Author: ralfbecker
New Revision: 55142
URL: http://svn.stylite.de/viewvc/egroupware?rev=55142&view=rev
do not wrap progress widget in an a tag and install click handler, if there is no href
trunk/etemplate/js/et2_widget_progress.js
— trunk/etemplate/js/et2_widget_progress.js (original)
+++ trunk/etemplate/js/et2_widget_progress.js Thu Feb 25 14:12:25 2016
@@ -120,17 +120,26 @@
this.options.href = _value;
var href = this.options.href;
var popup = this.options.extra_link_popup;
var target = this.options.extra_link_target;
jQuery(this.node).parent().click(function(e)
egw.open_link(href,target,popup);
e.preventDefault();
return false;
else if (jQuery(this.node).parent('a').length)
eGroupWare-cvs mailing list
