Author: ralfbecker
New Revision: 55055
URL: http://svn.stylite.de/viewvc/egroupware?rev=55055&view=rev
alignment of NM header
trunk/addressbook/inc/class.addressbook_ui.inc.php
trunk/addressbook/lang/egw_bg.lang
trunk/addressbook/lang/egw_ca.lang
trunk/addressbook/lang/egw_cs.lang
trunk/addressbook/lang/egw_de.lang
trunk/addressbook/lang/egw_el.lang
trunk/addressbook/lang/egw_en.lang
trunk/addressbook/lang/egw_es-es.lang
trunk/addressbook/lang/egw_fi.lang
trunk/addressbook/lang/egw_fr.lang
trunk/addressbook/lang/egw_hu.lang
trunk/addressbook/lang/egw_id.lang
trunk/addressbook/lang/egw_it.lang
trunk/addressbook/lang/egw_lo.lang
trunk/addressbook/lang/egw_nl.lang
trunk/addressbook/lang/egw_pl.lang
trunk/addressbook/lang/egw_pt-br.lang
trunk/addressbook/lang/egw_ru.lang
trunk/addressbook/lang/egw_sk.lang
trunk/addressbook/lang/egw_sl.lang
trunk/addressbook/lang/egw_sv.lang
trunk/addressbook/lang/egw_zh-tw.lang
trunk/addressbook/lang/egw_zh.lang
trunk/addressbook/templates/default/app.css
trunk/addressbook/templates/pixelegg/app.css
trunk/calendar/inc/class.calendar_uilist.inc.php
trunk/calendar/js/app.js
trunk/calendar/templates/default/list.xet
trunk/calendar/templates/pixelegg/app.less
trunk/etemplate/templates/default/etemplate2.css
trunk/infolog/inc/class.infolog_ui.inc.php
trunk/infolog/templates/default/app.css
trunk/infolog/templates/pixelegg/app.css
trunk/infolog/templates/pixelegg/app.less
trunk/phpgwapi/lang/egw_bg.lang
trunk/phpgwapi/lang/egw_ca.lang
trunk/phpgwapi/lang/egw_cs.lang
trunk/phpgwapi/lang/egw_de.lang
trunk/phpgwapi/lang/egw_el.lang
trunk/phpgwapi/lang/egw_en.lang
trunk/phpgwapi/lang/egw_es-es.lang
trunk/phpgwapi/lang/egw_fi.lang
trunk/phpgwapi/lang/egw_fr.lang
trunk/phpgwapi/lang/egw_hu.lang
trunk/phpgwapi/lang/egw_id.lang
trunk/phpgwapi/lang/egw_it.lang
trunk/phpgwapi/lang/egw_lo.lang
trunk/phpgwapi/lang/egw_nl.lang
trunk/phpgwapi/lang/egw_pl.lang
trunk/phpgwapi/lang/egw_pt-br.lang
trunk/phpgwapi/lang/egw_ru.lang
trunk/phpgwapi/lang/egw_sk.lang
trunk/phpgwapi/lang/egw_sl.lang
trunk/phpgwapi/lang/egw_sv.lang
trunk/phpgwapi/lang/egw_zh-tw.lang
trunk/phpgwapi/lang/egw_zh.lang
trunk/timesheet/inc/class.timesheet_ui.inc.php
trunk/timesheet/js/app.js
— trunk/addressbook/inc/class.addressbook_ui.inc.php (original)
+++ trunk/addressbook/inc/class.addressbook_ui.inc.php Wed Feb 17 20:56:54 2016
@@ -1737,10 +1737,10 @@
$rows[‘customfields’] = array_values($this->customfields);
// full app-header with all search criteria specially for the print
@@ -1748,7 +1748,7 @@
if ($query[‘org_view’])
@@ -1758,21 +1758,23 @@
if($query[‘advanced_search’])
$header[] = lang("%1 starts with '%2'",$order,$query['searchletter']);
if ($query['search'] && !$query['advanced_search']) // do not add that, if we have advanced search active
$header[] = lang("Search for '%1'",$query['search']);
$GLOBALS['egw_info']['flags']['app_header'] = implode(': ', $header);
return $this->total;
— trunk/addressbook/lang/egw_bg.lang (original)
+++ trunk/addressbook/lang/egw_bg.lang Wed Feb 17 20:56:54 2016
@@ -295,7 +295,6 @@
required fields * addressbook bg ÐадÑлжиÑелни полеÑа *
role addressbook bg РолÑ
room addressbook bg СÑаÑ
-search for ‘%1’ addressbook bg ТÑÑÑене на '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook bg ÐзбеÑеÑе Ñнимка вÑв ÑоÑÐ¼Ð°Ñ “поÑÑÑеє. Ð¢Ñ Ñе бÑде пÑеоÑазмеÑена на 60 пикÑела ÑиÑина.
select a view addressbook bg ÐÐ·Ð±Ð¾Ñ Ð½Ð° изглед
select addressbook type addressbook bg ÐÐ·Ð±Ð¾Ñ Ð½Ð° Ñип адÑеÑен ÑказаÑел
— trunk/addressbook/lang/egw_ca.lang (original)
+++ trunk/addressbook/lang/egw_ca.lang Wed Feb 17 20:56:54 2016
@@ -262,7 +262,6 @@
repetition addressbook ca Repetició
role addressbook ca CÃ rrec
room addressbook ca Despatx
-search for ‘%1’ addressbook ca Busceu per '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook ca Seleccioneu una fotografia en format jpeg. Serà redimensionada a una amplada de 60 pÃxels.
select a view addressbook ca Seleccioneu una vista
select addressbook type addressbook ca Seleccioneu un tipus de llibreta d’adreces
— trunk/addressbook/lang/egw_cs.lang (original)
+++ trunk/addressbook/lang/egw_cs.lang Wed Feb 17 20:56:54 2016
@@ -322,7 +322,6 @@
required fields * addressbook cs povinné položky *
role addressbook cs Role
room addressbook cs MÃstnost
-search for ‘%1’ addressbook cs Hledat '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook cs Vyberte portrét ve formátu jpeg. Bude upraven na Å¡ÃÅku 60 pixelů.
select a view addressbook cs Vybrat pohled
select addressbook type addressbook cs Vybrat typ adresáÅe
— trunk/addressbook/lang/egw_de.lang (original)
+++ trunk/addressbook/lang/egw_de.lang Wed Feb 17 20:56:54 2016
@@ -404,7 +404,6 @@
required fields * addressbook de unbedingt auszufüllende Felder *
role addressbook de Beruf
room addressbook de Raum
-search for ‘%1’ addressbook de Suche nach '%1’
search letter addressbook de Suche nach Buchstaben
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook de Wählen Sie ein hochformatiges jpeg Foto. Es wird 60 Pixel breit skaliert.
select a view addressbook de Eine Ansicht auswählen
— trunk/addressbook/lang/egw_el.lang (original)
+++ trunk/addressbook/lang/egw_el.lang Wed Feb 17 20:56:54 2016
@@ -273,7 +273,6 @@
required fields * addressbook el αÏαιÏοÏμενα Ïεδία *
role addressbook el ΡÏλοÏ
room addressbook el ÎÏαÏείο
-search for ‘%1’ addressbook el ÎναζήÏηÏη για '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook el ÎÏιλÎξÏε μια jpeg ÏÏÏογÏαÏία Ïε μοÏÏή ÏοÏÏÏαίÏοÏ
. Îα εÏαναÏÏοÏδιοÏιÏÏεί Ïε 60 pixel ÏλάÏοÏ.
select a view addressbook el ÎÏιλÎξÏε μία ÏÏοβολή
select addressbook type addressbook el ÎÏιλÎξÏε ÏÏÏο βιβλίοÏ
διεÏ
θÏνÏεÏν
— trunk/addressbook/lang/egw_en.lang (original)
+++ trunk/addressbook/lang/egw_en.lang Wed Feb 17 20:56:54 2016
@@ -404,7 +404,6 @@
required fields * addressbook en Required fields *
role addressbook en Occupation
room addressbook en Room
-search for ‘%1’ addressbook en Search for '%1’
search letter addressbook en Search letter
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook en Select a portrait format jpeg photo. It will be re-sized to 60 pixel width.
select a view addressbook en Select a view
— trunk/addressbook/lang/egw_es-es.lang (original)
+++ trunk/addressbook/lang/egw_es-es.lang Wed Feb 17 20:56:54 2016
@@ -386,7 +386,6 @@
required fields * addressbook es-es Campos requeridos *
role addressbook es-es Rol
room addressbook es-es Habitación
-search for ‘%1’ addressbook es-es Buscar '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook es-es Seleccione una foto jpeg en formato vertical. Se redimensionará a un ancho de 60 pixels.
select a view addressbook es-es Seleccionar una vista
select addressbook type addressbook es-es Seleccionar el tipo de libreta de direcciones
— trunk/addressbook/lang/egw_fi.lang (original)
+++ trunk/addressbook/lang/egw_fi.lang Wed Feb 17 20:56:54 2016
@@ -358,7 +358,6 @@
required fields * addressbook fi Vaaditut kentät *
role addressbook fi Ammatti
room addressbook fi Huone
-search for ‘%1’ addressbook fi Haku '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook fi Valitse jpeg muodossa oleva kuva. Se muokkautuu 60 pikseliä leveäksi kuvaksi.
select a view addressbook fi Valitse näkymä
select addressbook type addressbook fi Valitse osoitekirjan tyyppi
— trunk/addressbook/lang/egw_fr.lang (original)
+++ trunk/addressbook/lang/egw_fr.lang Wed Feb 17 20:56:54 2016
@@ -393,7 +393,6 @@
required fields * addressbook fr Champs nécessaires *
role addressbook fr Rôle
room addressbook fr Salle
-search for ‘%1’ addressbook fr Recherche de '%1’
search letter addressbook fr Chercher sur une lettre
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook fr Sélectionner une photo jpeg en mode portrait. Elle sera reformatée en 60 pixels de largeur.
select a view addressbook fr Sélectionnez une vue
— trunk/addressbook/lang/egw_hu.lang (original)
+++ trunk/addressbook/lang/egw_hu.lang Wed Feb 17 20:56:54 2016
@@ -277,7 +277,6 @@
required fields * addressbook hu kötelezÅ mezÅk
role addressbook hu Szerep
room addressbook hu Szoba
-search for ‘%1’ addressbook hu ‘%1’ keresése
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook hu Válasszon ki egy arcképes fotót. Ãt lesz méretezve 60 pixel szélességűre.
select a view addressbook hu Nézet választása
select addressbook type addressbook hu Válassza ki a CÃmjegyzék tÃpusát
— trunk/addressbook/lang/egw_id.lang (original)
+++ trunk/addressbook/lang/egw_id.lang Wed Feb 17 20:56:54 2016
@@ -246,7 +246,6 @@
required fields * addressbook id Field diperlukan *
role addressbook id Peran
room addressbook id Ruang
-search for ‘%1’ addressbook id Mencari '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook id Select a portrait format jpeg photo. It will be resized to 60 pixel width.
select a view addressbook id Pilih tampilan
select addressbook type addressbook id Pilih tipe buku alamat
— trunk/addressbook/lang/egw_it.lang (original)
+++ trunk/addressbook/lang/egw_it.lang Wed Feb 17 20:56:54 2016
@@ -398,7 +398,6 @@
required fields * addressbook it Campi obbligatori *
role addressbook it Ruolo
room addressbook it Stanza
-search for ‘%1’ addressbook it Cerca '%1’
search letter addressbook it Cerca per lettera
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook it Seleziona una foto jpeg in formato ritratto. Sarà ridimensionata ad una larghezza di 60 pixel.
select a view addressbook it Seleziona una vista
— trunk/addressbook/lang/egw_lo.lang (original)
+++ trunk/addressbook/lang/egw_lo.lang Wed Feb 17 20:56:54 2016
@@ -36,7 +36,6 @@
permission denied !!! addressbook lo àºà»à»à»àºà»àº®àº±àºàºàº°àºàº¸àºàº²àº !!!
repetition addressbook lo àºàº²àºà»àº®àº±àºàºà»à»àº²
role addressbook lo àºàº»àºàºàº²àº
-search for ‘%1’ addressbook lo àºàº»à»àºàº«àº² '% 1’
select multiple contacts for a further action addressbook lo à»àº¥àº·àºàºà»àºàº»àº²àºàº²àºàºàº´àºàºà»à»àº«àº¼àº²àºàº®àº¹àºà»àºàº à»àºàº·à»àºàºàº²àºàºà»àº²à»àºàºµàºàºàº²àºàºà»à»à»àº
show addressbook lo ສະà»àºàº
start admin lo à»àº¥àºµà»àº¡
— trunk/addressbook/lang/egw_nl.lang (original)
+++ trunk/addressbook/lang/egw_nl.lang Wed Feb 17 20:56:54 2016
@@ -395,7 +395,6 @@
required fields * addressbook nl verplichte velden *
role addressbook nl Rol
room addressbook nl Kamer
-search for ‘%1’ addressbook nl Zoek naar '%1’
search letter addressbook nl Zoek letter
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook nl Kies een portretformaat jpeg foto. Het wordt aangepast tot 60 pixels breedte.
select a view addressbook nl Kies een weergave
— trunk/addressbook/lang/egw_pl.lang (original)
+++ trunk/addressbook/lang/egw_pl.lang Wed Feb 17 20:56:54 2016
@@ -330,7 +330,6 @@
required fields * addressbook pl pola wymagane *
role addressbook pl Pozycja
room addressbook pl Pokój
-search for ‘%1’ addressbook pl Szukaj '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook pl Wybierz zdjÄcie w formacie JPEG. BÄdzie zmniejszone do szerokoÅci 60 pikseli.
select a view addressbook pl Wybierz wyglÄ
d
select addressbook type addressbook pl Wybierz typ ksiÄ
żki adresowej
— trunk/addressbook/lang/egw_pt-br.lang (original)
+++ trunk/addressbook/lang/egw_pt-br.lang Wed Feb 17 20:56:54 2016
@@ -316,7 +316,6 @@
required fields * addressbook pt-br campos requeridos *
role addressbook pt-br Função
room addressbook pt-br Sala
-search for ‘%1’ addressbook pt-br Procurar por '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook pt-br Selecione uma foto no formato jpeg. Ela será alterada para o tamanho de 60 pixels de largura
select a view addressbook pt-br Selecionar uma exibição
select addressbook type addressbook pt-br Selecionar tipo de Livro de Contatos
— trunk/addressbook/lang/egw_ru.lang (original)
+++ trunk/addressbook/lang/egw_ru.lang Wed Feb 17 20:56:54 2016
@@ -369,7 +369,6 @@
required fields * addressbook ru ТÑебÑемÑе полÑ
role addressbook ru ÐолжноÑÑÑ
room addressbook ru ÐомнаÑа
-search for ‘%1’ addressbook ru ÐÑкаÑÑ '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook ru ÐÑбÑаÑÑ ÑоÑогÑаÑÐ¸Ñ jpeg поÑÑÑеÑного ÑоÑмаÑа. Ðна бÑÐ´ÐµÑ Ð¼Ð°ÑÑÑабиÑована до 60 пикÑелей в ÑиÑинÑ
select a view addressbook ru ÐÑбÑаÑÑ Ð²Ð¸Ð´
select addressbook type addressbook ru ÐÑбÑаÑÑ Ñип адÑеÑной книги
— trunk/addressbook/lang/egw_sk.lang (original)
+++ trunk/addressbook/lang/egw_sk.lang Wed Feb 17 20:56:54 2016
@@ -398,7 +398,6 @@
required fields * addressbook sk Požadované polia *
role addressbook sk PozÃcia
room addressbook sk Miestnosť
-search for ‘%1’ addressbook sk HľadaÅ¥ '%1’
search letter addressbook sk HľadaÅ¥ podľa pÃsmena
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook sk Vyberte obrázok jpeg orientovaný na výšku. Bude prispôsobený na výškový rozmer 60 pixlov.
select a view addressbook sk Vyberte pohľad
— trunk/addressbook/lang/egw_sl.lang (original)
+++ trunk/addressbook/lang/egw_sl.lang Wed Feb 17 20:56:54 2016
@@ -345,7 +345,6 @@
required fields * addressbook sl Zahtevana polja *
role addressbook sl Vloga
room addressbook sl Soba
-search for ‘%1’ addressbook sl IÅ¡Äi '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook sl Izberite pokonÄno sliko JPEG. Njena velikost bo spremenjena na Å¡irino 60 pikslov.
select a view addressbook sl Izberite pogled
select addressbook type addressbook sl Izberite vrsto adresarja
— trunk/addressbook/lang/egw_sv.lang (original)
+++ trunk/addressbook/lang/egw_sv.lang Wed Feb 17 20:56:54 2016
@@ -242,7 +242,6 @@
repetition addressbook sv Ã
terkommande
role addressbook sv Roll
room addressbook sv Rum
-search for ‘%1’ addressbook sv Sök efter '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook sv Välj ett jpeg porträtt foto. Bilden skalas om till 60 pixel.
select a view addressbook sv Välj vy
select addressbook type addressbook sv Välj adressbok typ
— trunk/addressbook/lang/egw_zh-tw.lang (original)
+++ trunk/addressbook/lang/egw_zh-tw.lang Wed Feb 17 20:56:54 2016
@@ -287,7 +287,6 @@
required fields * addressbook zh-tw å¿
å¡«æ¬ä½
role addressbook zh-tw è§è²
room addressbook zh-tw 辦å
¬å®¤
-search for ‘%1’ addressbook zh-tw æå° '%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook zh-tw 鏿ä¸å jpeg æ ¼å¼çç
§çï¼å®æè¢«éæ°èª¿æ´çºå¯¬åº¦ 60 ç«ç´ ã
select a view addressbook zh-tw 鏿ä¸å檢è¦
select addressbook type addressbook zh-tw 鏿éè¨éé¡å
— trunk/addressbook/lang/egw_zh.lang (original)
+++ trunk/addressbook/lang/egw_zh.lang Wed Feb 17 20:56:54 2016
@@ -292,7 +292,6 @@
required fields * addressbook zh å¿
è¦å段*
role addressbook zh èå¡
room addressbook zh æ¿é´
-search for ‘%1’ addressbook zh æç´¢’%1’
select a portrait format jpeg photo. it will be resized to 60 pixel width. addressbook zh éæ©ä¸ä¸ª jpeg æ ¼å¼çç
§çï¼å®å°è¢«éæ°è°æ´å®½åº¦ä¸º60pxã
select a view addressbook zh éæ©ä¸ä¸ªæ¥ç
select addressbook type addressbook zh éæ©é讯簿类å
— trunk/addressbook/templates/default/app.css (original)
+++ trunk/addressbook/templates/default/app.css Wed Feb 17 20:56:54 2016
@@ -118,7 +118,7 @@
right: 215px;
#addressbook-index .filtersContainer select {
- width: 31.5%;
select#addressbook-index_col_filter[tid] {
width: 82px;
@@ -127,6 +127,3 @@
float:right;
width: 200px;
-#addressbook-index_favorite_wrapper {
— trunk/addressbook/templates/pixelegg/app.css (original)
+++ trunk/addressbook/templates/pixelegg/app.css Wed Feb 17 20:56:54 2016
@@ -137,7 +137,7 @@
right: 215px;
- width: 31.5%;
width: 82px;
@@ -145,9 +145,6 @@
#addressbook-index_addressbook-index-row select {
float: right;
width: 200px;
- top: -1px;
@media all {
— trunk/calendar/inc/class.calendar_uilist.inc.php (original)
+++ trunk/calendar/inc/class.calendar_uilist.inc.php Wed Feb 17 20:56:54 2016
@@ -5,7 +5,7 @@
@copyright © 2005-16 by RalfBecker-At-outdoor-training.de
@license http://opensource.org/licenses/gpl-license.php GPL - GNU General Public License
@version $Id$
@@ -155,7 +155,6 @@
‘sort’ => ‘ASC’,// IO direction of the sort: ‘ASC’ or ‘DESC’
‘default_cols’ => ‘!week,weekday,cal_title,cal_description,recure,cal_location,cal_owner,cat_id,pm_id’,
‘filter_onchange’ => “app.calendar.filter_change”,
'header_left' => 'calendar.list.dates',
'row_id' => 'row_id', // set in get rows "$event[id]:$event[recur_date]"
'row_modified' => 'modified',
'favorites' => true
@@ -353,7 +352,7 @@
$params[‘startdate’] = egw_time::to($this->first, egw_time::ET2);
$params[‘enddate’] = egw_time::to($this->last, egw_time::ET2);
break;
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Wed Feb 17 20:56:54 2016
@@ -5,7 +5,7 @@
- will automatically update itself.
@param {string} _msg message (already translated) to show, eg. ‘Entry deleted’
@param {string} _app application name
@@ -441,10 +441,10 @@
* Set the app header
- Because the toolbar takes some vertical space and has some horizontal space,
- we don’t use the system app header, but our own that is in the toolbar
@param {string} header Text to display
set_app_header: function(header) {
@@ -652,7 +652,7 @@
if(widget == null) return;
/ Disabled
@@ -721,13 +721,13 @@
window.setTimeout(function() {
cloned.remove();
@@ -783,7 +783,7 @@
},0);
@@ -793,12 +793,12 @@
// Consume scroll if in the middle of something
if(app.calendar._scroll_disabled) return false;
@@ -1046,7 +1046,7 @@
if (typeof duration != ‘undefined’ && typeof end != ‘undefined’)
end.set_disabled(duration.get_value()!==’’);
@@ -1302,6 +1302,10 @@
if (filter && dates)
dates.set_disabled(filter.value !== “custom”);
@@ -1445,7 +1449,7 @@
var widget = _senders[0].iface.getWidget();
return widget.recur_prompt();
@@ -1602,7 +1606,7 @@
typeof content.recur_type != ‘undefined’ && content.recur_type != null && content.recur_type != 0
@@ -1805,7 +1809,7 @@
// it will work for other users too.
state.owner = 0;
@@ -1826,7 +1830,7 @@
delete state.enddate;
delete state.start_date;
delete state.end_date;
@@ -1992,7 +1996,7 @@
break;
// Month is calculated individually for the month
@@ -2009,7 +2013,7 @@
// Hide all but the first day header
$j(grid.getDOMNode()).toggleClass('hideDayColHeader',state.state.view == 'week');
@@ -2080,7 +2084,7 @@
var row_index = 0;
@@ -2197,7 +2201,7 @@
view.etemplates[0].widgetContainer.iterateOver(function(w) {
w.set_width($j(view.etemplates[0].DOMContainer).width() * 0.69);
},this,et2_calendar_timegrid);
$j(view.etemplates[1].DOMContainer).css({"left":"69%", "height":($j(framework.tabsUi.activeTab.contentDiv).height()-30)+'px'});
// TODO: Maybe some caching here
this.egw.jsonq('calendar_uiviews::ajax_get_todos', [state.state.date, state.state.owner[0]], function(data) {
@@ -2804,7 +2808,7 @@
* callbacks.
* @param {Object} state Current state for update, used to determine what to update
_update_events: function(state, data) {
var updated_days = {};
@@ -3165,7 +3169,7 @@
.on(‘click’, ‘.ui-datepicker-week-col’, function() {
var view = app.calendar.state.view;
var days = app.calendar.state.days;
// Avoid a full state update, we just want the calendar to update
// Directly update to avoid change event from the sidebox calendar
var date = new Date(this.nextSibling.dataset.year,this.nextSibling.dataset.month,this.nextSibling.firstChild.textContent,0,0,0);
@@ -3312,7 +3316,7 @@
// Avoid unwanted refresh immediately after load
nm.c
