Author: nathangray
New Revision: 55124
URL: http://svn.stylite.de/viewvc/egroupware?rev=55124&view=rev
Get calendar home less broken
- Fix actions missing on home reload
- Fix full reload on home reload
- Fix calendar reload removed home events
trunk/calendar/inc/class.calendar_favorite_portlet.inc.php
trunk/calendar/inc/class.calendar_uiviews.inc.php
trunk/calendar/js/app.js
trunk/calendar/js/calendar_favorite_portlet.js
trunk/calendar/js/et2_widget_event.js
trunk/calendar/js/et2_widget_planner.js
trunk/calendar/js/et2_widget_timegrid.js
trunk/egroupware/home/inc/class.home_favorite_portlet.inc.php
trunk/egroupware/home/js/app.js
— trunk/calendar/inc/class.calendar_favorite_portlet.inc.php (original)
+++ trunk/calendar/inc/class.calendar_favorite_portlet.inc.php Tue Feb 23 22:29:13 2016
@@ -58,6 +58,9 @@
public function exec($id = null, etemplate_new &$etemplate = null)
// Always load app's javascript, so most actions have a chance of working
egw_framework::validate_file('.','app',$this->context['appname']);
// Always load app's css
egw_framework::includeCSS('calendar', 'app-'.$GLOBALS['egw_info']['user']['preferences']['common']['theme']) ||
egw_framework::includeCSS('calendar','app');
@@ -86,8 +89,6 @@
$etemplate->read(‘home.legacy’);
$etemplate->set_dom_id($id);
egw_framework::validate_file('','app',$this->context['appname']);
$content = array('legacy' => '');
@@ -143,7 +144,7 @@
$this->favorite[‘state’][‘view’] == ‘day’ ? 1 : 4
$this->actions =& $etemplate->getElementAttribute(‘view’, ‘actions’);
— trunk/calendar/inc/class.calendar_uiviews.inc.php (original)
+++ trunk/calendar/inc/class.calendar_uiviews.inc.php Tue Feb 23 22:29:13 2016
@@ -612,12 +612,18 @@
$search_params[‘start’] = $week_start->format(‘ts’);
$search_params[‘end’] = $week_end->format(‘ts’);
$content['view'][] = (array)$this->tagWholeDayOnTop($this->bo->search($search_params)) +
array(
'id' => $week_start->format('Ymd')
$home->setElementAttribute("view[$week]",'onchange',false);
$home->setElementAttribute("view[$week]",'granularity',$granularity);
$home->setElementAttribute("view[$week]",'show_weekend', $this->search_params['weekend']);
$week++;
// Get the actions
$home->setElementAttribute('view','actions',$this->get_actions());
$home->exec(__METHOD__, $content);
— trunk/calendar/js/app.js (original)
+++ trunk/calendar/js/app.js Tue Feb 23 22:29:13 2016
@@ -74,6 +74,9 @@
// Calendar allows other apps to hook into the sidebox. We keep these etemplates
// up to date as state is changed.
sidebox_hooked_templates: [],
// List of queries in progress, to prevent home from requesting the same thing
_queries_in_progress: [],
- Constructor
@@ -2724,6 +2727,14 @@
// Show ajax loader
framework.applications.calendar.sidemenuEntry.showAjaxLoader()
// Already in progress?
var query_string = JSON.stringify(query);
if(this._queries_in_progress.indexOf(query_string) != -1)
return;
this._queries_in_progress.push(query_string);
this.egw.dataFetch(
instance ? instance.etemplate_exec_id :
this.sidebox_et2.getInstanceManager().etemplate_exec_id,
@@ -2731,7 +2742,13 @@
query,
this.id,
function calendar_handleResponse(data) {
var idx = this._queries_in_progress.indexOf(query_string);
if(idx >= 0)
this._queries_in_progress.splice(idx,1);
//console.log(data);
// Look for any updated select options
if(data.rows && data.rows.sel_options && this.sidebox_et2)
— trunk/calendar/js/calendar_favorite_portlet.js (original)
+++ trunk/calendar/js/calendar_favorite_portlet.js Tue Feb 23 22:29:13 2016
@@ -27,38 +27,47 @@
// List view, we can just update it
this.portlet.getWidgetById(‘nm’).refresh(_id,_type);
- else if (_id)
// Calendar app should handle it in its observer()
- else if (app.classes.calendar && app.calendar)
// No ID, probably a refresh of app. Calendar will discard the cache.
// Only make a request if:
// - portlet date range is outside calendar state range
// - portlet owner is not in calendar state owner
// Otherwise, we'll kill the connection with several overlapping requests
var value = [];
var state = this.portlet.options.settings.favorite.state;
if(state.owner == 0) state.owner = [egw.user('account_id')];
this.portlet.iterateOver(function(view) {
value.push({
owner: view.options.owner,
start_date: view.options.start_date,
end_date: view.options.end_date
state.first = !state.first || state.first > view.options.start_date ? view.options.start_date : state.first;
state.last = !state.last || state.last < view.options.end_date ? view.options.end_date : state.last;
},this, et2_calendar_view);
if(state.first < new Date(app.calendar.state.first) || state.last > new Date(app.calendar.state.last) ||
state.owner != app.calendar.state.owner)
app.calendar.et2 = this.portlet._children[0]
app.calendar._need_data(value, state);
else
// No intelligence since we don't have access to the state
// (app.calendar.getState() is for the calendar tab, not home)
// just refresh on every calendar or infolog change
if(_app == 'calendar' || _app == 'infolog')
var new_cache_id = app.classes.calendar._daywise_cache_id(
event.data.date,
// Make sure to use the right owner, not current calendar state
this.portlet.settings.favorite.state.owner || ''
var daywise = egw.dataGetUIDdata(new_cache_id);
daywise = daywise ? daywise.data : [];
if(_type === 'delete')
daywise.splice(daywise.indexOf(_id),1);
else if (daywise.indexOf(_id) < 0)
daywise.push(_id);
egw.dataStoreUID(new_cache_id,daywise);
else
app.home.refresh(this.portlet.id);
— trunk/calendar/js/et2_widget_event.js (original)
+++ trunk/calendar/js/et2_widget_event.js Tue Feb 23 22:29:13 2016
@@ -235,7 +235,19 @@
// Copy actions set in parent
var action_parent = this;
while(action_parent != null && !action_parent.options.actions &&
!action_parent.instanceOf(et2_container)
action_parent = action_parent.getParent();
try {
this._link_actions(action_parent.options.actions||{});
} catch (e) {
// something went wrong, but keep quiet about it
debugger;
// Make sure category stuff is there
// Fake it to use the cache / call - if already there, these will return
@@ -853,7 +865,7 @@
// objects
this._actionObject = objectManager.insertObject(false, new egwActionObject(
‘calendar::’+this.options.value.row_id, objectManager, new et2_event_action_object_impl(this,this.getDOMNode()),
— trunk/calendar/js/et2_widget_planner.js (original)
+++ trunk/calendar/js/et2_widget_planner.js Tue Feb 23 22:29:13 2016
@@ -732,7 +732,7 @@
this.widget.update_timer = null;
this.widget.doInvalidate = true;
window.setTimeout(jQuery.proxy(function() {if(this.loader) this.loader.hide();},this.widget),100);
},{widget:this,"trigger":trigger}),ET2_GRID_INVALIDATE_TIMEOUT);
— trunk/calendar/js/et2_widget_timegrid.js (original)
+++ trunk/calendar/js/et2_widget_timegrid.js Tue Feb 23 22:29:13 2016
@@ -950,6 +950,8 @@
_scroll: function(event)
if(!this.day_widgets) return;
// Loop through days, let them deal with it
for(var day = 0; day < this.day_widgets.length; day++)
@@ -1013,7 +1015,7 @@
for(var i = 0; i < parent.children.length; i++)
@@ -1303,7 +1305,7 @@
* necessarily an entry from the resource app), or a list containing a
* combination of both.
- set_value: function(events)
- set_value: function set_value(events)
if(typeof events !== ‘object’) return false;
@@ -1328,26 +1330,35 @@
this.set_start_date(day_list[0]);
this.set_end_date(day_list[day_list.length-1]);
// Sub widgets actually get their own data from egw.data, so we'll
// stick it there
var consolidated = et2_calendar_view.is_consolidated(this.options.owner, this.day_list.length == 1 ? 'day' : 'week');
for(var day in events)
var day_list = [];
for(var i = 0; i < events[day].length; i++)
day_list.push(events[day][i].row_id);
egw.dataStoreUID('calendar::'+events[day][i].row_id, events[day][i]);
// We need to check if we're attached already, as the datastore can cause
// conflicts across other events (especially home) if we call it too early
if(this.isAttached())
// stick it there
var day_list = [];
// Might be split by user, so we have to check that too
for(var i = 0; i < this.options.owner.length; i++)
var owner = consolidated ? this.options.owner : this.options.owner[i];
var day_id = app.classes.calendar._daywise_cache_id(day,owner);
egw.dataStoreUID(day_id, day_list);
if(consolidated) break;
else
this.value = events;
@@ -1781,9 +1792,10 @@
this.options.height = Math.max(this.options.height, needed);
// Set all others to match
if(!_too_small && rowCount > 1 && this._parent)
if(!this._parent) return;
this._parent.iterateOver(function(widget) {
if(!widget.disabled) widget.resize(true);
},this, et2_calendar_timegrid);
— trunk/egroupware/home/inc/class.home_favorite_portlet.inc.php (original)
+++ trunk/egroupware/home/inc/class.home_favorite_portlet.inc.php Tue Feb 23 22:29:13 2016
@@ -125,7 +125,7 @@
egw_framework::includeCSS($this->context[‘appname’],‘app’);
— trunk/egroupware/home/js/app.js (original)
+++ trunk/egroupware/home/js/app.js Tue Feb 23 22:29:13 2016
@@ -157,13 +157,15 @@
// Check for existing etemplate, this one loaded over it
// NOTE: Moving them around like this can cause problems with event handlers
var existing = etemplate2.getById(et2.uniqueId);
eGroupWare-cvs mailing list
