Dear Ralf,
as you requested for previous comment i reproduce a problem in
https://proj.egroupware.de/egw
as a new trial
user/pw: sysop/xuA#/Fk>
the behavior is the following:
there are 2 different projects
i try to fill in timesheet elements with timesheet app
fill in first element to “P-2015-0001: 1”
click on ‘save as new’
click on small ‘x’ to remove old project 1
i try to create a new ts element but to the 2nd project “P-2015-0002: 2”
and now the problem(s):
sometime the linking to the new project does not work: it remains to the 1st one
sometimes the title remains in timesheet overview, means the 2 entries have same 1st title
I found a synchronize menu right click on a project under project view, but it did not help. What exactly this feature is used for?
thanks in advance & br
Erik
