Newer php does NOT allow: php_value mbstring.func_overload 7
you have to use instead: php_admin_value mbstring.func_overload 7
Listas schrieb:
Hi Ralf,
I need help to understand and solve a problem.
I’m using egroupware 1.6.001 installed by rpm and updated by daily
snapshot into fedora 10. I work with projecterp 0.4 svn last week, and I
have problems to generate reports because it don’t accepting UTF-8
multibyte characters like ç á é à ã.
The two files attached shows this. In the first, there are a “Test
Supplier” and the report are generated clearly. In the second I included
multibyte characters and the report don’t worked fine.
My config files are below (the parts that interests):
* egroupware.conf
<Directory /usr/share/egroupware/>
Options FollowSymLinks ExecCGI
AllowOverride None
Order allow,deny
Allow from all
DirectoryIndex index.html index.php
AddHandler cgi-script .cgi
AddDefaultCharset Off
php_flag file_uploads on
php_flag log_errors on
php_flag magic_quotes_gpc off
php_flag magic_quotes_runtime off
php_flag register_globals off
php_flag short_open_tag on
php_flag track_vars on
php_flag display_errors off
php_value error_reporting 'E_ALL & ~E_NOTICE'
php_value max_execution_time 90
* php_value mbstring.func_overload 7*
php_value memory_limit 128M
php_value session.gc_maxlifetime 14400
php_value include_path .:/usr/share/pear
php_value open_basedir
/usr/share/egroupware:/var/lib/egroupware:/tmp:/usr/share/pear
php_value upload_max_filesize 64M
<Location /egroupware/rpc.php>
*php_value mbstring.func_overload 0*
Order allow,deny
Allow from all
</Location>
* php.ini
[mbstring]
; language for internal character representation.
;mbstring.language = Japanese
; internal/script encoding.
; Some encoding cannot work as internal encoding.
; (e.g. SJIS, BIG5, ISO-2022-*)
;mbstring.internal_encoding = EUC-JP
; http input encoding.
;mbstring.http_input = auto
; http output encoding. mb_output_handler must be
; registered as output buffer to function
;mbstring.http_output = SJIS
; enable automatic encoding translation according to
; mbstring.internal_encoding setting. Input chars are
; converted to internal encoding by setting this to On.
; Note: Do _not_ use automatic encoding translation for
; portable libs/applications.
;mbstring.encoding_translation = Off
; automatic encoding detection order.
; auto means
;mbstring.detect_order = auto
; substitute_character used when character cannot be converted
; one from another
;mbstring.substitute_character = none;
; overload(replace) single byte functions by mbstring functions.
; mail(), ereg(), etc are overloaded by mb_send_mail(), mb_ereg(),
; etc. Possible values are 0,1,2,4 or combination of them.
; For example, 7 for overload everything.
; 0: No overload
; 1: Overload mail() function
; 2: Overload str*() functions
; 4: Overload ereg*() functions
*;mbstring.func_overload = 0*
; enable strict encoding detection.
;mbstring.strict_encoding = Off
I already talked about it with Nathan Gray but we still don’t solve it.
http://www.nabble.com/report_purchase_order-is-not-generating-td23370666.html
Can you help us to understand this and fix this problem?
Thanks and regards.
Register Now for Creativity and Technology (CaT), June 3rd, NYC. CaT
is a gathering of tech-side developers & brand creativity professionals. Meet
the minds behind Google Creative Lab, Visual Complexity, Processing, &
iPhoneDevCamp as they present alongside digital heavyweights like Barbarian
Group, R/GA, & Big Spaceship. http://p.sf.net/sfu/creativitycat-com
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Nigel Vickers und Ralf Becker
