Hallo Zusammen,
ich bekomme jede Minute den unten dargestellten Eintrag in der /var/log/syslog.
Nov 7 12:54:04 egw kernel: [ 961.574125] br-f3f3d4f657a6: port 2(veth20ec025) entered blocking state
Nov 7 12:54:04 egw kernel: [ 961.574129] br-f3f3d4f657a6: port 2(veth20ec025) entered disabled state
Nov 7 12:54:04 egw kernel: [ 961.574247] device veth20ec025 entered promiscuous mode
Nov 7 12:54:04 egw systemd-udevd[7825]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 7 12:54:04 egw systemd-udevd[7825]: Using default interface naming scheme ‘v245’.
Nov 7 12:54:04 egw systemd-udevd[7825]: vetha13d06a: Could not generate persistent MAC: No data available
Nov 7 12:54:04 egw systemd-udevd[7826]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 7 12:54:04 egw dockerd[1220]: time=“2021-11-07T12:54:04.351117108+01:00” level=info msg="No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]"
Nov 7 12:54:04 egw dockerd[1220]: time=“2021-11-07T12:54:04.351193845+01:00” level=info msg="IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]“
Nov 7 12:54:04 egw systemd-udevd[7826]: Using default interface naming scheme ‘v245’.
Nov 7 12:54:04 egw systemd-udevd[7826]: veth20ec025: Could not generate persistent MAC: No data available
Nov 7 12:54:04 egw systemd-networkd[582]: veth20ec025: Link UP
Nov 7 12:54:04 egw networkd-dispatcher[841]: WARNING:Unknown index 67 seen, reloading interface list
Nov 7 12:54:04 egw containerd[867]: time=“2021-11-07T12:54:04.376414694+01:00” level=info msg=“starting signal loop” namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573 pid=7846
Nov 7 12:54:04 egw kernel: [ 961.878487] eth0: renamed from vetha13d06a
Nov 7 12:54:04 egw systemd-networkd[582]: veth20ec025: Gained carrier
Nov 7 12:54:04 egw kernel: [ 961.906212] br-f3f3d4f657a6: port 2(veth20ec025) entered blocking state
Nov 7 12:54:04 egw kernel: [ 961.906217] br-f3f3d4f657a6: port 2(veth20ec025) entered forwarding state
Nov 7 12:54:04 egw dockerd[1220]: time=“2021-11-07T12:54:04.842037842+01:00” level=info msg=“ignoring event” container=1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573 module=libcontainerd namespace=moby topic=/tasks/delete type=”*events.TaskDelete"
Nov 7 12:54:04 egw containerd[867]: time=“2021-11-07T12:54:04.842402810+01:00” level=info msg=“shim disconnected” id=1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573
Nov 7 12:54:04 egw containerd[867]: time=“2021-11-07T12:54:04.842509535+01:00” level=warning msg=“cleaning up after shim disconnected” id=1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573 namespace=moby
Nov 7 12:54:04 egw containerd[867]: time=“2021-11-07T12:54:04.842533090+01:00” level=info msg="cleaning up dead shim"
Nov 7 12:54:04 egw containerd[867]: time=“2021-11-07T12:54:04.857001233+01:00” level=warning msg="cleanup warnings time=“2021-11-07T12:54:04+01:00” level=info msg=“starting signal loop” namespace=moby pid=7967\n"
Nov 7 12:54:04 egw systemd-networkd[582]: veth20ec025: Lost carrier
Nov 7 12:54:04 egw kernel: [ 962.092539] br-f3f3d4f657a6: port 2(veth20ec025) entered disabled state
Nov 7 12:54:04 egw kernel: [ 962.092666] vetha13d06a: renamed from eth0
Nov 7 12:54:04 egw systemd-udevd[7878]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 7 12:54:04 egw systemd-udevd[7878]: Using default interface naming scheme ‘v245’.
Nov 7 12:54:04 egw systemd-networkd[582]: veth20ec025: Link DOWN
Nov 7 12:54:04 egw kernel: [ 962.142201] br-f3f3d4f657a6: port 2(veth20ec025) entered disabled state
Nov 7 12:54:04 egw kernel: [ 962.144869] device veth20ec025 left promiscuous mode
Nov 7 12:54:04 egw kernel: [ 962.144876] br-f3f3d4f657a6: port 2(veth20ec025) entered disabled state
Nov 7 12:54:04 egw systemd-networkd[582]: rtnl: received neighbor for link ‘68’ we don’t know about, ignoring.
Nov 7 12:54:04 egw systemd-udevd[7878]: vetha13d06a: Failed to get link config: No such device
Nov 7 12:54:04 egw networkd-dispatcher[841]: ERROR:Unknown interface index 67 seen even after reload
Nov 7 12:54:04 egw systemd[4270]: run-docker-netns-af0b7552816f.mount: Succeeded.
Nov 7 12:54:04 egw systemd[1]: run-docker-netns-af0b7552816f.mount: Succeeded.
Nov 7 12:54:05 egw systemd[4270]: var-lib-docker-containers-1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573-mounts-shm.mount: Succeeded.
Nov 7 12:54:05 egw systemd[4270]: var-lib-docker-overlay2-c684ea9148053dfa709dba6618adaaba4ca49c8ddbc94c23853834360104e0fc-merged.mount: Succeeded.
Nov 7 12:54:05 egw systemd[1]: var-lib-docker-containers-1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573-mounts-shm.mount: Succeeded.
Nov 7 12:54:05 egw systemd[1]: var-lib-docker-overlay2-c684ea9148053dfa709dba6618adaaba4ca49c8ddbc94c23853834360104e0fc-merged.mount: Succeeded.
und wieder von vorne, aber mit anderen Bridges…
Nov 7 12:55:04 egw kernel: [ 1022.085853] br-f3f3d4f657a6: port 2(veth59d255b) entered blocking state
Nov 7 12:55:04 egw kernel: [ 1022.085856] br-f3f3d4f657a6: port 2(veth59d255b) entered disabled state
Nov 7 12:55:04 egw kernel: [ 1022.085919] device veth59d255b entered promiscuous mode
Nov 7 12:55:04 egw systemd-udevd[8051]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 7 12:55:04 egw dockerd[1220]: time=“2021-11-07T12:55:04.862868655+01:00” level=info msg="No non-localhost DNS nameservers are left in resolv.conf. Using default external servers: [nameserver 8.8.8.8 nameserver 8.8.4.4]"
Nov 7 12:55:04 egw dockerd[1220]: time=“2021-11-07T12:55:04.862920852+01:00” level=info msg="IPv6 enabled; Adding default IPv6 external servers: [nameserver 2001:4860:4860::8888 nameserver 2001:4860:4860::8844]"
Nov 7 12:55:04 egw systemd-udevd[8051]: Using default interface naming scheme ‘v245’.
Nov 7 12:55:04 egw systemd-udevd[8051]: vethc12b51e: Could not generate persistent MAC: No data available
Nov 7 12:55:04 egw systemd-udevd[8052]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 7 12:55:04 egw systemd-udevd[8052]: Using default interface naming scheme ‘v245’.
Nov 7 12:55:04 egw systemd-udevd[8052]: veth59d255b: Could not generate persistent MAC: No data available
Nov 7 12:55:04 egw networkd-dispatcher[841]: WARNING:Unknown index 69 seen, reloading interface list
Nov 7 12:55:04 egw systemd-networkd[582]: veth59d255b: Link UP
Nov 7 12:55:04 egw containerd[867]: time=“2021-11-07T12:55:04.889510247+01:00” level=info msg=“starting signal loop” namespace=moby path=/run/containerd/io.containerd.runtime.v2.task/moby/1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573 pid=8072
Nov 7 12:55:05 egw kernel: [ 1022.390714] eth0: renamed from vethc12b51e
Nov 7 12:55:05 egw systemd-networkd[582]: veth59d255b: Gained carrier
Nov 7 12:55:05 egw kernel: [ 1022.409326] br-f3f3d4f657a6: port 2(veth59d255b) entered blocking state
Nov 7 12:55:05 egw kernel: [ 1022.409330] br-f3f3d4f657a6: port 2(veth59d255b) entered forwarding state
Nov 7 12:55:05 egw containerd[867]: time=“2021-11-07T12:55:05.343147143+01:00” level=info msg=“shim disconnected” id=1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573
Nov 7 12:55:05 egw containerd[867]: time=“2021-11-07T12:55:05.343217795+01:00” level=warning msg=“cleaning up after shim disconnected” id=1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573 namespace=moby
Nov 7 12:55:05 egw containerd[867]: time=“2021-11-07T12:55:05.343233394+01:00” level=info msg=“cleaning up dead shim"
Nov 7 12:55:05 egw dockerd[1220]: time=“2021-11-07T12:55:05.343312160+01:00” level=info msg=“ignoring event” container=1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573 module=libcontainerd namespace=moby topic=/tasks/delete type=”*events.TaskDelete"
Nov 7 12:55:05 egw containerd[867]: time=“2021-11-07T12:55:05.355889926+01:00” level=warning msg="cleanup warnings time=“2021-11-07T12:55:05+01:00” level=info msg=“starting signal loop” namespace=moby pid=8199\n"
Nov 7 12:55:05 egw systemd-networkd[582]: veth59d255b: Lost carrier
Nov 7 12:55:05 egw kernel: [ 1022.590195] br-f3f3d4f657a6: port 2(veth59d255b) entered disabled state
Nov 7 12:55:05 egw kernel: [ 1022.590307] vethc12b51e: renamed from eth0
Nov 7 12:55:05 egw networkd-dispatcher[841]: WARNING:Unknown index 69 seen, reloading interface list
Nov 7 12:55:05 egw systemd-udevd[8094]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Nov 7 12:55:05 egw systemd-udevd[8094]: Using default interface naming scheme ‘v245’.
Nov 7 12:55:05 egw kernel: [ 1022.632554] br-f3f3d4f657a6: port 2(veth59d255b) entered disabled state
Nov 7 12:55:05 egw systemd-networkd[582]: veth59d255b: Link DOWN
Nov 7 12:55:05 egw kernel: [ 1022.635083] device veth59d255b left promiscuous mode
Nov 7 12:55:05 egw kernel: [ 1022.635093] br-f3f3d4f657a6: port 2(veth59d255b) entered disabled state
Nov 7 12:55:05 egw systemd-networkd[582]: rtnl: received neighbor for link ‘70’ we don’t know about, ignoring.
Nov 7 12:55:05 egw systemd-udevd[8094]: vethc12b51e: Failed to get link config: No such device
Nov 7 12:55:05 egw networkd-dispatcher[841]: ERROR:Unknown interface index 69 seen even after reload
Nov 7 12:55:05 egw systemd[4270]: run-docker-netns-35cf7758a9a1.mount: Succeeded.
Nov 7 12:55:05 egw systemd[1]: run-docker-netns-35cf7758a9a1.mount: Succeeded.
Nov 7 12:55:05 egw systemd[4270]: var-lib-docker-containers-1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573-mounts-shm.mount: Succeeded.
Nov 7 12:55:05 egw systemd[4270]: var-lib-docker-overlay2-c684ea9148053dfa709dba6618adaaba4ca49c8ddbc94c23853834360104e0fc-merged.mount: Succeeded.
Nov 7 12:55:05 egw systemd[1]: var-lib-docker-containers-1964109b2a40a9a6fdd364db7ba7a1f000414dc34d008d81b264a30742092573-mounts-shm.mount: Succeeded.
Nov 7 12:55:05 egw systemd[1]: var-lib-docker-overlay2-c684ea9148053dfa709dba6618adaaba4ca49c8ddbc94c23853834360104e0fc-merged.mount: Succeeded.
Nov 7 12:55:32 egw systemd[1]: Starting Ubuntu Advantage Timer for running repeated jobs…
Nov 7 12:55:32 egw systemd[1]: ua-timer.service: Succeeded.
Nov 7 12:55:32 egw systemd[1]: Finished Ubuntu Advantage Timer for running repeated jobs.
Die EGW selbst scheint davon nicht beeinträchtigt. Auf der Weboberfläche fallen mir keine Fehler auf.
System Ubuntu LTS 20.04 in ESXi VM. Die EGW Container sind die einzigen Container auf der Maschine.
Dank und Gruß,
Hansa
