Good day.
We are using docker on Debian 12.7 via APT package egroupware-docker 23.1.20240930-1. In the app under Admin > Changelog and versions, the latest version listed is 23.1.20250307.
Apparently since the upgrade to 23.1.20250307 we can no longer access resources in the calendar entry dialog via the “Add new participants or resource” textbox/drop-down.
However, if I go to the resources group (left pane), right click on a resource, and select “Book Resource”, I am taken correctly to the calendar creation dialog with the requested resource pre-selected. Such an entry saves fine and appears to work correctly.
I haven’t downgraded to the previous version yet in hopes that there is a simple fix someone is aware of?
Thanks,
Steve
