Author: nathangray
New Revision: 55127
URL: http://svn.stylite.de/viewvc/egroupware?rev=55127&view=rev
Avoid permission errors by doing nothing when user clicks on event they have no permission to view
trunk/calendar/js/et2_widget_timegrid.js
trunk/calendar/templates/default/app.css
trunk/calendar/templates/pixelegg/app.less
— trunk/calendar/js/et2_widget_timegrid.js (original)
+++ trunk/calendar/js/et2_widget_timegrid.js Tue Feb 23 23:23:01 2016
@@ -1595,7 +1595,11 @@
result = this.onclick.apply(this, args);
var event_node = $j(event.event_node);
if(event.id && result && !this.disabled && !this.options.readonly &&
// Permissions - opening will fail if we try
event_node && !(event_node.hasClass('rowNoView'))
if(event.widget_id && this.getWidgetById(event.widget_id))
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Tue Feb 23 23:23:01 2016
@@ -584,7 +584,7 @@
background-color: #808080;
-.calendar_calEvent:hover{
+.calendar_calEvent:not(.rowNoView):hover{
cursor: pointer;
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Tue Feb 23 23:23:01 2016
@@ -586,7 +586,7 @@
border-color: #808080;
-.calendar_calEvent:hover {
+.calendar_calEvent:not(.rowNoView):hover {
cursor: pointer;
/** Multi-line ellipsis */
@@ -1970,9 +1970,6 @@
* background: depending on category (shade)
background-color: #679fd2;
- cursor: pointer;
.calendar_calEvent:not([class*=" cat_"]) {
/* Defaults for no category, so we don’t override it */
— trunk/calendar/templates/pixelegg/app.less (original)
+++ trunk/calendar/templates/pixelegg/app.less Tue Feb 23 23:23:01 2016
@@ -867,9 +867,6 @@
background-color: @egw_color_blue_lightest;
- cursor: pointer;
eGroupWare-cvs mailing list
