Author: nathangray
New Revision: 54911
URL: http://svn.stylite.de/viewvc/egroupware?rev=54911&view=rev
Sidebox calendar buttons
- change button colors
- change tooltip for added buttons to match jqueryui buttons
- finally found (& removed) that 1px wiggle
trunk/calendar/js/app.js
trunk/calendar/js/et2_widget_event.js
trunk/calendar/templates/default/app.css
trunk/calendar/templates/default/sidebox.xet
trunk/calendar/templates/pixelegg/app.less
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Wed Feb 3 17:52:28 2016
@@ -3115,7 +3115,7 @@
var temp_date = new Date(year, month-1, 1,0,0,0);
//temp_date.setUTCMinutes(temp_date.getUTCMinutes() + temp_date.getTimezoneOffset());
go_button.btn.attr('title',egw.lang(date('F',temp_date)));
// Store current _displayed_ date in date button for clicking
temp_date.setUTCMinutes(temp_date.getUTCMinutes() - temp_date.getTimezoneOffset());
@@ -3194,6 +3194,7 @@
// Set today button
var today = $j('#calendar-sidebox_header_today');
@@ -3204,9 +3205,11 @@
temp_date.setUTCDate(1);
go_button.attr('title', egw.lang(date('F',temp_date)));
go_button.attr('data-date', temp_date.toJSON());
// Dynamic resize of sidebox calendar to fill sidebox
— trunk/calendar/js/et2_widget_event.js (original)
+++ trunk/calendar/js/et2_widget_event.js Wed Feb 3 17:52:28 2016
@@ -306,9 +306,6 @@
// Header
var title = !event.is_private ? event[‘title’] : egw.lang(‘private’);
@@ -350,6 +347,9 @@
.append(’
’+this.options.value.description+’
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Wed Feb 3 17:52:28 2016
@@ -555,12 +555,13 @@
.calendar_calTimeGrid:not(.calendar_calTimeGridList) *:not(.calendar_calDayColAllDay) > .calendar_calEvent::after {
width: 100%;
background-color: rgba(255,255,255,0.9);
- height: 5px;
content: “\02026”;
left: 0px;
float: right;
padding-bottom: 5em;
text-indent: 5px;
- line-height: 5px;
- User has not accepted the invitation
— trunk/calendar/templates/default/sidebox.xet (original)
+++ trunk/calendar/templates/default/sidebox.xet Wed Feb 3 17:52:28 2016
@@ -15,13 +15,13 @@
var tempDate = new Date();
var today = new Date(tempDate.getFullYear(), tempDate.getMonth(), tempDate.getDate(),0,-tempDate.getTimezoneOffset(),0);
var change = {date: today.toJSON()};
if(app.calendar.state.view == ‘planner’) { change.planner_days = Math.ceil((new Date(app.calendar.state.last) - new Date(app.calendar.state.first)) / (24*3600000));}
app.calendar.update_state(change);return false;"/>
<buttononly id="header_go" label="↵" icon="nope" statustext="Go" class="ui-corner-all" onclick="var change = {date: widget.btn.attr('data-date')}; if(app.calendar.state.view == 'planner') { change.planner_days = 0;change.first=change.date;var d = new Date(change.date);d = new Date(d.getFullYear(),d.getUTCMonth() + 1, 0);change.last=d.toJSON();} else if ( app.calendar.state.view == 'listview') {change.filter='month';} else {change.view = 'month';}app.calendar.update_state(change);" />
<buttononly id="header_go" label="↵" icon="nope" class="ui-corner-all" onclick="var change = {date: widget.btn.attr('data-date')}; if(app.calendar.state.view == 'planner') { change.planner_days = 0;change.first=change.date;var d = new Date(change.date);d = new Date(d.getFullYear(),d.getUTCMonth() + 1, 0);change.last=d.toJSON();} else if ( app.calendar.state.view == 'listview') {change.filter='month';} else {change.view = 'month';}app.calendar.update_state(change);" />
<date id="date" class="et2_fullWidth" inline="true" onchange="var view_change = app.calendar.sidebox_changes_views.indexOf(app.calendar.state.view);
var update = {date:widget.getValue()};
if(view_change >= 0) {update.view = app.calendar.sidebox_changes_views[view_change ? view_change - 1 : view_change];} else if (app.calendar.state.view == ‘listview’) {update.filter = ‘after’;} else if (app.calendar.state.view ==‘planner’) { update.planner_days = 1; } app.calendar.update_state(update);"/>
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Wed Feb 3 17:52:28 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 54904 2016-02-02 21:12:44Z nathangray $ /
+/ $Id: app.css 54905 2016-02-02 22:59:13Z nathangray $ */
/Media print classes/
@media print {
.th td,
@@ -560,12 +560,13 @@
width: 100%;
background-color: rgba(255, 255, 255, 0.9);
- height: 5px;
content: “\02026”;
left: 0px;
float: right;
text-indent: 5px;
- line-height: 5px;
@@ -2545,8 +2546,19 @@
#calendar-sidebox_date .ui-datepicker-year {
padding-right: 15px !important;
-#calendar-sidebox_date #calendar-sidebox_header_today {
- background-image: url(images/today.png);
+#calendar-sidebox_date .ui-datepicker-header a span {
- background-image: url(’…/…/…/phpgwapi/js/jquery/jquery-ui/redmond/images/ui-icons_217bc0_256x240.png’);
+#calendar-sidebox_date .ui-datepicker-header a.ui-state-hover {
- top: 3px;
+#calendar-sidebox_date .ui-datepicker-header a.ui-state-hover span {
- background-image: url(’…/…/…/pixelegg/images/ui-icons_egw_color_2_256x240_0C5DA5.png’);
- transition: none;
+#calendar-sidebox_header_go,
+#calendar-sidebox_header_today {
- background-color: #0c5da5;
#calendar_cat_id,
#calendar_filter,
— trunk/calendar/templates/pixelegg/app.less (original)
+++ trunk/calendar/templates/pixelegg/app.less Wed Feb 3 17:52:28 2016
@@ -11,6 +11,7 @@
@package calendar
@version $Id$
@import (reference) “…/…/…/pixelegg/less/definitions.less”;
@@ -1369,9 +1370,21 @@
// Select Fields in Sidemenu
#calendar_cat_id,
http://pubads.g.doubleclick.net/gampad/clk?id=267308311&iu=/4140
eGroupWare-cvs mailing list
