I have a big CSV file created with Lotus Organizer to be inserted into
Calendar. The file has 6000 lines with the following:
“XXXX”,“2002-09-04 15:30:00.000000000”,"2002-09-04 16:30:00.000000000"
where XXXX is description, date1 is start date and date2 is end date.
I can import normally, and in calendar fieldname I define start data and
end data for both dates. The issue is that the dates is not being sent
to egw_cal_dates table (Postgres database). Instead of that, fields
cal_start and cal_end receive “-1”.
Do you have some idea about how to solve this? I tried some translation
code, but no success.
One comment: I have created a iCal file from Lotus Organizer, but when I
try to import this file I get an error message. Thats why I´m using CSV.
Thanks for any information on this.
Regards.
Marcelo
Luis Marcelo Achite, MSc
Information Technology Manager
Inter-American Institute for Global Change Research - IAI
Avenida dos Astronautas, 1758, Jardim da Granja
12227-010 Sao Jose dos Campos - Sao Paulo - Brazil
Phone: (55-12) 3945-6868 Fax: (55-12) 3941-4410
e-mail : lmachite@dir.iai.int
Skype: lmachite ###############################################################
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
