Author: nathangray
New Revision: 54941
URL: http://svn.stylite.de/viewvc/egroupware?rev=54941&view=rev
Add minimum height for weeks - 1/2 hour must be at least 1 line high
trunk/calendar/js/et2_widget_daycol.js
trunk/calendar/js/et2_widget_timegrid.js
trunk/calendar/templates/default/app.css
— trunk/calendar/js/et2_widget_daycol.js (original)
+++ trunk/calendar/js/et2_widget_daycol.js Fri Feb 5 19:17:47 2016
@@ -531,6 +531,23 @@
* Apply styles for out-of-view and partially hidden events
- There are 3 different states or modes of display:
- ‘Normal’ - When showing events positioned by time, the indicator is just
- a bar colored by the last category color. On hover it shows either the
- title of a single event or “x event(s)” if more than one are hidden.
- Clicking adjusts the current view to show the earliest / latest hidden
- Fixed - When showing events positioned by time but in a fixed-height
- week (not auto-sized to fit screen) the indicator is the same as sized.
- On hover it shows the titles of the hidden events, clicking changes
- the view to the selected day.
- GridList - When showing just a list, the indicator shows “x event(s)”,
- and on hover shows the category color, title & time. Clicking changes
- the view to the selected day, and opens the event for editing.
_out_of_view: function()
@@ -591,8 +608,9 @@
// Reset
event.title.css({‘top’:’’,‘background-color’:’’});
event.body.css({'padding-top':'','margin-top':''});
var hidden = isHidden.call(this,event.div);
var day = this;
if(!hidden)
return;
@@ -601,16 +619,19 @@
// Bottom hidden is fine
if(hidden.hidden === ‘top’ && !hidden.completely)
event.body.css({
'padding-top': timegrid.scrolling.scrollTop() - event.div.position().top + title_height,
'margin-top' : -title_height
// Too many in gridlist view, show indicator
else if (this.display_settings.granularity === 0 && hidden)
@@ -625,7 +646,12 @@
// Completely out of view, show indicator
else if (hidden.completely)
this._hidden_indicator(event, hidden.hidden == 'top',
timegrid.div.hasClass('calendar_calTimeGridFixed') ? function() {
app.calendar.update_state({view: 'day', date: day.date});
return false;
} : false
}, this, et2_calendar_event);
@@ -642,24 +668,42 @@
var indicator = ‘’;
var day = this;
var timegrid = this._parent;
var fixed_height = timegrid.div.hasClass('calendar_calTimeGridFixed');
if(top)
if($j('.hiddenEventBefore',this.header).length === 0)
indicator = $j('<div class="hiddenEventBefore"></div>')
.appendTo(this.header)
.text(event.options.value.title)
.attr('data-hidden_count', 1)
.on('click', typeof onclick === 'function' ? onclick : function() {
$j('.calendar_calEvent',day.div).first()[0].scrollIntoView();
return false;
.attr('data-hidden_count', 1);
if(!fixed_height)
indicator
return false;
else
indicator
.append("<div>"+event.options.value.title+"</div>");
else
indicator = $j('.hiddenEventBefore',this.header);
indicator.attr('data-hidden_count', parseInt(indicator.attr('data-hidden_count')) + 1);
if (fixed_height)
indicator.append("<div>"+event.options.value.title+"</div>");
else
indicator.text(day.egw().lang('%1 event(s) %2',indicator.attr('data-hidden_count'),''));
else
@@ -675,14 +719,23 @@
// Better re-run this to clean up
day._out_of_view();
return false;
if(fixed_height)
indicator
.on('mouseover', function() {
indicator.css({
'height': (indicator.attr('data-hidden_count')*1.2) + 'em',
'margin-top': -(indicator.attr('data-hidden_count')*1.2) + 'em'
.on('mouseout', function() {
indicator.css({
'height': '',
'margin-top': ''
var count = parseInt(indicator.attr('data-hidden_count')) + 1
indicator.attr('data-hidden_count', count);
@@ -691,6 +744,10 @@
indicator.append(event.div.clone());
indicator.attr(‘data-hidden_label’, day.egw().lang(’%1 event(s) %2’,indicator.attr(‘data-hidden_count’),’’));
else if (fixed_height)
else
@@ -702,8 +759,8 @@
// Avoid white, which is hard to see
// Use border-bottom-color, Firefox doesn’t give a value with border-color
var color = jQuery.Color(event.div.css('background-color')).toString() !== jQuery.Color('white').toString() ?
event.div.css('background-color') : event.div.css('border-bottom-color');
if(color !== 'rgba(0, 0, 0, 0)')
indicator.css('border-color', color);
— trunk/calendar/js/et2_widget_timegrid.js (original)
+++ trunk/calendar/js/et2_widget_timegrid.js Fri Feb 5 19:17:47 2016
@@ -1706,11 +1706,14 @@
// Set the max width to avoid animations screwing up the width
this.div.css(‘max-width’,$j(this.getInstanceManager().DOMContainer).width());
// We expect the timegrid to be in a table with 0 or more other timegrids,
// 1 per row. We want each timegrid to be as large as possible, but space
// shared equally. Height can't be set to a percentage on the rows, because
// that doesn't work.
that doesn't work. However, if the timegrid is too small (1/2 hour < 1 line
height), we change to showing only the working hours with no vertical
scrollbar. Each week gets as much space as it needs.
// How many rows?
var rowCount = 0;
this._parent.iterateOver(function(widget) {
@@ -1718,7 +1721,7 @@
},this, et2_calendar_timegrid);
// Take the whole tab height
@@ -1728,13 +1731,35 @@
// Allow for borders & padding
this.options.height -= 2*((this.div.outerWidth(true) - this.div.innerWidth()) + parseInt(this.div.parent().css(‘padding-top’)));
// If too small, switch to list view automatically
// Set rather arbitrarily at 180 px.
if(this.options.granularity && rowCount > 1 && this.options.height < 180)
if(!widget.disabled) widget.set_granularity(0);
// Calculate how much space is needed, and
// if too small be bigger
var needed = ((this.day_end - this.day_start) /
(this.options.granularity / 60) * parseInt(this.div.css('line-height'))) +
this.gridHeader.outerHeight();
var too_small = needed > this.options.height && this.options.granularity != 0;
.css({
'overflow-y': too_small ? 'auto' : 'hidden',
'overflow-x': 'hidden',
'height': too_small ? height : '100%'
if(too_small)
this.options.height = needed;
if(!this.div.hasClass('calendar_calTimeGridFixed'))
window.setTimeout(jQuery.proxy(function() {
if(!widget.disabled) widget.resize();
},this),1);
this.div.addClass('calendar_calTimeGridFixed');
else
this.div.removeClass('calendar_calTimeGridFixed');
this.div.css('height', this.options.height);
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Fri Feb 5 19:17:47 2016
@@ -237,6 +237,10 @@
right: 0px;
position: absolute;
+/* Timegrid that has hit a minimum size */
+.calendar_calTimeGridFixed .calendar_calTimeGridScroll {
Show the day headers for single week view only once.
@@ -389,6 +393,9 @@
margin-top: -20px;
height: 20px;
background-color: white;
+.calendar_calTimeGridFixed .calendar_calDayCol .hiddenEventAfter:hover .calendar_calEvent {
/* Days in a different month, but shown to fill out the week */
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Fri Feb 5 19:17:47 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 54927 2016-02-04 22:35:34Z nathangray $ /
+/ $Id: app.css 54928 2016-02-04 23:14:54Z nathangray $ /
/Media print classes/
@media print {
.th td,
@@ -250,6 +250,10 @@
right: 0px;
position: absolute;
+/ Timegrid that has hit a minimum size */
- overflow: hidden;
Hide subsequent headers in week view with non-consolidated owners
@@ -401,6 +405,9 @@
margin-top: -20px;
height: 20px;
- position: relative;
.calendar_calDayColHeader.calendar_differentMonth > * {
eGroupWare-cvs mailing list
