Author: nathangray
New Revision: 55035
URL: http://svn.stylite.de/viewvc/egroupware?rev=55035&view=rev
Some more taglist changes
- Styled to look like selectbox with tags
- Start server search with 2+ chars on enter, even if there is a local match
- Fire change on change again, not blur, for less confusion
trunk/calendar/js/et2_widget_owner.js
trunk/calendar/templates/default/app.css
trunk/etemplate/js/et2_widget_taglist.js
trunk/etemplate/templates/default/etemplate2.css
trunk/pixelegg/css/mobile.css
trunk/pixelegg/css/pixelegg.css
trunk/pixelegg/less/etemplate2.less
trunk/pixelegg/less/magicsuggest.css
trunk/pixelegg/less/magicsuggest.less
— trunk/calendar/js/et2_widget_owner.js (original)
+++ trunk/calendar/js/et2_widget_owner.js Tue Feb 16 22:37:19 2016
@@ -52,8 +52,10 @@
// Allows sub-widgets to override options to the library
lib_options: {
autoSelect: false,
groupBy: 'app',
minChars: 2,
selectFirst: true,
// This option will also expand when the selection is changed
// via code, which we do not want
//expandOnFocus: true
@@ -67,20 +69,18 @@
var widget = this;
// onChange fired when losing focus, which is different from normal
this._oldValue = this.taglist.getValue();
this.$taglist
.on('focus', function() {widget.taglist.expand();})
// Since not using autoSelect, avoid some errors with selection starting
// with the group
.on('load expand', function() {
window.setTimeout(function() {
widget.div.find('.ms-res-item-active')
.removeClass('ms-res-item-active');
},1);
if(this.options.onchange && typeof this.onchange === 'function')
$j(this.taglist).on("blur", function() {
if(widget._oldValue.toString() !== widget.taglist.getValue().toString())
widget.onchange.call(widget, arguments);
widget._oldValue = widget.taglist.getValue();
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Tue Feb 16 22:37:19 2016
@@ -88,6 +88,10 @@
#calendar-sidebox_date .calendar_calHoliday a {
background-color: rgba(103, 159, 210, 0.5);
+#calendar-sidebox_owner .ms-helper {
- padding: 2px;
- background-color: white;
/* Toolbar */
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Tue Feb 16 22:37:19 2016
@@ -101,6 +101,10 @@
- padding: 2px;
/* Toolbar */
#calendar-toolbar {
— trunk/etemplate/js/et2_widget_taglist.js (original)
+++ trunk/etemplate/js/et2_widget_taglist.js Tue Feb 16 22:37:19 2016
@@ -168,7 +168,7 @@
// MagicSuggest would replaces our div, so add a wrapper instead
this.taglist = $j(’
’).appendTo(this.div);
@@ -194,7 +194,8 @@
highlight: false, // otherwise renderer have to return strings,
value: this.options.value
}, this.lib_options);
this.taglist = this.taglist.magicSuggest(this.taglist_options);
this.$taglist = $j(this.taglist);
// AJAX _and_ select options - use custom function
if(this.options.autocomplete_url && !jQuery.isEmptyObject(this.options.select_options))
@@ -206,11 +207,13 @@
// Display / hide a loading icon while fetching
this.$taglist
.on("beforeload", function() {this.container.prepend('<div class="ui-icon loading"/>');})
.on("load", function() {$j('.loading',this.container).remove();})
// Keep focus when selecting from the list
.on("selectionchange", function() { $j('input',this.container).focus();})
// Bind keyup so we can start ajax search when we like
.on('keyup.start_search', jQuery.proxy(this._keyup, this));
// Unbind change handler of widget's ancestor to stop it from bubbling
// taglist has its own onchange
@@ -219,7 +222,7 @@
// onChange
if(this.options.onchange && typeof this.onchange === ‘function’)
@@ -236,7 +239,7 @@
if (typeof this.onfocus == ‘function’)
var widget = this;
@@ -276,12 +279,12 @@
* @returns {Array}
_data: function(query) {
if(query.trim() ==='' || !this.options.autocomplete_url)
// No server - let magicsuggest handle options
return this.options.select_options;
if (!jQuery.isEmptyObject(this.options.select_options))
var return_value = this.options.select_options || {};
if (!jQuery.isEmptyObject(this.options.select_options) && !this._query_server
|| query.trim().length < this.taglist_options.minChars
// Check options, if there's a match there (that is not already
// selected), do not ask server
@@ -294,12 +297,34 @@
filtered.push(obj);
return_value = filtered.length > 0 ? filtered : this.options.autocomplete_url
else if (query.trim().length >= this.taglist_options.minChars || this._query_server)
// No options - ask server
return this.options.autocomplete_url;
this._query_server = false;
return return_value;
- Handler for keyup, used to start ajax search when we like
- _keyup: function(e, taglist, event) {
if(event.which === jQuery.ui.keyCode.ENTER)
this._query_server = true;
this.taglist.collapse();
this.taglist.expand();
this.div.find('.ms-res-item-active')
event.preventDefault();
return false;
— trunk/etemplate/templates/default/etemplate2.css (original)
+++ trunk/etemplate/templates/default/etemplate2.css Tue Feb 16 22:37:19 2016
@@ -1542,7 +1542,15 @@
margin: 0px auto -16px auto;
top: 5px;
-.ms-res-ctn {
+.et2_taglist div.ms-sel-ctn .ms-close-btn {
- width: 10px;
- height: 10px;
- background-position-y: -10px;
- background-size: cover;
- background-repeat: no-repeat;
- margin: 2px -16px 0 10px;
+.et2_taglist .ms-res-ctn {
position:absolute;
background: #FFF;
overflow-y: auto;
@@ -1558,15 +1566,40 @@
border-top: 0;
border-top-left-radius: 0;
border-top-right-radius: 0;
-div.ms-sel-ctn {
- padding: 1px 0px;
+.et2_taglist div.ms-sel-ctn {
padding-right: 0px;
-div.ms-sel-ctn .ms-sel-item {
+.et2_taglist div.ms-sel-ctn .ms-sel-item {
- margin: 0px 5px 3px 0px;
- padding: 3px 20px 3px 5px;
- border: 1px solid #aaa;
- border-radius: 3px;
- background-color: #e4e4e4;
- background-image: -webkit-gradient(linear, 50% 0%, 50% 100%, color-stop(20%, #f4f4f4), color-stop(50%, #f0f0f0), color-stop(52%, #e8e8e8), color-stop(100%, #eeeeee));
- background-image: -webkit-linear-gradient(#f4f4f4 20%, #f0f0f0 50%, #e8e8e8 52%, #eeeeee 100%);
- background-image: -moz-linear-gradient(#f4f4f4 20%, #f0f0f0 50%, #e8e8e8 52%, #eeeeee 100%);
- background-image: -o-linear-gradient(#f4f4f4 20%, #f0f0f0 50%, #e8e8e8 52%, #eeeeee 100%);
- background-image: linear-gradient(#f4f4f4 20%, #f0f0f0 50%, #e8e8e8 52%, #eeeeee 100%);
- background-clip: padding-box;
- box-shadow: 0 0 2px white inset, 0 1px 0 rgba(0, 0, 0, 0.05);
- color: #333;
- line-height: 13px;
- font-size: 11px;
- cursor: default;
word-break: break-all;
-.ms-ctn input:focus {
+.et2_taglist div.ms-ctn input {
- padding: 3px 5px;
+.et2_taglist div.ms-ctn input:focus {
min-width: 10em;
+.et2_taglist .ms-res-ctn .ms-res-item {
- padding: 3px 6px;
— trunk/pixelegg/css/mobile.css (original)
+++ trunk/pixelegg/css/mobile.css Tue Feb 16 22:37:19 2016
@@ -1137,19 +1137,6 @@
- .ms-ctn,
- .ms-res-ctn {
- /* It doesn’t really work smaller than this */
- min-width: 150px;
- .ms-ctn .loading {
- position: relative;
- margin: 0px auto -16px auto;
- top: 5px;
- .ms-res-ctn {
- overflow-x: hidden;
- et2_toolbar
@@ -1713,233 +1700,6 @@
@package pixelegg
@version $Id$
-div.ms-ctn {
- height: auto;
- padding: 0;
- margin-bottom: 0px;
- font-size: 14px;
- line-height: 20px;
- color: #555555;
- -webkit-border-radius: 3px;
- -moz-border-radius: 3px;
- background-color: #ffffff;
- border: 1px solid #cccccc;
- -webkit-box-shadow: inset 0 1px 1px rgba(0, 0, 0, 0.075);
- -moz-box-shadow: inset 0 1px 1px rgba(0, 0, 0, 0.075);
- box-shadow: inset 0 1px 1px rgba(0, 0, 0, 0.075);
- -webkit-transition: border linear 0.2s, box-shadow linear 0.2s;
- -moz-transition: border linear 0.2s, box-shadow linear 0.2s;
- -o-transition: border linear 0.2s, box-shadow linear 0.2s;
- transition: border linear 0.2s, box-shadow linear 0.2s;
- cursor: default;
- display: block;
-input.ms-inv {
- border: 1px solid #CC0000;
-div.ms-ctn-readonly {
- cursor: pointer;
-div.ms-ctn-disabled {
- cursor: not-allowed;
- background-color: #eeeeee;
-div.ms-ctn input {
- border: 0;
- box-shadow: none;
- -webkit-transition: none;
- outline: none;
- display: block;
- padding: 4px 6px;
- line-height: normal;
- overflow: hidden;
- height: auto;
- border-radius: 0;
- float: none;
- margin: 2px 0 2px 2px;
-div.ms-ctn-disabled input {
-div.ms-ctn .ms-input-readonly {
- cursor: pointer;
-div.ms-ctn .ms-empty-text {
- color: #DDD;
-div.ms-ctn input:focus {
- border: 0;
- box-shadow: none;
- background: #FFF;
-div.ms-ctn .ms-trigger {
- float: right;
- width: 27px;
- height: 28px;
- border-left: 1px solid #CCC;
- background: #EEE;
- cursor: pointer;
-div.ms-ctn .ms-trigger .ms-trigger-ico {
- display: inline-block;
- width: 0;
- height: 0;
- vertical-align: top;
- border-top: 4px solid gray;
- border-right: 4px solid transparent;
- border-left: 4px solid transparent;
- content: “”;
- margin-left: 9px;
- margin-top: 13px;
-div.ms-ctn .ms-trigger:hover {
- background: -moz-linear-gradient(100% 100% 90deg, #e3e3e3, #f1f1f1);
- background: -webkit-gradient(linear, 0% 0%, 0% 100%, from(#f1f1f1), to(#e3e3e3));
-div.ms-ctn .ms-trigger:hover .ms-trigger-ico {
- background-position: 0 -4px;
-div.ms-ctn-disabled .ms-trigger {
-div.ms-ctn-bootstrap-focus {
- border-bottom: 1px solid #CCC;
-div.ms-res-ctn {
-div.ms-res-ctn .ms-res-group {
- line-height: 23px;
- text-align: left;
- padding: 2px 5px;
- font-weight: bold;
- border-bottom: 1px dotted #CCC;
- border-top: 1px solid #CCC;
- background: #f3edff;
- color: #333;
-div.ms-res-ctn .ms-res-item {
- line-height: 25px;
- text-align: left;
- padding: 2px 5px;
- color: #666;
- cursor: pointer;
-div.ms-res-ctn .ms-res-item-grouped {
- padding-left: 15px;
-div.ms-res-ctn .ms-res-odd {
- background: #F3F3F3;
-div.ms-res-ctn .ms-res-item-active {
- background-color: #3875D7;
- color: #fff;
-div.ms-sel-ctn {
- overflow: auto;
- line-height: 22px;
- padding-right: 0px;
- background: #555;
- color: #EEE;
- float: left;
- font-size: 12px;
- padding: 0 15px 0 4px !important;
- margin-left: 5px;
- margin-top: 4px;
-div.ms-sel-ctn .ms-sel-text {
- background: #FFF;
- color: #666;
- padding-right: 0;
- margin-left: 0;
- font-size: 14px;
- font-weight: normal;
-div.ms-res-ctn .ms-res-item em {
- font-style: normal;
- background: #565656;
- color: #FFF;
-div.ms-sel-ctn .ms-sel-item:hover {
- background: #434343;
-div.ms-sel-ctn .ms-sel-text:hover {
- background: #FFF;
-div.ms-sel-ctn .ms-sel-item-active {
- border: 1px solid red;
- background: #757575;
-div.ms-ctn .ms-sel-ctn {
- margin-left: 0px;
-div.ms-ctn .ms-sel-ctn .ms-sel-item {
- margin-top: 3px;
-div.ms-stacked .ms-sel-item {
- float: inherit;
-div.ms-sel-ctn .ms-sel-item .ms-close-btn {
- width: 7px;
- cursor: pointer;
- height: 7px;
- float: right;
- margin: 2px 2px 0 3px !important;
- background-image: url(data:image/png;base64,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);
- position: absolute;
- right: 2px;
- top: 2px;
-div.ms-sel-ctn .ms-sel-item .ms-close-btn:hover {
- background-position: 0 0;
-span.ms-helper {
- color: #AAA;
- font-size: 10px;
- top: -17px;
- right: 0;
-.ms-ctn.input-lg .ms-trigger .ms-trigger-ico {
- margin-top: 17px;
-.ms-ctn.input-sm .ms-trigger .ms-trigger-ico {
- margin-top: 13px;
-.ms-ctn.input-lg .ms-sel-ctn .ms-sel-item {
- padding-top: 2px;
- padding-bottom: 3px;
-.ms-ctn.input-sm .ms-sel-ctn {
- line-height: 15px;
-.ms-ctn.input-sm .ms-sel-ctn .ms-sel-item {
- padding-top: 1px;
- padding-bottom: 1px;
- margin-top: 0;
- margin-bottom: 0;
-.ms-ctn.input-sm .ms-sel-ctn .ms-sel-item .ms-close-btn {
- margin-top: 4px;
- width: 24px;
- right: 1px;
- border-radius: 0 3px 3px 0;
- EGroupware: CSS with less preprocessor
@@ -4155,7 +3915,7 @@
text-decoration: none;
height: 32px;
/font-size: 1.1em;/
- font-size: 12.100000000000001px;
line-height: 1.5em;
#egw_fw_header #egw_fw_topmenu #egw_fw_topmenu_items ul li a:hover {
@@ -4179,7 +3939,7 @@
#egw_fw_header #egw_fw_topmenu #egw_fw_topmenu_items ul a#topmenu_home:before {
padding-right: 20px;
content: " ";
background-image: url(…/images/topmenu_items/home.png);
@@ -4577,7 +4337,7 @@
padding-left: 3em;
color: #999999;
/font-size: 12px;/
line-height: 17px;
#egw_fw_sidebar #egw_fw_sidemenu .egw_fw_ui_scrollarea_outerdiv .egw_fw_ui_sidemenu_entry_header object {
@@ -4748,7 +4508,7 @@
margin: 5px 0px 3px 5px;
padding: 0px 0px 0px 15px;
line-height: 1em;
background-image: url(…/images/arrow_left.png);
background-position: left center;
@@ -7096,7 +6856,7 @@
line-height: 1em;
— trunk/pixelegg/css/pixelegg.css (original)
+++ trunk/pixelegg/css/pixelegg.css Tue Feb 16 22:37:19 2016
@@ -1126,19 +1126,6 @@
- .ms-ctn,
- .ms-res-ctn {
- min-width: 150px;
- top: 5px;
- .ms-res-ctn {
- et2_toolbar
@@ -1702,233 +1689,6 @@
@package pixelegg
@version $Id$
-div.ms-ctn {
- height: auto;
- padding: 0;
- font-size: 14px;
- color: #555555;
- cursor: default;
- display: block;
-input.ms-inv {
- cursor: pointer;
-div.ms-ctn input {
- border: 0;
- box-shadow: none;
- outline: none;
- display: block;
- padding: 4px 6px;
- overflow: hidden;
- height: auto;
- border-radius: 0;
- float: none;
- cursor: pointer;
- color: #DDD;
- border: 0;
- box-shadow: none;
- background: #FFF;
- float: right;
- width: 27px;
- height: 28px;
- background: #EEE;
- cursor: pointer;
- width: 0;
- height: 0;
- content: “”;
- margin-left: 9px;
- margin-top: 13px;
-div.ms-res-ctn {
- text-align: left;
- padding: 2px 5px;
- color: #333;
- text-align: left;
- padding: 2px 5px;
- color: #666;
- cursor: pointer;
- color: #fff;
-div.ms-sel-ctn {
- overflow: auto;
- background: #555;
- color: #EEE;
- float: left;
- font-size: 12px;
- margin-left: 5px;
- margin-top: 4px;
- background: #FFF;
- color: #666;
- padding-right: 0;
- margin-left: 0;
- font-size: 14px;
- color: #FFF;
- background: #FFF;
- margin-left: 0px;
- margin-top: 3px;
- float: inherit;
- width: 7px;
- cursor: pointer;
- height: 7px;
- float: right;
- right: 2px;
- top: 2px;
-span.ms-helper {
- color: #AAA;
- font-size: 10px;
- top: -17px;
- right: 0;
- margin-top: 17px;
- margin-top: 13px;
- padding-top: 2px;
- padding-top: 1px;
- margin-top: 0;
- margin-bottom: 0;
- margin-top: 4px;
- width: 24px;
- right: 1px;
— trunk/pixelegg/less/etemplate2.less (original)
+++ trunk/pixelegg/less/etemplate2.less Tue Feb 16 22:37:19 2016
@@ -9,7 +9,6 @@
@import (reference) “./def_design_pattern_color_font_shadow.less”;
@import (reference) “./def_buttons.less”;
/@import (less) “…/…/etemplate/templates/default/etemplate2.css”;/
@media all {
@@ -1058,21 +1057,6 @@
- et2_taglist
-.ms-ctn,
-.ms-res-ctn {
- min-width: 150px;
-.ms-ctn .loading {
- top: 5px;
-.ms-res-ctn {
— trunk/pixelegg/less/magicsuggest.css (original)
+++ trunk/pixelegg/less/magicsuggest.css Tue Feb 16 22:37:19 2016
@@ -11,230 +11,3 @@
@package pixelegg
@version $Id$
-div.ms-ctn {
- height: auto;
- padding: 0;
- font-size: 14px;
- color: #555555;
- cursor: default;
- display: block;
-input.ms-inv {
- cursor: pointer;
-div.ms-ctn input {
- border: 0;
- box-shadow: none;
- outline: none;
- display: block;
- padding: 4px 6px;
- overflow: hidden;
- height: auto;
- border-radius: 0;
- float: none;
- cursor: pointer;
- color: #DDD;
- border: 0;
- box-shadow: none;
- background: #FFF;
- float: right;
- width: 27px;
- height: 28px;
- background: #EEE;
- cursor: pointer;
- width: 0;
- height: 0;
- content: “”;
- margin-left: 9px;
- margin-top: 13px;
-div.ms-res-ctn {
- text-align: left;
- padding: 2px 5px;
- color: #333;
- text-align: left;
- padding: 2px 5px;
- color: #666;
- cursor: pointer;
- color: #fff;
-div.ms-sel-ctn {
- overflow: auto;
- background: #555;
- color: #EEE;
- float: left;
- font-size: 12px;
- margin-left: 5px;
- margin-top: 4px;
- background: #FFF;
- color: #666;
- padding-right: 0;
- margin-left: 0;
- font-size: 14px;
- color: #FFF;
- background: #FFF;
- margin-left: 0px;
- margin-top: 3px;
- float: inherit;
- width: 7px;
- cursor: pointer;
- height: 7px;
- float: right;
- right: 2px;
- top: 2px;
-span.ms-helper {
- color: #AAA;
- font-size: 10px;
- top: -17px;
- right: 0;
- margin-top: 17px;
- margin-top: 13px;
- padding-top: 2px;
- padding-top: 1px;
- margin-top: 0;
- margin-bottom: 0;
- margin-top: 4px;
- width: 24px;
- right: 1px;
— trunk/pixelegg/less/magicsuggest.less (original)
+++ trunk/pixelegg/less/magicsuggest.less Tue Feb 16 22:37:19 2016
@@ -15,237 +15,3 @@
@import (reference) “definitions.less”;
-div.ms-ctn{
- height: auto;
- padding: 0;
- font-size: 14px;
- color: #555555;
- cursor: default;
- display: block;
-input.ms-inv{
-div.ms-ctn-readonly{
- cursor: pointer;
-div.ms-ctn-disabled{
-div.ms-ctn input{
- border: 0;
- box-shadow: none;
- outline: none;
- display: block;
- padding: 4px 6px;
- overflow: hidden;
- height: auto;
- border-radius: 0;
- float: none;
-div.ms-ctn-disabled input{
-div.ms-ctn .ms-input-readonly{
- cursor: pointer;
-div.ms-ctn .ms-empty-text{
- color: #DDD;
-div.ms-ctn input:focus{
- border: 0;
- box-shadow: none;
- background: #FFF;
-div.ms-ctn .ms-trigger{
- float: right;
- width: 27px;
- height: 28px;
- background: #EEE;
- cursor: pointer;
- width: 0;
- height: 0;
- content: “”;
- margin-left: 9px;
- margin-top: 13px;
-div.ms-ctn .ms-trigger:hover{
-div.ms-ctn .ms-trigger:hover .ms-trigger-ico{
-div.ms-ctn-disabled .ms-trigger{
-div.ms-ctn-bootstrap-focus{
-div.ms-res-ctn{
-div.ms-res-ctn .ms-res-group{
- text-align: left;
- padding: 2px 5px;
- color: #333;
-div.ms-res-ctn .ms-res-item{
- text-align: left;
- padding: 2px 5px;
- color: #666;
- cursor: pointer;
-div.ms-res-ctn .ms-res-item-grouped{
-div.ms-res-ctn .ms-res-odd{
-div.ms-res-ctn .ms-res-item-active{
-// filter: progid:DXImageTransform.Microsoft.gradient( startColorstr=’#3875D7’, endColorstr=’#2A62BC’, GradientType=0 );
-// background-image: -webkit-gradient(linear, 0 0, 0 100%, color-stop(20%, #3875D7), color-stop(90%, #2A62BC));
-// background-image: -webkit-linear-gradient(top, #3875D7 20%, #2A62BC 90%);
-// background-image: -moz-linear-gradient(top,
