Hi Daniel,
Hello all,
we use projectmanager part of EGW to keep track of time spent on project. The used-to-be behaviour was, that when we entered detail of the project, on upper right corner we have button to add new detail right next to list of possible entry types. We were used to behaviour, that when I select to add timesheet entry, the timesheet type remains selected until I change the to other type of event from the list.Now, possibly after some update, the value of the default detail type always reverts to some “default” value. In my case it is “mail”, my coleague has there “calendar” as default type.
Is that intended behaviour?
I don’t think so.
Please create a trial
(http://www.egroupware.org/en/products/cloud-services-30-day-free-trial.html),
try to reproduce there and use my.stylite.de credentials, you receive
with the trial, to report that bug.
Is there an option to change that?
Thank you,
Daniel
