Hi Pakus,
our (Conny, Lars, Ralf) plans are to allow the admin to add further LDAP
addressbooks (possibly readonly). Users will see this addressbooks in
the Addressbook List as “Addressbooks” (They are not search in “All”).
Then we only need to modify the search in FMail to search all
addressbooks and not only search in “All” (which will not include the
extra LDAP AB’s nor the accounts if they are in LDAP and contacts are not).
Pakus schrieb:
Hiya,
Done Ralf, thanks in advance…
With some initial help I’ll try to code part of this feature, LDAP
connection, but there’re several design decisions about it.
[/quote]
Do you have a time schedule to realize this feature (reading/searching LDAP-Adressbooks) ?
Furthermore, do you have any idears about writing to LDAP-Servers (allowing egroupware-users to add & modify entries in an LDAP-Adressbook) ?
