- Widget for selecting a date range
@augments et2_inputWidget
+var et2_date_range = et2_inputWidget.extend({
- attributes: {
value: {
"type": "any",
"description": "An object with keys 'from' and 'to' for absolute ranges, or a relative range string"
relative: {
type: 'boolean',
description: 'Is the date range relative (this week) or absolute (2016-02-15 - 2016-02-21). This will affect the value returned.'
- init: function init() {
this._super.apply(this, arguments);
this.div = jQuery(document.createElement('div'))
.attr({ class:'et2_date_range'});
this.from = null;
this.to = null;
this.select = null;
// Set domid
this.set_id(this.id);
this.setDOMNode(this.div[0]);
this._createWidget();
this.set_relative(this.options.relative || false)
- _createWidget: function createInputWidget() {
var widget = this;
this.from = et2_createWidget('date',{
blur: egw.lang('From'),
onchange: function() { widget.to.set_min(widget.from.getValue()); }
},this);
this.to = et2_createWidget('date',{
blur: egw.lang('To'),
onchange: function() {widget.from.set_max(widget.to.getValue()); }
},this);
this.select = et2_createWidget('select',{
select_options: et2_date_range.relative_dates,
empty_label: this.options.blur || 'All'
},this);
this.select.loadingFinished();
- Function which allows iterating over the complete widget tree.
- Overridden here to avoid problems with children when getting value
@param _callback is the function which should be called for each widget
@param _context is the context in which the function should be executed
@param _type is an optional parameter which specifies a class/interface
- the elements have to be instanceOf.
- iterateOver: function(_callback, _context, _type) {
if (typeof _type == "undefined")
_type = et2_widget;
if (this.isInTree() && this.instanceOf(_type))
_callback.call(_context, this);
- Toggles relative or absolute dates
- set_relative: function set_relative(_value)
this.options.relative = _value;
if(this.options.relative)
$j(this.from.getDOMNode()).hide();
$j(this.to.getDOMNode()).hide();
else
$j(this.select.getDOMNode()).hide();
- set_value: function set_value(value)
if(!value || typeof value == 'null')
this.select.set_value('');
this.from.set_value(null);
this.to.set_value(null);
// Relative
if(value && typeof value === 'string')
this._set_relative_value(value);
else if(value && typeof value.from === 'undefined' && value[0])
value = {
to: value[1] || new Date().valueOf()/1000
else if (value && value.from && value.to)
this.from.set_value(value.from);
this.to.set_value(value.to);
- getValue: function getValue()
return this.options.relative ?
this.select.getValue() :
{ from: this.from.getValue(), to: this.to.getValue() }
- _set_relative_value: function(_value)
$j(this.select.getDOMNode()).show();
// Show description
this.select.set_value(_value);
var now = new Date();
now.setUTCMinutes(-now.getTimezoneOffset());
now.setUTCHours(0);
now.setUTCSeconds(0);
// Use strings to avoid references
this.from.set_value(now.toJSON());
this.to.set_value(now.toJSON());
var relative = null;
for(var index in et2_date_range.relative_dates)
if(et2_date_range.relative_dates[index].value === _value)
relative = et2_date_range.relative_dates[index];
break;
if(relative)
var dates = ["from","to"]
var value = now.toJSON();
for(var i = 0; i < dates.length; i++)
var date = dates[i];
if(typeof relative[date] == "function")
value = relative[date](new Date(value))
else
value = this[date]._relativeDate(relative[date]);
this[date].set_value(value);
+et2_register_widget(et2_date_range, [“date-range”]);
+// Static part of the date range class
+jQuery.extend(et2_date_range,
- // Class Constants
- relative_dates: [
// Start and end are relative offsets, see et2_date.set_min()
// or Date objects
value: 'Today',
label: 'Today',
to: '+1d'
label: 'Yesterday',
value: 'Yesterday',
to: ''
label: 'This week',
value: 'This week',
from: function(date) {return egw.week_start(date);},
to: function(date) {
date.setUTCDate(date.getUTCDate() + 6);
return date;
label: 'Last week',
value: 'Last week',
var d = egw.week_start(date);
d.setUTCDate(d.getUTCDate() - 7);
return d;
return date;
label: 'This month',
value: 'This month',
to: '+1m'
label: 'Last month',
value: 'Last month',
to: ''
label: 'Last 3 months',
value: 'Last 3 months',
to: ''
'This quarter'=> array(0,0,0,0, 0,0,0,0), // Just a marker, needs special handling
'Last quarter'=> array(0,-4,0,0, 0,-4,0,0), // Just a marker
label: 'This year',
value: 'This year',
d.setUTCMonth(0);
d.setUTCDate(1);
return d;
to: function(d) {
d.setUTCMonth(11);
d.setUTCDate(31);
return d
label: 'Last year',
value: 'Last year',
d.setUTCMonth(0);
d.setUTCDate(1);
d.setUTCYear(d.getUTCYear() - 1)
return d;
to: function(d) {
d.setUTCMonth(11);
d.setUTCDate(31);
return d
/* Still needed?
'2 years ago' => array(-2,0,0,0, -1,0,0,0),
'3 years ago' => array(-3,0,0,0, -2,0,0,0),
