Author: ralfbecker
New Revision: 55153
URL: http://svn.stylite.de/viewvc/egroupware?rev=55153&view=rev
show no more lines and left/down triangles instead of plus/minus in tree
Added:
trunk/phpgwapi/templates/default/images/dhtmlxtree/minus.png (with props)
trunk/phpgwapi/templates/default/images/dhtmlxtree/plus.png (with props)
trunk/etemplate/js/et2_widget_tree.js
— trunk/etemplate/js/et2_widget_tree.js (original)
+++ trunk/etemplate/js/et2_widget_tree.js Thu Feb 25 20:29:56 2016
@@ -220,12 +220,12 @@
if (widget.options.autoloading)
var url = widget.options.autoloading;
@@ -242,6 +242,11 @@
// Enable/Disable highlighting
widget.input.enableHighlighting(widget.options.highlighting?true:false);
// show no more lines and left/down triangles instead of plus/minus
widget.input.enableTreeLines(false);
widget.input.setImageArrays('plus', 'plus.png', 'plus.png', 'plus.png', 'plus.png', 'plus.png');
widget.input.setImageArrays('minus', 'minus.png', 'minus.png', 'minus.png', 'minus.png', 'minus.png');
@@ -405,7 +410,7 @@
this.input.setCheck(this.value[i], true);
// autoloading openning needs to be absolutely based on user interaction
@@ -478,7 +483,7 @@
var allUnchecked = this.input.getAllUnchecked().split(this.input.dlmtr);
if (this.options.autoloading)
Binary file - no diff available.
Propchange: trunk/phpgwapi/templates/default/images/dhtmlxtree/minus.png
svn:mime-type = image/png
Propchange: trunk/phpgwapi/templates/default/images/dhtmlxtree/plus.png
eGroupWare-cvs mailing list
