Hi Ulle,
most issues are already saved, please test it again and let us know,
if you still run into major problems.
If you like, i’m happy to create you an account for our support center
my.stylite.de to report further issues.
Birgit
Stylite Support
[egroupware-developers@lists.sourceforge.net ]
Kopie: Birgit Stylite [bb@stylite.de ]
Hi Ulle,
thanks for your tests and feedback, I’m CCing Birgit who coordinates
these for Stylite with Nathan and who ever is involved.
She will add your email (mehner-at-dfn.de) to our internal ticket, so we
kept informed about the progress.
Calendar is WIP, but there are some hitches in calendar trunk for quite some
time I would like to list here. Hope they get fixed in the near
future … - Sidebar
Search doesn’t work - input search term with Enter does nothing, except
if List view ist choosen
Select box for User/Calendars (id=“calendar-sidebox_owner”) doesn’t give
the choice of multiple selections (neither to choose “All”).
- In Participants-selectbox in column head (list view) groups are
missing as options (which is bad)
- When a group is selected in sidebar selectbox then this group appears
as an (selected) option in selectbox in column head (which is good)
- When current user is selected in sidebar and - When a
different Participant is choosen in column head: Events are
listed from that participant, even where current user is NOT participant
(which is good)
- When “All” is choosen in column head: Events where current user is
NOT participant are NOT listed (which is bad)
All views are broken (probably wrong css) in Firefox, except list view.
Other browsers (Chromium, IE in Win8.1) are rendering OK.
Same situation in Calendar-Box in Home-Pane/App.
Note: “Year view” (from Sidebar select box) seems to be quite ok in
Firefox
All views: After switching between views, translation for headline gets
lost (“List view” instead of “Listenansicht”, Sidebar shows correct
translation)
Red line for “time needed for page rendering” is shown multiple times
(with different values), above and below (if activated in settings)
one line below would be enough
Right after login there seems to be a standard view (could not find a
setting for that). When logging out while on day view and log in again, the
view strangely switches to day view here, while the head line still says
"List view".
Generally I think there should be a possibility to show all ALL events
together I have rights to read, even from other users calendars. Not only
where I am a participant, what currently seems to be the state in
trunk. And than there should be an easy way to hide those other
users calenders I
am allowed to read. Probably best UX would be via checkbox for each calendar
Cheers,
Ulle
eGroupware SVN Trunk
View this message in context:
http://egroupware.219119.n3.nabble.com/Problems-with-current-state-of-Calendar-in-trunk-tp4009298.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
Email: rb@stylite.de www.stylite.de | www.egroupware.org
Birgit Becker
Isaac-Fulda-Allee 9 | 55124 Mainz
Tel: 06131 32702-13 | Fax: 06131 32702-70
cell +49 (0) 170 3147833
mailto: bb@stylite.de | skype: birgit-kl
Geschäftsführer - Managing Directors: Andre Keller | Ralf Becker |
Gudrun Mueller
Vorsitzender Aufsichtsrat - Chairman of the supervisory board: Prof.
VAT DE214280951 | Registergericht Mainz, HRB 46224
Email written with EGroupware: The software for advanced business
communication
