I’m using eGroupWare 1.4.002 and Funambol 6.5.7.
Could you send the apache error log file for the failed sync ? The
funambol log file just tells you that there has been a problem on the
server. Investigation has to happen from there.
[/quote]
This is the extract of the Apache error log:
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n
[id] => 374\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 375\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 376\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 377\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 380\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 381\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 382\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 383\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 384\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 385\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 386\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 387\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 389\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 390\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 391\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 392\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 393\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 394\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 395\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 396\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 397\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 398\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 399\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 400\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 402\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 410\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 412\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 413\n [photo] => \n )\n\n)\n
[Tue Feb 12 15:22:27 2008] [error] [client 192.168.1.111] Array\n(\n [0] => Array\n (\n [id] => 414\n [photo] => \n )\n\n)\n
This is the extract of the /tmp/egroupware_syncml.log:
Feb 12 15:19:24 EGWSYNC [info] [] SyncML: setUID ./sifcontacts, 00000000B14AAA78FBCEA246942DB403B7121284C4172000, something went wrong!!! Mapping not found. [on line 374 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: setUID contacts-520-5e193e9ffc2431ac5015a9788c7d3c0c => contacts-520-5e193e9ffc2431ac5015a9788c7d3c0c [on line 378 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: setUID ./sifcontacts, 00000000B14AAA78FBCEA246942DB403B7121284C4172000, contacts-520-5e193e9ffc2431ac5015a9788c7d3c0c, 1202825964 [on line 383 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: r/ added client entry as contacts-520-5e193e9ffc2431ac5015a9788c7d3c0c [on line 166 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/Sync/SlowSync.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: try to add contentype text/x-s4j-sifc to sifcontacts [on line 159 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/Sync/SlowSync.php”]
Feb 12 15:19:24 EGWSYNC [info] [] SyncML: setUID ./sifcontacts, 00000000B14AAA78FBCEA246942DB403B7121284E4172000, something went wrong!!! Mapping not found. [on line 374 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: setUID contacts-521-5e193e9ffc2431ac5015a9788c7d3c0c => contacts-521-5e193e9ffc2431ac5015a9788c7d3c0c [on line 378 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: setUID ./sifcontacts, 00000000B14AAA78FBCEA246942DB403B7121284E4172000, contacts-521-5e193e9ffc2431ac5015a9788c7d3c0c, 1202825964 [on line 383 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: r/ added client entry as contacts-521-5e193e9ffc2431ac5015a9788c7d3c0c [on line 166 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/Sync/SlowSync.php”]
Feb 12 15:19:24 EGWSYNC [info] [] SyncML: setUID ./sifcontacts, 00000000B14AAA78FBCEA246942DB403B712128404182000, something went wrong!!! Mapping not found. [on line 374 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: setUID contacts-522-5e193e9ffc2431ac5015a9788c7d3c0c => contacts-522-5e193e9ffc2431ac5015a9788c7d3c0c [on line 378 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: setUID ./sifcontacts, 00000000B14AAA78FBCEA246942DB403B712128404182000, contacts-522-5e193e9ffc2431ac5015a9788c7d3c0c, 1202825964 [on line 383 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/State_egw.php”]
Feb 12 15:19:24 EGWSYNC [debug] [] SyncML: r/ added client entry as contacts-522-5e193e9ffc2431ac5015a9788c7d3c0c [on line 166 of “/home/web/default/egroupware/phpgwapi/inc/horde/Horde/SyncML/Sync/SlowSync.php”]
Bye!
