Author: nathangray
New Revision: 54963
URL: http://svn.stylite.de/viewvc/egroupware?rev=54963&view=rev
Use taglist for owner
Added:
trunk/calendar/js/et2_widget_owner.js
trunk/calendar/inc/class.calendar_ui.inc.php
trunk/calendar/inc/class.calendar_uiforms.inc.php
trunk/calendar/js/app.js
trunk/calendar/templates/default/sidebox.xet
— trunk/calendar/inc/class.calendar_ui.inc.php (original)
+++ trunk/calendar/inc/class.calendar_ui.inc.php Tue Feb 9 21:28:57 2016
@@ -618,20 +618,45 @@
$content[‘date’] = $this->date ? $this->date : egw_time();
$owners = $this->owner ? is_array($this->owner) ? array($this->owner) : explode(’,’,$this->owner) : array($GLOBALS[‘egw_info’][‘user’][‘account_id’]);
$sel_options = array();
// Get user accounts, formatted nicely for grouping and matching
// the ajax call calendar_uiforms->ajax_owner()
$account_options = array('account_type' => 'both');
$accounts = accounts::link_query('',$account_options);
$sel_options['owner'] = array_map(
function($account_id, $account_name) {
return array(
'value' => $account_id,
'label' => $account_name,
'app' => lang('home-accounts')
array_keys($accounts), $accounts
// Add external owners that a select account widget will not find
$linked_owners = array();
foreach($owners as &$owner)
$owner = ''.$owner;
if(!is_numeric($owner))
$resource = $this->bo->resources[substr($owner, 0,1)];
$label = egw_link::title($resource['app'], substr($owner,1));
$linked_owners[$resource['app']][substr($owner,1)] = $label;
else if (!in_array($owner, array_keys($accounts)))
$label = egw_link::title('home-accounts',$owner);
$resource = array('app'=> 'home-accounts');
else
continue;
$sel_options['owner'][] = array('value' => $owner, 'label' => $label, 'app' => lang($resource['app']));
if($linked_owners)
— trunk/calendar/inc/class.calendar_uiforms.inc.php (original)
+++ trunk/calendar/inc/class.calendar_uiforms.inc.php Tue Feb 9 21:28:57 2016
@@ -2942,6 +2942,59 @@
- Handle ajax searches for owner across all supported resources
@return Array List of matching results
- public function ajax_owner()
$query = $_REQUEST['query'];
$options = ['num_rows' => 100];
$results = [];
if($query)
foreach($this->bo->resources as $type => $data)
$mapped = array();
if ($data['app'] && egw_link::get_registry($data['app'], 'query'))
$_results = egw_link::query($data['app'], $query,$options);
if(!$_results) continue;
$r_results = array_unique($_results);
foreach($_results as $id => $title)
if($id && $title)
// Magicsuggest uses id, not value.
$value = [
'id' => $type.$id,
'value'=> $type.$id,
'label' => $title,
'app' => lang($data['app'])
if(is_array($value['label']))
$value = array_merge($value, $value['label']);
$mapped[] = $value;
if(count($mapped))
$results = array_merge($results, $mapped);
// switch regular JSON response handling off
egw_json_request::isJSONRequest(false);
header('Content-Type: application/json; charset=utf-8');
echo json_encode($results);
common::egw_exit();
- imports a mail as Calendar
@param array $mailContent = null mail content
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Tue Feb 9 21:28:57 2016
@@ -12,6 +12,7 @@
/*egw:uses
/etemplate/js/etemplate2.js;
- /calendar/js/et2_widget_owner.js;
/calendar/js/et2_widget_timegrid.js;
/calendar/js/et2_widget_planner.js;
@@ -1972,13 +1973,6 @@
state.state.owner[state.state.owner.indexOf(‘0’)] = this.egw.user(‘account_id’);
if(state.state.owner.length === 1 && this.sidebox_et2)
// If only one owner selected, go back to single select
var owner = this.sidebox_et2.getWidgetById('owner');
owner.set_multiple(false);
// Show the correct number of grids
var grid_count = 0;
@@ -2747,6 +2741,10 @@
if(!found)
if(!widget.options.select_options.push)
widget.options.select_options = [];
widget.options.select_options.push(option);
@@ -2884,7 +2882,7 @@
for(var day in updated_days)
// Might be split by user, so we have to check that too
@@ -3247,6 +3245,14 @@
button.parent().css(‘margin-right’,button.outerWidth(true)+2);
button.parent().parent().css(‘white-space’,‘nowrap’);
$j(window).on('resize.calendar-owner', function() {
var preferred_width = $j('#calendar-et2_target').children().first().outerWidth()||0;
var owner = app.calendar.sidebox_et2.getWidgetById('owner');
if(preferred_width && owner.input.hasClass("chzn-done"))
owner.input.next().css('width',preferred_width);
— trunk/calendar/js/et2_widget_owner.js (added)
+++ trunk/calendar/js/et2_widget_owner.js Tue Feb 9 21:28:57 2016
@@ -1,0 +1,59 @@
+“use strict”;
+/*egw:uses
- Tag list widget customised for calendar owner, which can be a user
- account or group, or an entry from almost any app, or an email address
- A cross between auto complete, selectbox and chosen multiselect
- Uses MagicSuggest library
+var et2_calendar_owner = et2_taglist_email.extend(
- attributes: {
"autocomplete_url": {
"default": "calendar.calendar_uiforms.ajax_owner.etemplate"
"autocomplete_params": {
"name": "Autocomplete parameters",
"type": "any",
"default": {},
"description": "Extra parameters passed to autocomplete URL. It should be a stringified JSON object."
allowFreeEntries: {
"default": false,
ignore: true
select_options: {
"type": "any",
"name": "Select options",
// Set to empty object to use selectbox's option finding
"default": {},
"description": "Internaly used to hold the select options."
- // Allows sub-widgets to override options to the library
- lib_options: {
groupBy: 'app',
expandOnFocus: true
+et2_register_widget(et2_calendar_owner, [“calendar_owner”]);
— trunk/calendar/templates/default/sidebox.xet (original)
+++ trunk/calendar/templates/default/sidebox.xet Tue Feb 9 21:28:57 2016
@@ -27,7 +27,7 @@
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Tue Feb 9 21:28:57 2016
@@ -11,7 +11,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 54928 2016-02-04 23:14:54Z nathangray $ /
+/ $Id: app.css 54941 2016-02-05 18:17:47Z nathangray $ */
/Media print classes/
@media print {
.th td,
eGroupWare-cvs mailing list
