Author: nathangray
New Revision: 55070
URL: http://svn.stylite.de/viewvc/egroupware?rev=55070&view=rev
Promote calendar-owner to full widget, loadable by etemplate on its own
Added:
trunk/calendar/inc/class.calendar_owner_etemplate_widget.inc.php
trunk/calendar/inc/class.calendar_export_csv.inc.php
trunk/calendar/inc/class.calendar_ui.inc.php
trunk/calendar/inc/class.calendar_uiforms.inc.php
trunk/calendar/js/et2_widget_owner.js
trunk/calendar/templates/default/export_csv_select.xet
trunk/calendar/templates/default/sidebox.xet
— trunk/calendar/inc/class.calendar_export_csv.inc.php (original)
+++ trunk/calendar/inc/class.calendar_export_csv.inc.php Thu Feb 18 20:45:37 2016
@@ -237,21 +237,30 @@
public function get_selectors_etpl($definition = null) {
$states = $GLOBALS['egw']->session->appsession('session_data','calendar');
switch($states['view']) {
case 'month':
$query = $this->get_query_month($states);
break;
case 'week':
case 'weekN':
$query = $this->get_query_week($states);
break;
case 'day':
$query = $this->get_query_day($states);
break;
$start= new egw_time($query['start']);
$end = new egw_time($query['end']);
$states = $this->bo->cal_prefs['saved_states'];
$list = $GLOBALS['egw']->session->appsession('calendar_list','calendar');
if(!$list['startdate'])
case 'month':
break;
case 'week':
case 'weekN':
break;
case 'day':
break;
else
$start= new egw_time($list['startdate']);
$end = new egw_time($list['enddate']);
if ($states['view'] == 'listview')
@@ -375,6 +384,9 @@
‘no-enum-groups’ => lang(‘only group-events’),
‘not-unknown’ => lang(‘No meeting requests’),
— trunk/calendar/inc/class.calendar_owner_etemplate_widget.inc.php (added)
+++ trunk/calendar/inc/class.calendar_owner_etemplate_widget.inc.php Thu Feb 18 20:45:37 2016
@@ -1,0 +1,160 @@
+<?php
- EGroupware - eTemplate serverside of owner list widget
@copyright 2016 Nathan Gray
- eTemplate tag list widget
- The naming convention is __etemplate_widget
+class calendar_owner_etemplate_widget extends etemplate_widget_taglist
- Make sure all the needed select options are there
- @param array $expand values for keys ‘c’, ‘row’, ‘c_’, ‘row_’, ‘cont’
- public function beforeSendToClient($cname, array $expand=null)
egw_framework::validate_file('.','et2_widget_owner','calendar');
egw_framework::includeCSS('calendar');
$bo = new calendar_bo();
$form_name = self::form_name($cname, $this->id, $expand);
$value =& self::get_array(self::$request->content, $form_name);
if (!is_array(self::$request->sel_options[$form_name]))
self::$request->sel_options[$form_name] = array();
$sel_options =& self::$request->sel_options[$form_name];
// Get user accounts, formatted nicely for grouping and matching
// the ajax call calendar_uiforms->ajax_owner() - users first
$accounts = array();
$list = array('accounts', 'owngroups');
foreach($list as $type)
$account_options = array('account_type' => $type);
$accounts += accounts::link_query('',$account_options);
$accounts = array_intersect_key($accounts, $GLOBALS['egw']->acl->get_grants('calendar'));
$sel_options += array_map(
function($account_id, $account_name) {
return array(
'value' => ''.$account_id,
'label' => $account_name,
'app' => lang('home-accounts')
array_keys($accounts), $accounts
// Add external owners that a select account widget will not find
foreach($value as &$owner)
// Make sure it's a string for comparison
$owner = ''.$owner;
if(!is_numeric($owner))
$resource = $bo->resources[substr($owner, 0,1)];
$label = egw_link::title($resource['app'], substr($owner,1));
$linked_owners[$resource['app']][substr($owner,1)] = $label;
else if (!in_array($owner, array_keys($accounts)))
$label = egw_link::title('home-accounts',$owner);
$resource = array('app'=> 'home-accounts');
else
continue;
$sel_options[] = array('value' => $owner, 'label' => $label, 'app' => lang($resource['app']));
- Handle ajax searches for owner across all supported resources
- @return Array List of matching results
- public static function ajax_owner()
$query = $_REQUEST['query'];
// Arbitrarily limited to 50 / resource
$options = ['start' => 0, 'num_rows' => 50];
$results = [];
$resources = array_merge(array('' => $bo->resources['']),$bo->resources);
foreach($resources as $type => $data)
$mapped = array();
$_results = array();
// Handle accounts seperately
if($type == '')
foreach($list as $a_type)
$account_options = $options + array('account_type' => $a_type);
$_results += accounts::link_query('',$account_options);
$_results = array_intersect_key($_results, $GLOBALS['egw']->acl->get_grants('calendar'));
else if ($data['app'] && egw_link::get_registry($data['app'], 'query'))
$_results = egw_link::query($data['app'], $query,$options);
if(!$_results) continue;
$_results = array_unique($_results);
foreach($_results as $id => $title)
if($id && $title)
// Magicsuggest uses id, not value.
$value = [
'id' => $type.$id,
'value'=> $type.$id,
'label' => $title,
'app' => lang($data['app'])
if(is_array($value['label']))
$value = array_merge($value, $value['label']);
$mapped[] = $value;
if(count($mapped))
$results = array_merge($results, $mapped);
// switch regular JSON response handling off
egw_json_request::isJSONRequest(false);
header('Content-Type: application/json; charset=utf-8');
echo json_encode($results);
common::egw_exit();
— trunk/calendar/inc/class.calendar_ui.inc.php (original)
+++ trunk/calendar/inc/class.calendar_ui.inc.php Thu Feb 18 20:45:37 2016
@@ -616,61 +616,7 @@
$content = $this->cal_prefs[‘saved_states’];
$content[‘view’] = $this->view ? $this->view : ‘week’;
$content[‘date’] = $this->date ? $this->date : egw_time();
$owners = $this->owner ? is_array($this->owner) ? array($this->owner) : explode(',',$this->owner) : array($GLOBALS['egw_info']['user']['account_id']);
$sel_options = array('owner' => array());
$sel_options['owner'] = array_map(
return array(
$linked_owners = array();
foreach($owners as &$owner)
$owner = ''.$owner;
$resource = $this->bo->resources[substr($owner, 0,1)];
else
continue;
$sel_options['owner'][] = array('value' => $owner, 'label' => $label, 'app' => lang($resource['app']));
if($linked_owners)
// Send them to link registry too
egw_json_response::get()->call('egw.link_title_callback',$linked_owners);
$readonlys = array();
$sel_options['status_filter'] = array(
array('value' => 'default', 'label' => lang('Not rejected'), 'title' => lang('Show all status, but rejected')),
— trunk/calendar/inc/class.calendar_uiforms.inc.php (original)
+++ trunk/calendar/inc/class.calendar_uiforms.inc.php Thu Feb 18 20:45:37 2016
@@ -2942,75 +2942,6 @@
- public function ajax_owner()
$results = [];
if($query)
$resources = array_merge(array('' => $this->bo->resources['']),$this->bo->resources);
$mapped = array();
if($type == '')
if($id && $title)
$value = [
'id' => $type.$id,
'label' => $title,
$mapped[] = $value;
if(count($mapped))
common::egw_exit();
- imports a mail as Calendar
- @param array $mailContent = null mail content
— trunk/calendar/js/et2_widget_owner.js (original)
+++ trunk/calendar/js/et2_widget_owner.js Thu Feb 18 20:45:37 2016
@@ -29,7 +29,7 @@
attributes: {
“autocomplete_url”: {
@@ -90,4 +90,4 @@
return this.taglist.getValue();
-et2_register_widget(et2_calendar_owner, [“calendar_owner”]);
+et2_register_widget(et2_calendar_owner, [“calendar-owner”]);
— trunk/calendar/templates/default/export_csv_select.xet (original)
+++ trunk/calendar/templates/default/export_csv_select.xet Thu Feb 18 20:45:37 2016
@@ -38,7 +38,7 @@
— trunk/calendar/templates/default/sidebox.xet (original)
+++ trunk/calendar/templates/default/sidebox.xet Thu Feb 18 20:45:37 2016
@@ -27,7 +27,7 @@
eGroupWare-cvs mailing list
