Hi André,
Hi Ralf,
it’s getting more and more strange:
The file /root/egroupware-epl-install.log has just 2 lines:
Sat Jun 25 22:09:00 UTC 2016
Sat Jun 25 22:09:57 UTC 2016
I have no idea, what this means…
If there’s no other option, I’m going to try a manual installation…
Manual installation gives you exactly what you have now in your docker
file: EGrouware sources are there, but not database is installed. For
Docker that’s usually what you want.
What is your plan for dockerizing EGroupware? One container for
EGroupware sources, one for webserver and one for the database?
Btw. did your dockerfile contained a database, because EGroupware
postinstall will always fail, if there is no database available AND
credentials are either set in enviroment or it is root with empty
password (default for MySQL/MariaDB).
André
Hi Andre,
Hello,
I wanted to produce a docker image to provide an easy installation of
egroupware, but I get a strange error:
While installation it says:
Creating config file /etc/php5/mods-available/ldap.ini with new version
php5_invoke: Enable module ldap for cli SAPI
php5_invoke: Enable module ldap for apache2 SAPI
Setting up egroupware-epl-sambaadmin (14.3.20160525) …
Setting up egroupware-epl-sitemgr (14.3.20160525) …
Setting up egroupware-epl-timesheet (14.3.20160525) …
Setting up egroupware-epl-tracker (14.3.20160525) …
Setting up egroupware-epl-wiki (14.3.20160525) …
Setting up egroupware-epl (14.3.20160525) …
grep: /etc/lsb-release: No such file or directory<--------
You can ignore these, they are from trying to detect an UCS installation.
dpkg: error processing package egroupware-epl (–configure):
subprocess installed post-installation script returned error exit
status 10
EGroupware postinstall scripts writes a log to
/root/egroupware-epl-install.log, have a look for that.
I searched the internet for this error and found some people having
problems with egroupware and debian jessie like
https://sourceforge.net/p/egroupware/mailman/message/34082415/ - but
this isn’t an upgrade, this was an empty installation - a new docker
container.
Or does someone have a working dockerfile for installing?
Thanks in advance,
sneakyx
alias André Scholz
