Author: hnategh
New Revision: 55031
URL: http://svn.stylite.de/viewvc/egroupware?rev=55031&view=rev
Mobile theme W.I.P.:
-Fix nm header
trunk/etemplate/js/et2_extension_nextmatch.js
trunk/pixelegg/css/mobile.css
trunk/pixelegg/css/mobile.less
— trunk/etemplate/js/et2_extension_nextmatch.js (original)
+++ trunk/etemplate/js/et2_extension_nextmatch.js Tue Feb 16 19:00:05 2016
@@ -2281,6 +2281,7 @@
.addClass(“nextmatch_header_row”)
.appendTo(this.div);
this.filter_div = jQuery(document.createElement(“div”))
— trunk/pixelegg/css/mobile.css (original)
+++ trunk/pixelegg/css/mobile.css Tue Feb 16 19:00:05 2016
@@ -584,19 +584,19 @@
div.header_row_right div[id$=favorite_wrapper] {
margin-top: 0px;
- top: 6px;
.et2_nextmatch {
background-color: transparent;
.et2_nextmatch .nextmatch_header {
- padding: 5px;
- padding: 0;
border: none;
background-image: none;
.et2_nextmatch .nextmatch_header_row {
padding-bottom: 6px;
- width: 100%;
.et2_nextmatch > img {
width: 16px;
@@ -707,94 +707,6 @@
-* Search Field
- .nextmatch_header_row > .search {
- padding: 0 0 0 0px;
- margin-right: 15px;
- margin-left: 15px;
- width: 200px;
- z-index: 100;
- white-space: nowrap;
- /.background_color_search;/
- /.border_radius_button_righttop;/
- .nextmatch_header_row > .search input {
- /background-color: @gray_0;/
- font-size: 11px;
- color: #000000;
- padding: 3px;
- width: 150px;
- border-color: #696969;
- border-right: none;
- .nextmatch_header_row > .search input::-webkit-input-placeholder {
- /* WebKit browsers */
- color: #696969;
- .nextmatch_header_row > .search input:-moz-placeholder {
- /* Mozilla Firefox 4 to 18 */
- color: #696969;
- .nextmatch_header_row > .search input::-moz-placeholder {
- /* Mozilla Firefox 19+ */
- color: #696969;
- .nextmatch_header_row > .search input:-ms-input-placeholder {
- /* Internet Explorer 10+ */
- color: #696969;
- .nextmatch_header_row > .search button.et2_button {
- border: 1px solid rgba(0, 0, 0, 0.15);
- border-color: #b4b4b4;
- -webkit-box-shadow: 1px 1px 1px rgba(0, 0, 0, 0.9);
- -moz-box-shadow: 1px 1px 1px rgba(0, 0, 0, 0.9);
- box-shadow: 1px 1px 1px rgba(0, 0, 0, 0.9);
- width: 45px;
- -webkit-border-radius: 3px;
- -webkit-border-top-right-radius: 20px;
- -moz-border-radius: 3px;
- -moz-border-radius-topright: 20px;
- border-radius: 3px;
- border-top-right-radius: 20px;
- /cursor: pointer; 14022014 entfernt/
- padding: 0px;
- margin: 8px 10px;
- margin-left: 0px;
- background-image: url("…/images/search.png");
- background-position: center 0;
- background-size: contain;
- background-repeat: no-repeat;
- text-indent: 110%;
- overflow: hidden;
- .nextmatch_header_row > .search button.et2_button:hover {
- -webkit-box-shadow: 1px 1px 1px rgba(0, 0, 0, 0.6);
- -moz-box-shadow: 1px 1px 1px rgba(0, 0, 0, 0.6);
- box-shadow: 1px 1px 1px rgba(0, 0, 0, 0.6);
- background-color: #679fd2 !important;
- /hide arrow/
- color: #679fd2 !important;
- .nextmatch_header_row > .search button.et2_button:active {
- /.background_verlauf_diagonal_gray;/
- background-color: #1aa200 !important;
- .nextmatch_header_row > .search button.et2_button:focus {
- outline: 0;
- border-width: 1px;
- border-style: solid;
- -webkit-box-shadow: 0 0 2px 1px rgba(0, 0, 0, 0.1);
- -moz-box-shadow: 0 0 2px 1px rgba(0, 0, 0, 0.1);
- box-shadow: 0 0 2px 1px rgba(0, 0, 0, 0.1);
- /background-color: @color_positive_action_active !important;/
@@ -931,13 +843,12 @@
.nextmatch_header .header_count {
position: relative;
- top: 0;
height: 22px;
height: 24px;
border: 1px solid #E0E0E0;
float: right;
- margin: 6px 5px 0 10px;
- padding: 0 20px;
- padding: 0 10px;
text-align: center;
font-size: 11px;
@@ -5829,7 +5740,7 @@
table.egwGridView_outer thead tr th {
background-position: -200px;
- font-weight: normal;
padding: 3px 0 3px 4px;
border-left: 0px solid transparent;
@@ -5838,8 +5749,7 @@
border-bottom: 0px solid transparent;
vertical-align: middle;
overflow: auto;
- border-top-right-radius: 23px;
- border-radius: 5px;
table.egwGridView_outer thead tr th:hover {
background-color: #bfbfbf;
@@ -5875,7 +5785,7 @@
background-color: #ffffff;
table.egwGridView_outer thead tr th.optcol:hover {
- background-color: #189800;
- cursor: pointer;
table.egwGridView_outer thead tr th.optcol span.selectcols {
height: 9px;
@@ -5885,9 +5795,6 @@
background-size: 10px 10px;
display: inline-block;
-table.egwGridView_outer thead tr th.optcol span.selectcols:hover {
table.egwGridView_outer > tbody > tr {
/Elements inside td/
@@ -7648,6 +7555,17 @@
body .et2_nextmatch .nextmatch_header {
background-color: background-color-egw-dark;
- body .et2_nextmatch .nextmatch_header_row div.header_row_right,
- body .et2_nextmatch .nextmatch_header div.header_row_right {
- position: absolute;
- display: block;
- top: 0;
- body .et2_nextmatch .nextmatch_header_row div.filtersContainer,
- body .et2_nextmatch .nextmatch_header div.filtersContainer {
- width: 100%;
- margin-top: 37px;
body .et2_nextmatch .nextmatch_header_row select,
body .et2_nextmatch .nextmatch_header select {
display: block;
@@ -7661,6 +7579,7 @@
border-bottom: none;
padding-left: 10px;
max-width: none;
- background-color: transparent;
body .et2_nextmatch .nextmatch_header_row label,
body .et2_nextmatch .nextmatch_header label {
@@ -7909,13 +7828,15 @@
body .et2_nextmatch .header_count {
margin: 0;
height: 50px;
- font-size: 12pt;
margin-top: -3px;
margin-right: 0px;
float: right;
border: none;
border-radius: 0;
- border-left: 1px solid rgba(0, 0, 0, 0.15);
- body .et2_nextmatch .header_count span {
- font-size: 12pt;
body .et2_nextmatch table.egwGridView_grid tr div.h2_hbox {
padding-bottom: 4px;
— trunk/pixelegg/css/mobile.less (original)
+++ trunk/pixelegg/css/mobile.less Tue Feb 16 19:00:05 2016
@@ -1164,6 +1164,15 @@
.et2_nextmatch {
.nextmatch_header_row, .nextmatch_header
@@ -1178,6 +1187,7 @@
padding-left:10px;
max-width:none;
@@ -1446,16 +1456,18 @@
eGroupWare-cvs mailing list
