Author: ralfbecker
New Revision: 54896
URL: http://svn.stylite.de/viewvc/egroupware?rev=54896&view=rev
temporary reverting r54893: Multi-line ellipsis on event bodies that are longer than their space can show
trunk/calendar/js/et2_widget_daycol.js
trunk/calendar/js/et2_widget_event.js
trunk/calendar/templates/default/app.css
— trunk/calendar/js/et2_widget_daycol.js (original)
+++ trunk/calendar/js/et2_widget_daycol.js Tue Feb 2 10:19:31 2016
@@ -76,7 +76,6 @@
.addClass(“calendar_calDayColAllDay”)
.appendTo(this.header);
this.event_wrapper = $j(document.createElement(‘div’))
— trunk/calendar/js/et2_widget_event.js (original)
+++ trunk/calendar/js/et2_widget_event.js Tue Feb 2 10:19:31 2016
@@ -343,12 +343,8 @@
this.body
.html('<span class="calendar_calEventTitle">'+title+'</span>')
.append('<span class="calendar_calTimespan">'+start_time + '</span>');
if(this.options.value.description.trim())
this.body
.append('<p>'+this.options.value.description+'</p>');
@@ -362,34 +358,19 @@
* > 4 - Show description as well, truncated to fit
_small_size: function() {
// Pre-calculation reset
this.div.removeClass('calendar_calEventSmall');
this.body.css('height', 'auto');
if(this.options.value.whole_day_on_top) return;
var line_height = parseFloat(this.div.css('line-height'));
var visible_lines = Math.floor(this.div.innerHeight() / line_height);
visible_lines = Math.max(1,visible_lines);
this.div.toggleClass('calendar_calEventSmall',visible_lines < 4);
this.div
.attr('data-visible_lines', visible_lines);
if(this.body.height() > this.div.height() - this.title.height() && visible_lines >= 4)
this.body.css('height', Math.floor((visible_lines-1)*line_height - this.title.height()) + 'px');
else
this.body.css('height', '');
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Tue Feb 2 10:19:31 2016
@@ -556,20 +556,6 @@
cursor: pointer;
-/** Multi-line ellipsis */
-.calendar_calEvent .calendar_calEventBody {
- overflow: hidden;
-.calendar_calTimeGrid:not(.calendar_calTimeGridList) .calendar_calEvent::after {
- width: 100%;
- background-color: rgba(255,255,255,0.9);
- height: 0.9em;
- content: “\02026”;
- left: 0px;
- float: right;
- padding-bottom: 2em;
- text-indent: 5px;
- User has not accepted the invitation
@@ -759,7 +745,7 @@
.calendar_calTimeGridList .calendar_calDayColHeader > div[data-date] {
border: none;
-.calendar_calTimeGridList .calendar_calDayCol > div.event_wrapper
+.calendar_calTimeGridList .calendar_calDayCol > div:first-child
position: absolute;
top: 0px;
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Tue Feb 2 10:19:31 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 54892 2016-02-01 20:52:53Z nathangray $ /
+/ $Id: app.css 54876 2016-01-28 22:08:15Z nathangray $ /
/Media print classes/
@media print {
.th td,
@@ -559,20 +559,6 @@
.calendar_calEvent:hover {
cursor: pointer;
-/* Multi-line ellipsis */
- overflow: hidden;
- width: 100%;
- background-color: rgba(255, 255, 255, 0.9);
- height: 0.9em;
- left: 0px;
- float: right;
- text-indent: 5px;
@@ -746,7 +732,7 @@
border: none;
-.calendar_calTimeGridList .calendar_calDayCol > div.event_wrapper {
+.calendar_calTimeGridList .calendar_calDayCol > div:first-child {
position: absolute;
top: 0px;
bottom: 3em;
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
eGroupWare-cvs mailing list
