP message: #14 {main}
PHP message: # Instance=, User=, Request=POST https://zelec.homelinux.net/egroupware/setup/index.php, User-agent=Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0” while reading response
2020/04/05 16:33:16 [error] 6#6: *158143 FastCGI sent in stderr: “
PHP message: EGroupware\Rocketchat\Hooks::avatar_stat()Rocketchat is not configured!” while reading response header from upstream, client: 172.20.0.1, server: _, request: “GET /egroupware/index.php?cd=yes HTTP/1.1”, upstream: “fastcgi://172.20.0.4:9000”, host: “zelec.homelinux.net”, referrer: "https://zelec.homelinux.net/egroupware/login.php?cd=10"
2020/04/05 16:33:33 [error] 9#9: *158149 FastCGI sent in stderr: “
PHP message: PHP Warning: ldap_search(): Search: No such object in /usr/share/egroupware/api/src/Contacts/Ldap.php on line 1085
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #4, ‘cn=zelec,cn=lan’, ‘(|(entryUUID=be…’, Array, 0, 2000)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->_searchLDAP(‘cn=zelec,cn=lan’, ‘(|(entryUUID=be…’, Array, 0, Array)
PHP message: #3 /usr/share/egroupware/api/src/Contacts/Storage.php(612): EGroupware\Api\Contacts\Ldap->read(‘benoit’)
PHP message: #4 /usr/share/egroupware/api/src/Contacts.php(1142): EGroupware\Api\Contacts\Storage->read(‘benoit’)
PHP message: #5 /usr/share/egroupware/api/src/Contacts.php(2611): EGroupware\Api\Contacts->read(‘benoit’)
PHP message: #6 /usr/share/egroupware/api/avatar.php(30): EGroupware\Api\Contacts->photo()
PHP message: #7 {main}
PHP message: # Instance=default, User=benoit, Request=GET https://jolly/egroupware/api/avatar.php?account_id=1002, User-agent=Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0
PHP message: PHP Warning: readfile(): Filename cannot be empty in /usr/share/egroupware/api/src/Contacts.php on line 2654
PHP message: #1 /usr/share/egroupware/api/src/Contacts.php(2654): readfile(’’)
PHP message: #2 /usr/share/egroupware/api/avatar.php(30): EGroupware\Api\Contacts->photo()
PHP message: #3 {main}
PHP message: # Instance=default, User=benoit, Request=GET https://jolly/egroupware/api/avatar.php?account_id=1002, User-agent=Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0” while reading response header from upstream, client: 172.20.0.1, server: _, request: “GET /egroupware/api/avatar.php?account_id=1002 HTTP/1.1”, upstream: “fastcgi://172.20.0.4:9000”, host: “zelec.homelinux.net”, referrer: "https://zelec.homelinux.net/egroupware/index.php?cd=yes"
2020/04/05 16:33:34 [error] 6#6: *158143 FastCGI sent in stderr: "
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #153, ‘cn=zelec,cn=lan’, ‘uidNumber=1002’, Array, 0, 2000)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->_searchLDAP(‘cn=zelec,cn=lan’, ‘uidNumber=1002’, Array, 0, Array)
PHP message: #3 /usr/share/egroupware/api/src/Contacts/Storage.php(612): EGroupware\Api\Contacts\Ldap->read(Array)
PHP message: #4 /usr/share/egroupware/api/src/Contacts.php(1142): EGroupware\Api\Contacts\Storage->read(Array)
PHP message: #5 /usr/share/egroupware/calendar/inc/class.calendar_owner_etemplate_widget.inc.php(76): EGroupware\Api\Contacts->read(‘account:1002’, true)
PHP message: #6 [internal function]: calendar_owner_etemplate_widget->{closure}(1002, ‘szczygiel, beno…’)
PHP message: #7 /usr/share/egroupware/calendar/inc/class.calendar_owner_etemplate_widget.inc.php(91): array_map(Object(Closure), Array, Array)
PHP message: #8 [internal function]: calendar_owner_etemplate_widget->beforeSendToClient(’’, Array)
PHP message: #9 /usr/share/egroupware/api/src/Etemplate/Widget.php(555): call_user_func_array(Array, Array)
PHP message: #10 /usr/share/egroupware/api/src/Etemplate/Widget/Box.php(96): EGroupware\Api\Etemplate\Widget->run(‘beforeSendToCli…’, Array, false, NULL)
PHP message: #11 /usr/share/egroupware/api/src/Etemplate/Widget.php(567): EGroupware\Api\Etemplate\Widget\Box->run(‘beforeSendToCli…’, Array, false)
PHP message: #12 /usr/share/egroupware/api/src/Etemplate/Widget/Template.php(264): EGroupware\Api\Etemplate\Widget->run(‘beforeSendToCli…’, Array, false)
PHP message: #13 /usr/share/egroupware/api/src/Etemplate.php(169): EGroupware\Api\Etemplate\Widget\Template->run(‘beforeSendToCli…’, Array)
PHP message: #14 /usr/share/egroupware/calendar/inc/class.calendar_ui.inc.php(617): EGroupware\Api\Etem
2020/04/05 16:33:34 [error] 6#6: *158158 FastCGI sent in stderr: “
PHP message: EGroupware\Api\Mail::getInstance (282) Loading the Profile for ProfileID failed for icServer; Compte non trouvé ! (acc_id=NULL) Trigger new instance for Default-Profile . called from:EGroupware\Api\Mail::getInstance:282 / mail_ui->__construct:148 / CreateObject:67(mail.mail_ui) / EGroupware\Api\Framework\Ajax::ajax_exec:994 / call_user_func_array(Array) / EGroupware\Api\Json\Request->handleRequest:192 / EGroupware\Api\Json\Request->parseRequest:104
PHP message: mail_ui::index561L’initialisation du courrier en échec. Veuillez utiliser l’assistant pour traiter le problème. Menuaction:mail.mail_ui.index.mail_ui->index:561 / EGroupware\Api\Framework\Ajax::ajax_exec:1012 / call_user_func_array(Array) / EGroupware\Api\Json\Request->handleRequest:192 / EGroupware\Api\Json\Request->parseRequest:104” while reading response header from upstream, client: 172.20.0.1, server: _, request: “POST /egroupware/json.php?menuaction=mail.jdots_framework.ajax_exec.template.mail.mail_ui.index HTTP/1.1”, upstream: “fastcgi://172.20.0.4:9000”, host: “zelec.homelinux.net”, referrer: "https://zelec.homelinux.net/egroupware/index.php?cd=yes"
2020/04/05 16:33:35 [error] 6#6: *158143 FastCGI sent in stderr: "
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #39, ‘cn=zelec,cn=lan’, ‘uidNumber=8’, Array, 0, 2000)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->_searchLDAP(‘cn=zelec,cn=lan’, ‘uidNumber=8’, Array, 0, Array)
PHP message: #5 /usr/share/egroupware/api/src/Framework.php(1559): EGroupware\Api\Contacts->read(‘account:8’, true)
PHP message: #6 [internal function]: EGroupware\Api\Framework::ajax_user_list()
PHP message: #7 /usr/share/egroupware/api/src/Json/Request.php(192): call_user_func_array(Array, Array)
PHP message: #8 /usr/share/egroupware/api/src/Json/Request.php(104): EGroupware\Api\Json\Request->handleRequest(‘EGroupware\Api\…’, Array)
PHP message: #9 /usr/share/egroupware/json.php(125): EGroupware\Api\Json\Request->parseRequest(‘EGroupware\Api\…’, ‘{“request”:{"pa…’)
PHP message: #10 {main}
PHP message: # Instance=default, User=benoit, Request=POST https://jolly/egroupware/json.php?menuaction=EGroupware\Api\Framework::ajax_user_list, User-agent=Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #39, ‘cn=zelec,cn=lan’, ‘uidNumber=1002’, Array, 0, 2000)
2020/04/05 16:33:35 [error] 6#6: *158143 FastCGI sent in stderr: “ray)
PHP message: #5 /usr/share/egroupware/api/src/Framework.php(1559): EGroupware\Api\Contacts->read(‘account:-9’, true)
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #39, ‘cn=zelec,cn=lan’, ‘uidNumber=-1’, Array, 0, 2000)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->searchLDAP(‘cn=zelec,cn=lan’, ‘uidNumber=-1’, Array, 0, Array)
PHP message: #5 /usr/share/egroupware/api/src/Framework.php(1559): EGroupware\Api\Contacts->read(‘account:-1’, true)
2020/04/05 16:33:42 [error] 6#6: *158185 FastCGI sent in stderr: "
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #39, ‘cn=zelec,cn=lan’, ‘uidNumber=-1001’, Array, 0, 2000)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->searchLDAP(‘cn=zelec,cn=lan’, ‘uidNumber=-1001’, Array, 0, Array)
PHP message: #5 /usr/share/egroupware/calendar/inc/class.calendar_owner_etemplate_widget.inc.php(284): EGroupware\Api\Contacts->read(‘account:-1001’, true)
PHP message: #6 [internal function]: calendar_owner_etemplate_widget::ajax_owner()
PHP message: #8 /usr/share/egroupware/api/src/Json/Request.php(96): EGroupware\Api\Json\Request->handleRequest('calendar_owner…’, Array)
PHP message: #9 /usr/share/egroupware/json.php(125): EGroupware\Api\Json\Request->parseRequest(‘api.queue’, ‘{“request”:{"pa…’)
PHP message: # Instance=default, User=benoit, Request=POST https://jolly/egroupware/json.php?menuaction=api.queue, User-agent=Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0
PHP message: #1 /usr/share/egroupware/api/src/Contacts/Ldap.php(1085): ldap_search(Resource id #39, ‘cn=zelec,cn=lan’, ‘uidNumber=-1000’, Array, 0, 2000)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->searchLDAP(‘cn=zelec,cn=lan’, ‘uidNumber=-1000’, Array, 0, Array)
2020/04/05 16:33:42 [error] 6#6: *158185 FastCGI sent in stderr: "upware/calendar/inc/class.calendar_owner_etemplate_widget.inc.php(284): EGroupware\Api\Contacts->read(‘account:8’, true)
PHP message: #2 /usr/share/egroupware/api/src/Contacts/Ldap.php(421): EGroupware\Api\Contacts\Ldap->searchLDAP(‘cn=zelec,cn=lan’, ‘uidNumber=1002’, Array, 0, Array)
PHP message: #5 /usr/share/egroupware/calendar/inc/class.calendar_owner_etemplate_widget.inc.php(284): EGroupware\Api\Contacts->read(‘account:1002’, true)
2020/04/05 16:33:42 [error] 6#6: *158185 FastCGI sent in stderr: "/Json/Request.php(192): call_user_func_array(Array, Array)
PHP message: #11 /usr/share/egroupware/api/src/Json/Request.php(96): EGroupware\Api\Json\Request->handleRequest('calendar_owner…’, Array)
PHP message: #12 /usr/share/egroupware/json.php(125): EGroupware\Api\Json\Request->parseRequest(‘api.queue’, ‘{“request”:{"pa…’)
PHP message: #13 {main}
PHP message: # Instance=default, User=benoit, Request=POST https://jolly/egroupware/json.php?menuaction=api.queue, User-agent=Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:74.0) Gecko/20100101 Firefox/74.0” while reading response header from upstream, client: 172.20.0.1, server: _, request: “POST /egroupware/json.php?menuaction=api.queue HTTP/1.1”, upstream: “fastcgi://172.20.0.4:9000”, host: “zelec.homelinux.net”, referrer: “https://zelec.homelinux.net/egroupware/index.php?menuaction=calendar.calendar_uiviews.index&ajax=true”
^C
Merci
Benoit
