Hi Stefan,
Dear developers,
in our installation (actual trunkversion) we used or started to use
ProjectReportMind, which is originally a french module from Versusmind. It
worked until json started to take over the functions from xajax, which, as
you posted a few weeks ago, isn’t necessary anymore and has been deleted
from trunk.
Now I updated to the new version of PRM and had to reinstall xajax.inc.php,
because it obviously is mandatory to get PRM to work. Some things seem to
work now, but I’ve got a lot of errors showing “Ajax request to
http://mysite/json.php?menuaction=rida.ajax_edition_etape2.ajax_search_in_calendar_import
failed: error” or e.g. “Ajax request to
http://mysite/json.php?menuaction=rida.ajax_edition_etape2.ajax_search_accounts
failed: error” .
I don’t know how to overcome this, so my question is, if it is possible to
re-activate the xajax-components in trunk to match some (old) modules which
need this function to work properly.
NO, we emulate most of the old xajax functions in our new code. If the
app you mentioned uses xajax as all the other egroupware apps do, it
will work with json as well as with xajax.
JSON is a full replacement for xajax, you can not install both!
JSON has one requirement: installations have to use utf-8! Is your
installation still using iso-8859-1? In that case you have to convert it
to utf-8 (create a db-backup in setup or admin and restore it, that’s
all it takes in an up to date trunk).
Otherwise the author of the app needs to fix his app.
Thanks in advance and keep on with your excellent work
Thanks
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Sell apps to millions through the Intel® Atom™ Developer Program
Be part of this innovative community and reach millions of netbook users
worldwide. Take advantage of special opportunities to increase revenue and
speed time-to-market. Join now, and jumpstart your future.
http://p.sf.net/sfu/intel-atom-d2d
