Hello ,
I need some help with Project Manager.
My problem is that I need to create sub projects and control them, but I can’t seem to figure out how to change the project parent in order to move it as sub some other project after creating it.
Also I need to know if it is possible to import projects and in the CVS files to set the parent and sub projects in the needed structure.
Thanks in advance.
