<hbox>
<description value="Start"/>
<date id="startdate" onchange="app.calendar.update_state({date: widget.getValue()}); return false;"/>
<description value="End"/>
<date id="enddate" onchange="app.calendar.update_state({end_date: widget.getValue()}); return false;"/>
</hbox>
<grid width="100%" >
<columns>
<column width="10"/>
<column width="95%" />
<column width="80"/>
</columns>
<rows>
<row class="th">
</row>
<row class="$row_cont[class]" valign="top">
<description class=" cat_$row_cont[cat_id] mobile_cat_col"/>
<vbox class="calendar_fullWidth">
<hbox class="calTitleRow">
<description id="${row}[title]" no_lang="1" class="$row_cont[sub_class] et2_ellipsis" overflow="hidden" width="100%" />
</hbox>
<box class="calDescRow">
<description id="${row}[description]" no_lang="1" activate_links="1"/>
</box>
</vbox>
<vbox class="calDates">
<date-time id="${row}[start]" readonly="true" options=",$cont[format]" class="noWrap"/>
<date-time id="${row}[end]" readonly="true" options=",$cont[format]" class="noWrap"/>
</vbox>
</row>
</rows>
</grid>
<grid width="100%" border="0" spacing="0" padding="0">
<columns>
<column width="70%"/>
<column/>
</columns>
<rows>
<row disabled="!@css">
<html id="css" span="all"/>
</row>
<row>
<description align="center" id="msg" no_lang="1" span="all" class="message"/>
</row>
<row disabled="1">
<template id="dates"/>
</row>
<row>
<description id="plus_button_container"/>
</row>
<row>
<nextmatch id="nm" template="calendar.list.rows" header_left="calendar.list.dates" span="all"/>
</row>
<row>
<hbox>
<box class="action_popup prompt" id="delete_popup">
<vbox>
<description value="Delete" class="promptheader"/>
<description value="This is a recurring event. Do you want to delete just this recurrence or the whole series?"/>
<hbox>
<button label="Delete this recurrence" id="delete" onclick="nm_submit_popup(this); return false;"/>
<button label="Delete series" id="delete_series" onclick="nm_popup_action.id = 'delete_series'; nm_submit_popup(this); return false;"/>
<buttononly label="Cancel" onclick="nm_hide_popup(this,'delete_popup');"/>
</hbox>
</vbox>
</box>
<box class="action_popup prompt" id="undelete_popup">
<vbox>
<description value="Un-delete" class="promptheader"/>
<description value="This is a recurring event. Do you want to Un-delete just this recurrence or the whole series?"/>
<hbox>
<button label="Un-delete this recurrence" id="undelete" onclick="nm_submit_popup(this); return false;"/>
<button label="Un-delete series" id="undelete_series" onclick="nm_popup_action.id = 'undelete_series'; nm_submit_popup(this); return false;"/>
<buttononly label="Cancel" onclick="nm_hide_popup(this,'undelete_popup');"/>
</hbox>
</vbox>
</box>
</hbox>
<description/>
</row>
</rows>
</grid>
<styles>
.noWrap { white-space: nowrap; }
<grid width="100%">
<columns>
<column width="120"/>
<column width="600"/>
</columns>
<rows>
<row>
<description for="ident_id" value="Identity"/>
<menulist>
<menupopup id="ident_id" no_lang="1" onchange="1" class="et2_fullWidth"/>
</menulist>
</row>
<row>
<description/>
<checkbox label="allow users to create further identities" id="acc_further_identities" class="emailadmin_no_user"/>
</row>
<row>
<description for="ident_name" value="Name"/>
<textbox id="ident_name" maxlength="128" blur="default your name and email" class="et2_fullWidth"/>
</row>
<row>
<description for="ident_realname" value="Your name"/>
<hbox>
<textbox id="ident_realname" maxlength="128" width="96%"/>
<buttononly label="Placeholders" id="button[placeholders]" onclick="window.open(egw::link('/index.php','menuaction=addressbook.addressbook_merge.show_replacements&nonavbar=1'),'_blank','dependent=yes,width=860,height=620,scrollbars=yes,status=yes'); return false;" options="dialog_help"/>
</hbox>
</row>
<row>
<description for="ident_org" value="Organisation"/>
<textbox id="ident_org" maxlength="128" span="all" class="et2_fullWidth"/>
</row>
<row>
<description for="ident_email" value="EMail address"/>
<url-email id="ident_email" options="80,128" width="96%"/>
</row>
<row>
<htmlarea expand_toolbar="false" height="125px" id="ident_signature" span="all" width="100%"/>
</row>
</rows>
</grid>
<grid width="100%">
<columns>
</columns>
<rows>
<row class="emailadmin_no_single">
<description for="acc_imap_logintype" value="Type"/>
<menulist>
<menupopup id="acc_imap_type" class="et2_fullWidth"/>
</menulist>
</row>
<description for="acc_imap_logintype" value="Login" class="emailadmin_no_single"/>
<menulist>
<menupopup class="emailadmin_no_single et2_fullWidth" statustext="How username get constructed" id="acc_imap_logintype"/>
</menulist>
</row>
<row class="@manual_class">
<description for="acc_imap_username" value="Username"/>
<textbox id="acc_imap_username" maxlength="128" autocomplete="off" class="et2_fullWidth"/>
</row>
<description for="acc_domain" value="Domain" class="emailadmin_no_single"/>
<textbox id="acc_domain" maxlength="128" class="emailadmin_no_single et2_fullWidth"/>
</row>
<row>
<description for="acc_imap_password" value="Password"/>
<hbox>
<passwd id="acc_imap_password" maxlength="128" autocomplete="off" width="96%"/>
<description id="acc_imap_account_id" class="emailadmin_diagnostic"/>
</hbox>
</row>
<description for="acc_imap_host" value="IMAP server"/>
<textbox blur="Hostname or IP" id="acc_imap_host" maxlength="128" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_imap_ssl" value="Secure connection"/>
<hbox>
<menulist>
<menupopup class="emailadmin_ssl" id="acc_imap_ssl" needed="1" onchange="app.emailadmin.wizard_imap_ssl_onchange" width="30%"/>
</menulist>
<textbox type="integer" label="Port" id="acc_imap_port" needed="1" class="emailadmin_port"/>
</hbox>
</row>
<groupbox span="all" class="emailadmin_imap_admin">
<caption label="IMAP administration"/>
<grid>
<columns>
</columns>
<rows>
<row>
<description for="acc_imap_admin_username" value="Admin user"/>
<textbox id="acc_imap_admin_username" maxlength="128" autocomplete="off" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_imap_admin_password" value="Password"/>
<passwd id="acc_imap_admin_password" maxlength="128" autocomplete="off" class="et2_fullWidth"/>
</row>
</rows>
</grid>
</groupbox>
</row>
</rows>
</grid>
<grid width="100%">
<columns>
</columns>
<rows>
<row>
<description for="acc_folder_sent" value="Sent folder"/>
<taglist id="acc_folder_sent" empty_label="Select one ..." maxSelection="1" autocomplete_url="" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_folder_trash" value="Trash folder"/>
<taglist id="acc_folder_trash" empty_label="Select one ..." maxSelection="1" autocomplete_url="" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_folder_draft" value="Drafts folder"/>
<taglist id="acc_folder_draft" empty_label="Select one ..." maxSelection="1" autocomplete_url="" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_folder_template" value="Templates folder"/>
<taglist id="acc_folder_template" empty_label="Select one ..." maxSelection="1" autocomplete_url="" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_folder_junk" value="Junk folder"/>
<taglist id="acc_folder_junk" empty_label="Select one ..." maxSelection="1" autocomplete_url="" class="et2_fullWidth"/>
</row>
<row>
<description for="acc_folder_junk" value="Notify about new mail in this folders"/>
<vbox>
<taglist id="notify_folders" empty_label="Select one ..." autocomplete_url="" onchange="app.emailadmin.change_folders" class="et2_fullWidth"/>
<checkbox id="notify_save_default" label="save as default"/>
<checkbox id="notify_use_default" label="use default"/>
</vbox>
</row>
</rows>
</grid>
<grid width="100%">
<columns>
</columns>
<rows>
<row>
<description for="acc_sieve_enabled" value="Enable Sieve"/>
<menulist>
<menupopup type="select-bool" id="acc_sieve_enabled" needed="1" class="et2_fullWidth"/>
</menulist>
</row>
<description for="acc_sieve_host" value="Sieve server"/>
<textbox blur="Hostname or IP" id="acc_sieve_host" onchange="app.emailadmin.wizard_sieve_onchange" maxlength="128" class="et2_fullWidth"/>
</row>
<description for="acc_sieve_ssl" value="Secure connection"/>
<hbox>
<menulist>
<menupopup class="emailadmin_ssl" id="acc_sieve_ssl" onchange="app.emailadmin.wizard_sieve_ssl_onchange" width="30%"/>
</menulist>
<textbox type="integer" label="Port" id="acc_sieve_port" onchange="app.emailadmin.wizard_sieve_onchange" class="emailadmin_port"/>
</hbox>
</row>
<row>
<description value="Vacation messages with start and end date require an admin account to be set!" span="all" class="emailadmin_no_single"/>
</row>
</rows>
</grid>
<grid width="100%">
<columns>
</columns>
<rows>
<description for="acc_smtp_type" value="Type"/>
<menulist>
<menupopup id="acc_smtp_type" onchange="1" class="et2_fullWidth"/>
</menulist>
</row>
<description for="acc_smtp_auth_session" value="Authentication"/>
<checkbox label="Use username+password from current user" id="acc_smtp_auth_session"/>
</row>
<description for="acc_smtp_username" value="Username"/>
<textbox blur="if authentication required" id="acc_smtp_username" maxlength="128" autocomplete="off" class="et2_fullWidth"/>
</row>
<description for="acc_smtp_password" value="Password"/>
<hbox>
<passwd id="acc_smtp_password" maxlength="128" autocomplete="off" class="et2_fullWidth"/>
<description id="acc_smtp_account_id" class="emailadmin_diagnostic"/>
</hbox>
</row>
<description for="acc_smtp_host" value="SMTP server"/>
<textbox blur="Hostname or IP" id="acc_smtp_host" needed="1" maxlength="128" class="et2_fullWidth"/>
</row>
<description for="acc_smtp_ssl" value="Secure connection"/>
<hbox>
<menulist>
<menupopup class="emailadmin_ssl" id="acc_smtp_ssl" needed="1" onchange="app.emailadmin.wizard_smtp_ssl_onchange" width="30%"/>
</menulist>
<textbox type="integer" label="Port" id="acc_smtp_port" needed="1" class="emailadmin_port"/>
</hbox>
</row>
</rows>
</grid>
<grid width="100%">
<columns>
</columns>
<rows>
<row>
<description for="mailLocalAddress" value="EMail address"/>
<url-email id="mailLocalAddress" options="32,128" class="et2_fullWidth"/>
</row>
<row>
<description/>
<checkbox label="Email account active" id="accountStatus" selected_value="active"/>
</row>
<row>
<description for="mailAlternateAddress" value="Alternate email address"/>
<taglist id="mailAlternateAddress" autocomplete_url="" class="et2_fullWidth"/>
</row>
<row disabled="@no_forward_available">
<description for="mailForwardingAddress" value="Forward email's to"/>
<taglist id="mailForwardingAddress" autocomplete_url="" class="et2_fullWidth"/>
</row>
<description/>
<vbox>
<checkbox label="Forward only" id="deliveryMode" selected_value="forwardOnly" onchange="if (widget.getValue()) et2_dialog.alert('Forward only disables IMAP mailbox / storing of mails and just forwards them to given address.','Forward only');"/>
<checkbox label="Allow users to change forwards" id="acc_user_forward"/>
</vbox>
</row>
<row>
<description for="quotaLimit" value="Quota (MB)"/>
<hbox>
<textbox type="integer" id="quotaLimit"/>
<description value="Leave empty for no quota"/>
</hbox>
</row>
<row>
<description for="quotaUsed" value="Currently:"/>
<textbox type="integer" id="quotaUsed" readonly="true"/>
</row>
<row disabled="!@admin_actions">
<description value="Administration"/>
<description/>
</row>
<toolbar id="admin_actions" colspan="2" default_execute="app.emailadmin.account_edit_action"/>
</row>
</rows>
</grid>
<grid width="100%">
<columns>
</columns>
<rows>
<row disabled="@hidebuttons" class="dialogHeadbar" >
<hbox span="all">
<button label="Save" id="button[save]"/>
<button label="Apply" id="button[apply]" />
<button statustext="Use wizard to detect or verify configuration" label="Wizard" id="button[wizard]" image="magicwand" background_image="1"/>
<button align="right" label="Delete" id="button[delete]" onclick="et2_dialog.confirm(widget,'Delete this account','Delete')"/>
<button align="right" label="Delete identity" id="button[delete_identity]" onclick="et2_dialog.confirm(widget,'Delete identity','Delete')" image="delete" background_image="1"/>
</hbox>
</row>
<row disabled="!@accounts" class="dialogHeader">
<description for="acc_id" value="Mail account"/>
<menulist>
<menupopup id="acc_id" onchange="app.emailadmin.change_account" class="et2_fullWidth"/>
</menulist>
<description/>
</row>
<row>
<description for="acc_name" value="Name of account"/>
<hbox>
<textbox id="acc_name" needed="1" class="et2_fullWidth"/>
<description align="right" value="$cont[acc_id]" class="emailadmin_diagnostic"/>
</hbox>
</row>
<row class="emailadmin_no_user">
<description for="account_id" value="Valid for"/>
<hbox>
<menulist>
<menupopup type="select-account" id="account_id" onchange="app.emailadmin.account_hide_not_applying" options="Everyone,both" width="96%"/>
</menulist>
<buttononly label="Select multiple" id="button[multiple]" onclick="app.emailadmin.edit_multiple" options="users"/>
</hbox>
</row>
<row>
<description/>
<checkbox label="account editable by user" id="acc_user_editable"/>
</row>
<row>
<tabbox id="tabs" span="all" width="100%" align_tabs="v">
<tabs>
<tab id="emailadmin.account.identity" label="Identity+Signature" statustext="Identity&Signature"/>
<tab id="emailadmin.account.imap" label="IMAP" statustext="incoming mail"/>
<tab id="emailadmin.account.folder" label="Folder" statustext="Folder"/>
<tab id="emailadmin.account.sieve" label="Sieve" statustext="serverside filtering"/>
<tab id="emailadmin.account.smtp" label="SMTP" statustext="outgoing mail"/>
<tab id="emailadmin.account.aliases" label="Aliases+Forwards" statustext="Aliases, Forwarding, Quota, ..."/>
</tabs>
<tabpanels>
<template id="emailadmin.account.identity"/>
<template id="emailadmin.account.imap"/>
<template id="emailadmin.account.folder"/>
<template id="emailadmin.account.sieve"/>
<template id="emailadmin.account.smtp"/>
<template id="emailadmin.account.aliases"/>
</tabpanels>
</tabbox>
</row>
</rows>
</grid>
