Hi
I try to setup an non-privileged account for external people that can see the projects they are part of and read them for e.g. integration into timecards. This works fine using roles except the user is always able to add new projects with the button lower left. I would like to disable this but I couldn’t find a way. If I set group or user-acls for projectmanager to read-only he can see any project and still can add projects the way described above. If I disable Projectmanager at all for the group there is no possibility any more to attach timecards or infologs to projects even if the user is part of project-members and allowed in the roles. Is there a way to do this?
Regards,
Lukas WOLEK
