Author: nathangray
New Revision: 54926
URL: http://svn.stylite.de/viewvc/egroupware?rev=54926&view=rev
- Disable scrolling to change week (swipe & pg up/ pg dn kept)
- Remove animations
trunk/calendar/js/app.js
trunk/calendar/js/et2_widget_daycol.js
trunk/calendar/js/et2_widget_timegrid.js
trunk/calendar/templates/default/app.css
trunk/calendar/templates/pixelegg/app.less
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Thu Feb 4 22:05:31 2016
@@ -650,7 +650,8 @@
},this, et2_calendar_timegrid);
if(widget == null) return;
@@ -756,7 +757,13 @@
// If detecting the transition end worked, we wouldn’t need to use a timeout.
window.setTimeout(remove,100);
window.setTimeout(function() {
if(app.calendar)
app.calendar._scroll_disabled = false;
}, 2000);
// Get the view to calculate - this actually loads the new data
// Using a timeout make it a little faster (in Chrome)
@@ -777,6 +784,7 @@
// Bind only once, to the whole thing
/* Disabled
jQuery('body').off('.calendar')
//.on('wheel','.et2_container:#calendar-list,#calendar-sidebox)',
.on('wheel.calendar','.et2_container .calendar_calTimeGrid, .et2_container .calendar_plannerWidget',
@@ -806,6 +814,7 @@
return false;
— trunk/calendar/js/et2_widget_daycol.js (original)
+++ trunk/calendar/js/et2_widget_daycol.js Thu Feb 4 22:05:31 2016
@@ -393,31 +393,19 @@
this.title.toggleClass(‘et2_clickable et2_link’,label === ‘’);
set_left: function(left) {
// Maybe?
window.setTimeout(jQuery.proxy(function() {
if(this.div)
this.div.css('left',left);
// Headers are positioned relative
//this.header.css('left',left);
},this),1);
set_width: function(width) {
if(this.width_timeout)
window.clearTimeout(this.width_timeout);
this.options.width = width;
this.width_timeout = window.setTimeout(jQuery.proxy(function() {
this.width_timeout = null;
if(this.div)
this.div.outerWidth(this.options.width);
this.header.outerWidth(this.options.width);
},this),1);
— trunk/calendar/js/et2_widget_timegrid.js (original)
+++ trunk/calendar/js/et2_widget_timegrid.js Thu Feb 4 22:05:31 2016
@@ -869,18 +869,15 @@
before = true;
if(delete_index < 0) delete_index = 0;
// Wait until any animations or other timeouts are done
this.div.hide();
this.header.hide();
this.free();
},this.day_widgets[delete_index]),1000);
// Widgets that are before our date shrink, after just get pushed out
if(before)
this.day_widgets[delete_index].set_width('0px');
this.day_widgets[delete_index].div.hide();
this.day_widgets[delete_index].header.hide();
this.day_widgets[delete_index].destroy();
this.day_widgets.splice(delete_index--,1);
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Thu Feb 4 22:05:31 2016
@@ -107,14 +107,12 @@
#calendar-todo {
position: absolute;
width: 30%;
- margin-top: 0px;/* Nice transition when changing days in a week */
- transition: 1s ease-in-out;
- margin-top: 0px;
z-index: 10;
#calendar-view {
width: 100%;
- transition: width 1s ease-in-out;
#calendar-view_view td {
padding: 0px;
@@ -320,8 +318,8 @@
- border-left: 1px solid silver;/* Nice transition when changing days in a week */
- -webkit-transition: 0.1s ease-in-out;
- transition: none;
/* Calendar Id #
@@ -341,8 +339,8 @@
border-right: 1px solid silver;
height: initial;
min-height: 2em;
- /* Nice transition when changing days in a week */
- transition: none;
z-index:30;
white-space: initial;
padding-bottom: 2ex;
@@ -1202,7 +1200,7 @@
.calendar_slide {
/ There is a cleanup timeout in calendar app.js line 563 that must match */
- transition-duration: 0s; /* was 2s */
transition-delay: 50ms;
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Thu Feb 4 22:05:31 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 54905 2016-02-02 22:59:13Z nathangray $ /
+/ $Id: app.css 54911 2016-02-03 16:52:28Z nathangray $ */
/Media print classes/
@media print {
.th td,
@@ -121,13 +121,10 @@
position: absolute;
width: 30%;
margin-top: 0px;
z-index: 10;
#calendar-view {
width: 100%;
padding: 0px;
@@ -333,8 +330,7 @@
- width:
- transition: none;
/* Calendar Id #
@@ -356,8 +352,7 @@
height: initial;
min-height: 2em;
- transition: none;
z-index: 30;
@@ -1186,7 +1181,8 @@
.calendar_slide {
- /* was 2s /
— trunk/calendar/templates/pixelegg/app.less (original)
+++ trunk/calendar/templates/pixelegg/app.less Thu Feb 4 22:05:31 2016
@@ -11,7 +11,6 @@
@package calendar
@version $Id$
@import (reference) “…/…/…/pixelegg/less/definitions.less”;
eGroupWare-cvs mailing list
