Author: ralfbecker
New Revision: 55065
URL: http://svn.stylite.de/viewvc/egroupware?rev=55065&view=rev
fix not working “cat_is_select” === true, for translating options used instead of category-selection
branches/14.2/etemplate/js/et2_extension_nextmatch.js
— branches/14.2/etemplate/js/et2_extension_nextmatch.js (original)
+++ branches/14.2/etemplate/js/et2_extension_nextmatch.js Thu Feb 18 16:51:33 2016
@@ -539,7 +539,7 @@
@@ -1427,7 +1427,7 @@
self.activeFilters.selectcols.push(‘lettersearch’);
self.getInstanceManager().submit();
@@ -1467,7 +1467,7 @@
* Set the currently displayed columns, without updating user's preference
@param {string[]} column_list List of column names
@param {boolean} trigger_update=false - explicitly trigger an update
@@ -1506,7 +1506,7 @@
var cf = this.columns[i].widget.options.customfields;
var visible = this.columns[i].widget.options.fields;
@@ -2315,7 +2315,7 @@
// Add category
if(!settings.no_cat) {
settings.cat_id_label = egw.lang(“Category”);
this.category = this._build_select('cat_id', 'select-cat', settings.cat_id, settings.cat_is_select !== true);
// Filter 1
eGroupWare-cvs mailing list
