Please apologize if this is not the best forum.
I receive this error when selecting some ProjectManager elements (Subprojects):
Fatal error: Maximum execution time of 30 seconds exceeded in /var/www/egw16/projectmanager/inc/class.projectmanager_bo.inc.php on line 793
Usually they have a few levels of subprojects and some items on them.
Being always the same causing the error, I suspect there must be some problems with their records on the databases.
I think that this started to happen when I “moved” projects down one level. I.e., I created an overall project called 2009 and moved the few projects at the root level by relinking them to the newly created project 2009. I did the same for all the inner Subprojects. I don’t know if this was reasonable or not but I did want to try.
The strange thing is that all data regarding the projects elements seem to be there:
They are listed if the filter All (Mainprojects+Subprojects) is chosen on the Projectlist.
Their Subprojects can be accessed from this Projectlist, albeit those that cause errors do not.
All the records related to projects, including those causing errors, seem to be present on the egw_pm_projects table.
I repaired all tables ad some reported having been repaired, but the problem still happens.
Also, I would like to understand how are the relationships Project-subprojects represented on the tables so that I could see if something is missing. I took a look at all the tables egw_pm_* and was unable to find the field(s), table(s) or method used for this purpose.
Any and all help will be greatly appreciated.
Thank you,
Jose
