Author: hnategh
New Revision: 55168
URL: http://svn.stylite.de/viewvc/egroupware?rev=55168&view=rev
Mobile theme W.I.P.:
- Add some SVG icons
- Fix devices with smaller screen do not show the sidemenu
- Remove not used SVGs
- Fix nextmatch header icons
Added:
trunk/pixelegg/images/apply.png
- copied unchanged from r55158, trunk/pixelegg/images/export.png
trunk/pixelegg/images/apply.svg
- copied, changed from r55140, trunk/pixelegg/images/save.svg
trunk/pixelegg/images/attach.svg
trunk/pixelegg/images/edit.svg
trunk/pixelegg/images/favorites.svg
- copied, changed from r55167, trunk/pixelegg/images/star.svg
trunk/pixelegg/images/list_alt.svg
trunk/pixelegg/images/lock.svg
trunk/pixelegg/images/plus.svg
trunk/pixelegg/images/save_new.svg
trunk/pixelegg/images/setup.svg
trunk/pixelegg/images/tag_message.svg
trunk/pixelegg/images/topmenu_items/mobile/check.svg
trunk/pixelegg/images/topmenu_items/mobile/menu_active.svg
trunk/pixelegg/images/topmenu_items/mobile/plus_white.svg
Removed:
trunk/pixelegg/images/E-Mail.svg
trunk/pixelegg/images/addressbook.svg
trunk/pixelegg/images/admin.svg
trunk/pixelegg/images/menu_list_round.svg
trunk/pixelegg/images/tracker.svg
trunk/pixelegg/images/wiki.svg
trunk/pixelegg/css/mobile.css
trunk/pixelegg/css/pixelegg.css
trunk/pixelegg/images/dots.svg
trunk/pixelegg/images/menu_list.svg
trunk/pixelegg/images/topmenu_items/mobile/back.svg
trunk/pixelegg/images/topmenu_items/mobile/menu.svg
trunk/pixelegg/less/def_buttons.less
trunk/pixelegg/mobile/fw_mobile.css
trunk/pixelegg/mobile/fw_mobile.less
— trunk/pixelegg/css/mobile.css (original)
+++ trunk/pixelegg/css/mobile.css Fri Feb 26 13:04:24 2016
@@ -2179,7 +2179,7 @@
button[id=“displayToolbar-delete”],
button.et2_button_delete {
/background-color: @color_negative_action_hover !important;/
- background-image: url(’…/images/delete.png’) !important;
- background-image: url(’…/images/delete.png’);
margin-left: 3em;
/.border_normal;/
/.box_shadow_standard_light;/
@@ -4368,7 +4368,7 @@
padding: 0px 0px 0px 15px;
line-height: 1em;
font-size: 12.1px;
- background-image: url(…/images/arrow_left.png);
- background-image: url(…/images/arrow_right.png);
background-repeat: no-repeat;
background-position: left center;
@@ -4400,7 +4400,7 @@
/.background-clip(padding-box);/
#egw_fw_sidebar #egw_fw_sidemenu .egw_fw_ui_scrollarea_outerdiv .egw_fw_ui_sidemenu_entry_content .egw_fw_ui_category_active h1 {
- background-image: url(…/images/arrow_down.png);
- background-image: url(…/images/arrow_down_white.png);
line-height: 1em;
font-size: 12px;
— trunk/pixelegg/css/pixelegg.css (original)
+++ trunk/pixelegg/css/pixelegg.css Fri Feb 26 13:04:24 2016
@@ -2168,7 +2168,7 @@
margin-left: 3em;
/.border_normal;/
@@ -3763,7 +3763,7 @@
text-decoration: none;
height: 32px;
/font-size: 1.1em;/
- font-size: 12.100000000000001px;
- font-size: 12.1px;
line-height: 1.5em;
#egw_fw_header #egw_fw_topmenu #egw_fw_topmenu_items ul li a:hover {
@@ -3787,7 +3787,7 @@
#egw_fw_header #egw_fw_topmenu #egw_fw_topmenu_items ul a#topmenu_home:before {
padding-right: 20px;
content: " ";
background-image: url(…/images/topmenu_items/home.png);
@@ -4185,7 +4185,7 @@
padding-left: 3em;
color: #999999;
/font-size: 12px;/
line-height: 17px;
#egw_fw_sidebar #egw_fw_sidemenu .egw_fw_ui_scrollarea_outerdiv .egw_fw_ui_sidemenu_entry_header object {
@@ -4356,7 +4356,7 @@
margin: 5px 0px 3px 5px;
line-height: 1em;
— trunk/pixelegg/images/save.svg (original)
+++ trunk/pixelegg/images/apply.svg Fri Feb 26 13:04:24 2016
@@ -2,11 +2,11 @@
<?xml-stylesheet type="text/css" href="../less/svg.css" ?>
-<svg version=“1.1” id=“pixelegg_save” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" d="M9.454,26.628h13.092v-1.062H9.454V26.628z M23.515,1.12H1.816
v29.76h28.368V7.57L23.515,1.12z M8.362,3.245h8.729V8.56h4.364V3.245h2.183v7.44H8.362V3.245z M26.91,28.754H5.089v-8.503
c0-1.761,1.465-3.188,3.273-3.188h15.275c1.807,0,3.272,1.428,3.272,3.188V28.754z M9.454,23.44h13.092v-1.063H9.454V23.44z
M9.454,20.251h13.092v-1.062H9.454V20.251z"/>
— trunk/pixelegg/images/attach.svg (added)
+++ trunk/pixelegg/images/attach.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,17 @@
+<?xml version="1.0" encoding="utf-8"?>
+<?xml-stylesheet type="text/css" href="../less/svg.css" ?>
+<svg version=“1.1” id=“pixelegg_attach” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
- width=“32px” height=“32px” viewBox=“0 0 32 32” enable-background=“new 0 0 32 32” xml:space=“preserve”>
+<path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" stroke="#e6e6e6" stroke-miterlimit=“10” d="M15.824,28.57
- c-3.363,3.313-8.773,3.3-12.117-0.045c-3.343-3.345-3.356-8.753-0.045-12.118L3.66,16.406L14.307,5.76l1.521-1.521l1.521-1.521
- c2.519-2.52,6.606-2.52,9.126,0c2.521,2.52,2.521,6.605,0,9.126l-1.521,1.52l-1.521,1.521l-5.336,5.337l-1.917,1.914l-3.394,3.396
- l-0.004-0.004c-1.684,1.63-4.368,1.62-6.031-0.044c-1.664-1.662-1.674-4.348-0.042-6.03l-0.005-0.006l1.521-1.521l1.873-1.872
- l1.917-1.916l2.294-2.293l1.785-1.787l1.725-1.725l1.053-1.052l1.521,1.521l-1.475,1.473l-1.568,1.569l-3.193,3.193l-1.643,1.642
- l-1.622,1.623l-1.147,1.145L8.223,20.97c-0.84,0.838-0.84,2.2,0,3.041c0.84,0.84,2.202,0.84,3.042,0l2.667-2.667l1.623-1.622
- l1.642-1.642l1.673-1.674l2.689-2.688l0.353-0.354l1.521-1.52l1.521-1.521l-0.004-0.004c0.016-0.015,0.036-0.027,0.053-0.043
- c1.679-1.68,1.679-4.404,0-6.083c-1.681-1.68-4.404-1.68-6.085,0c-0.015,0.016-0.028,0.035-0.044,0.051l-0.003-0.003l-1.521,1.521
- l-1.52,1.521l-0.353,0.353l-2.69,2.689l-3.542,3.542l-4.062,4.061c-2.52,2.521-2.52,6.606,0,9.127c2.521,2.521,6.606,2.521,9.126,0
- l4.062-4.062l9.625-9.626l1.52-1.52l1.522,1.52l-1.522,1.521L15.828,28.572L15.824,28.57z"/>
— trunk/pixelegg/images/dots.svg (original)
+++ trunk/pixelegg/images/dots.svg Fri Feb 26 13:04:24 2016
@@ -4,10 +4,8 @@
<polygon fill="#696969" stroke="#E6E6E6" stroke-miterlimit="10" points="29.007,9.38 22.886,3.496 16,10.116 9.114,3.496
2.994,9.38 9.879,16 2.994,22.62 9.114,28.504 16,21.884 22.886,28.504 29.007,22.62 22.121,16 "/>
+<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit=“10” d="M19.864,27.721c0,1.911-1.55,3.459-3.459,3.459
- c-1.91,0-3.458-1.548-3.458-3.459c0-1.907,1.548-3.457,3.458-3.457C18.314,24.264,19.864,25.813,19.864,27.721z"/>
— trunk/pixelegg/images/edit.svg (added)
+++ trunk/pixelegg/images/edit.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,13 @@
+<svg version=“1.1” id=“Ebene_1” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="none" stroke="#62686A" stroke-miterlimit="10" d="M5.492,19.1l6.897,6.894l12.853-12.846l-6.897-6.894L5.492,19.1z
M1,30.485l9.655-2.757l-6.896-6.895L1,30.485z M29.994,5.81l-4.311-4.308c-0.713-0.714-1.911-0.675-2.673,0.085l-2.842,2.841
l6.896,6.894l2.843-2.841C30.671,7.719,30.709,6.524,29.994,5.81z"/>
— trunk/pixelegg/images/star.svg (original)
+++ trunk/pixelegg/images/favorites.svg Fri Feb 26 13:04:24 2016
@@ -4,7 +4,7 @@
-<path fill-rule=“evenodd” clip-rule=“evenodd” fill="#696969" stroke="#E6E6E6" stroke-miterlimit=“10” d="M30.194,12.042
— trunk/pixelegg/images/list_alt.svg (added)
+++ trunk/pixelegg/images/list_alt.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,13 @@
+<svg version=“1.1” id=“pixelegg_list_alt” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-width="0.75" stroke-miterlimit="10" d="M1.736,1v4.554h28.975V1H1.736z M1.736,18.275
h28.975v-4.553H1.736V18.275z M1.736,31h28.975v-4.554H1.736V31z"/>
— trunk/pixelegg/images/lock.svg (added)
+++ trunk/pixelegg/images/lock.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,18 @@
+<svg version=“1.1” id=“pixelegg_lock” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" d="M25.308,14.912h-0.962V7.272c0-3.692-3.442-6.685-7.688-6.685
S8.968,3.58,8.968,7.272v7.639H8.007c-1.592,0-2.883,1.283-2.883,2.865v10.505c0,1.581,1.292,2.865,2.883,2.865h17.301
c1.591,0,2.883-1.284,2.883-2.865V17.776C28.19,16.194,26.898,14.912,25.308,14.912z M18.578,24.888v1.483
c0,1.055-0.859,1.91-1.921,1.91c-1.062,0-1.923-0.855-1.923-1.91v-1.484c-1.144-0.661-1.922-1.879-1.922-3.289
c0-2.109,1.722-3.821,3.845-3.821c2.122,0,3.844,1.712,3.844,3.821C20.501,23.008,19.723,24.227,18.578,24.888z M20.501,13.957
c0,0.336-0.093,0.655-0.235,0.955h-7.218c-0.143-0.3-0.235-0.619-0.235-0.955V7.272c0-1.583,1.722-2.865,3.845-2.865
c2.122,0,3.844,1.282,3.844,2.865V13.957z"/>
— trunk/pixelegg/images/menu_list.svg (original)
+++ trunk/pixelegg/images/menu_list.svg Fri Feb 26 13:04:24 2016
@@ -2,24 +2,18 @@
-<svg version=“1.1” id=“pixelegg_next_match” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-width="0.75" stroke-miterlimit="10" d="M7.902,1v4.554h22.809V1H7.902z M7.902,18.275
h22.809v-4.553H7.902V18.275z M7.902,31h22.809v-4.555H7.902V31z"/>
— trunk/pixelegg/images/plus.svg (added)
+++ trunk/pixelegg/images/plus.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,13 @@
+<svg version=“1.1” id=“pixelegg_plus” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" d="M31.31,19.861H19.959v11.347h-7.562V19.861H1.052v-7.562h11.345
V0.955h7.562v11.344H31.31V19.861z"/>
+++ trunk/pixelegg/images/save.svg Fri Feb 26 13:04:24 2016
@@ -6,10 +6,13 @@
<path fill="#696969" stroke="#E6E6E6" stroke-miterlimit="10" d="M9.454,26.628h13.092v-1.062H9.454V26.628z M23.515,1.12H1.816
<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" d="M9.315,26.748h13.092v-1.062H9.315V26.748z M22.407,22.496H9.315
v1.064h13.092V22.496z M23.039,16.84c4.612,0,8.353-3.545,8.353-7.919c0-4.373-3.74-7.917-8.353-7.917
c-4.613,0-8.353,3.545-8.353,7.917C14.686,13.294,18.426,16.84,23.039,16.84z M18.11,6.118l1.972-1.869l2.957,2.804l2.958-2.804
l1.971,1.869l-2.957,2.803l2.957,2.803l-1.971,1.869l-2.958-2.804l-2.957,2.804l-1.972-1.869l2.958-2.803L18.11,6.118z
M26.772,20.371v8.502H4.951v-8.502c0-1.762,1.465-3.189,3.273-3.189h7.866c-2.067-1.564-3.529-3.808-4.017-6.376H8.224v-7.44
h5.339c0.512-0.783,1.125-1.497,1.829-2.125H1.678V31h28.367V17.143c-1.06,0.812-2.279,1.445-3.607,1.848
C26.646,19.41,26.772,19.873,26.772,20.371z M22.407,19.463c-0.479-0.025-0.952-0.074-1.414-0.154H9.315v1.062h13.092V19.463z"/>
— trunk/pixelegg/images/save_new.svg (added)
+++ trunk/pixelegg/images/save_new.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,18 @@
+<svg version=“1.1” id=“pixelegg_save_new” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
v1.064h13.092V22.496z M23.039,16.84c4.611,0,8.354-3.545,8.354-7.919c0-4.373-3.74-7.917-8.354-7.917s-8.353,3.545-8.353,7.917
C14.686,13.294,18.426,16.84,23.039,16.84z M21.405,2.968l2.951,0.08l0.116,4.424l4.426,0.118l0.077,2.949l-4.422-0.118
l0.117,4.423l-2.948-0.079l-0.119-4.425l-4.423-0.117l-0.079-2.951l4.424,0.12L21.405,2.968z M26.771,20.371v8.502H4.951v-8.502
c0-1.762,1.465-3.189,3.273-3.189h7.866c-2.067-1.563-3.529-3.808-4.017-6.375H8.224v-7.44h5.339
c0.512-0.783,1.125-1.497,1.829-2.125H1.678V31h28.367V17.143c-1.061,0.812-2.279,1.445-3.607,1.849
C26.646,19.41,26.771,19.873,26.771,20.371z M22.407,19.463c-0.479-0.025-0.952-0.074-1.414-0.154H9.315v1.062h13.092V19.463z"/>
— trunk/pixelegg/images/setup.svg (added)
+++ trunk/pixelegg/images/setup.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,29 @@
+<svg version=“1.1” id=“pixelegg_setup” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" d="M27.114,11.493c1.295-3.006,1.63-3.999,0.526-5.111l-2.021-2.006
c-0.396-0.395-0.959-0.628-1.518-0.628c-0.377,0-0.767,0-3.553,1.264c-1.219-3.064-1.68-4.007-3.202-4.007h-2.86
c-1.505,0-1.958,0.852-3.137,4.026C8.516,3.834,8.119,3.834,7.764,3.834c-0.559,0-1.125,0.233-1.513,0.623L4.224,6.472
c-1.131,1.132-0.742,2.193,0.589,5.074c-3.122,1.238-3.985,1.667-3.985,3.23v2.853c0,1.602,0.946,2.045,4.009,3.167
c-1.292,3.003-1.626,3.996-0.526,5.103l2.014,2.008c0.392,0.396,0.964,0.635,1.525,0.635c0.374,0,0.763,0,3.552-1.265
c1.222,3.063,1.679,4.01,3.205,4.01h2.86c1.505,0,1.96-0.855,3.141-4.03c2.835,1.201,3.232,1.201,3.585,1.201
c0.557,0,1.119-0.234,1.513-0.623l2.039-2.028c1.118-1.133,0.729-2.194-0.601-5.062c3.043-1.21,3.981-1.674,3.981-3.233v-2.851
C31.124,13.054,30.178,12.616,27.114,11.493z M28.662,17.339c-0.603,0.352-2.314,1.024-3.006,1.299l-0.487,0.195l-0.771,1.869
l0.234,0.501c0.276,0.594,1.053,2.261,1.254,2.939L24.1,25.928c-0.271-0.075-1.033-0.328-3.063-1.203l-0.467-0.204l-1.867,0.771
l-0.192,0.51c-0.225,0.621-0.866,2.363-1.207,2.975h-2.541c-0.347-0.592-1.023-2.298-1.298-2.986l-0.195-0.492l-1.866-0.768
l-0.481,0.222c-2.013,0.928-2.75,1.189-2.981,1.263L6.15,24.23c0.181-0.678,0.903-2.346,1.196-3.021l0.215-0.494L6.788,18.85
l-0.509-0.185c-0.686-0.249-2.383-0.868-2.99-1.204v-2.521c0.593-0.34,2.249-0.993,3.004-1.293l0.488-0.191l0.773-1.867
L7.32,11.083c-0.279-0.595-1.053-2.264-1.253-2.945L7.853,6.36c0.27,0.073,1.032,0.325,3.069,1.2l0.468,0.203l1.862-0.768
l0.189-0.515c0.225-0.62,0.866-2.358,1.205-2.975h2.543c0.345,0.594,1.022,2.298,1.296,2.989l0.194,0.491l1.865,0.769l0.482-0.223
c2.015-0.929,2.749-1.19,2.982-1.261l1.791,1.781c-0.18,0.674-0.905,2.344-1.195,3.021l-0.215,0.496l0.776,1.87l0.506,0.184
c0.687,0.251,2.38,0.868,2.989,1.201V17.339z M15.977,11.636c-2.493,0-4.521,2.022-4.521,4.508c0,2.487,2.028,4.51,4.521,4.51
s4.521-2.023,4.521-4.51C20.497,13.659,18.47,11.636,15.977,11.636z M15.977,18.151c-1.137,0-2.064-0.901-2.064-2.007
c0-1.105,0.927-2.005,2.064-2.005c1.138,0,2.062,0.9,2.062,2.005C18.039,17.25,17.114,18.151,15.977,18.151z"/>
— trunk/pixelegg/images/tag_message.svg (added)
+++ trunk/pixelegg/images/tag_message.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,16 @@
+<svg version=“1.1” id=“pixelegg_tag_message” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" d="M30.682,3.215c0-1.224-0.992-2.216-2.216-2.216h-8.862
c-0.708,0-1.331,0.338-1.737,0.854l-2.072,2.072L1.562,18.157c-0.828,0.827-0.828,2.17,0,2.997l8.989,8.989
c0.828,0.826,2.169,0.826,2.996,0L27.779,15.91l2.247-2.247l-0.007-0.007c0.408-0.402,0.662-0.96,0.662-1.578V3.215z
M25.533,10.667c-1.242,1.241-3.254,1.241-4.495,0c-1.241-1.241-1.241-3.253,0-4.495c1.241-1.241,3.253-1.241,4.495,0
C26.772,7.414,26.772,9.426,25.533,10.667z"/>
— trunk/pixelegg/images/topmenu_items/mobile/back.svg (original)
+++ trunk/pixelegg/images/topmenu_items/mobile/back.svg Fri Feb 26 13:04:24 2016
@@ -1,25 +1,12 @@
-<?xml-stylesheet type="text/css" href="../../../less/svg.css" ?>
-<svg version=“1.1” id=“pixelegg_back” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<polygon fill="#FFFFFF" points="-11.008,53.88 -17.128,47.996 -24.014,54.616 -30.9,47.996 -37.021,53.88 -30.135,60.5
-37.021,67.12 -30.9,73.004 -24.014,66.384 -17.128,73.004 -11.008,67.12 -17.894,60.5 "/>
<path fill="#FFFFFF" d="M-39.014,11.14v6.521h30V11.14H-39.014z M-39.014,29.401h30v-6.522h-30V29.401z M-39.014,41.14h30v-6.521
h-30V41.14z"/>
<polygon fill="#FFFFFF" points="29.569,13.938 12.236,13.938 12.236,10.889 1.236,16 12.236,21.111 12.236,18.062 29.569,18.062
<polygon fill="#FFFFFF" stroke="#FFFFFF" stroke-miterlimit="10" points="30.875,12.857 12.833,12.857 12.833,3.11 1.833,16.096
12.833,29.083 12.833,19.169 30.875,19.169 "/>
— trunk/pixelegg/images/topmenu_items/mobile/check.svg (added)
+++ trunk/pixelegg/images/topmenu_items/mobile/check.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,10 @@
+<path fill-rule=“evenodd” clip-rule=“evenodd” fill="#FFFFFF" stroke="#FFFFFF" stroke-miterlimit=“10” d="M6.943,28.453
- c0.906,0.765,2.097,1.127,3.286,1.109c0.43,0.014,0.852-0.068,1.265-0.207c0.679-0.18,1.328-0.45,1.866-0.902L29.403,14.9
- c1.772-1.498,1.772-3.925,0-5.422c-1.772-1.497-4.646-1.497-6.418,0L10.119,20.349l-2.389-2.424c-1.44-1.457-3.772-1.457-5.212,0
- c-1.438,1.46-1.438,3.825,0,5.281C2.518,23.206,5.474,26.947,6.943,28.453z"/>
— trunk/pixelegg/images/topmenu_items/mobile/menu.svg (original)
+++ trunk/pixelegg/images/topmenu_items/mobile/menu.svg Fri Feb 26 13:04:24 2016
@@ -1,13 +1,12 @@
-<svg version=“1.1” id=“pixelegg_menu” xmlns=“http://www.w3.org/2000/svg” xmlns:xlink=“http://www.w3.org/1999/xlink” x=“0px” y=“0px”
<path fill="#FFFFFF" stroke="#FFFFFF" fill-rule="evenodd" clip-rule="evenodd" d="M1,1v6.521h30V1H1z M1,19.261h30v-6.521H1V19.261z M1,31h30
v-6.521H1V31z"/>
<path fill="#FFFFFF" stroke="#e6e6e6" stroke-width="0.75" stroke-miterlimit="10" d="M1.736,1v4.554h28.975V1H1.736z M1.736,18.275
— trunk/pixelegg/images/topmenu_items/mobile/menu_active.svg (added)
+++ trunk/pixelegg/images/topmenu_items/mobile/menu_active.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,12 @@
<polygon fill="#696969" stroke="#e6e6e6" stroke-miterlimit="10" points="30.167,10.857 12.833,10.857 12.833,3.11 1.833,16.096
12.833,29.083 12.833,21.336 30.167,21.336 "/>
— trunk/pixelegg/images/topmenu_items/mobile/plus_white.svg (added)
+++ trunk/pixelegg/images/topmenu_items/mobile/plus_white.svg Fri Feb 26 13:04:24 2016
@@ -1,0 +1,12 @@
<path fill="#FFFFFF" stroke="#FFFFFF" stroke-miterlimit="10" d="M31.31,19.861H19.959v11.347h-7.562V19.861H1.052v-7.562h11.345
— trunk/pixelegg/less/def_buttons.less (original)
+++ trunk/pixelegg/less/def_buttons.less Fri Feb 26 13:04:24 2016
@@ -130,7 +130,7 @@
.Complete_Button_delete{
- background-image:url(’…/images/delete.png’)!important;
- background-image:url(’…/images/delete.png’);
margin-left: 3em;
background-color: @gray_30;
.Complete_Button_text_icon_before;
— trunk/pixelegg/mobile/fw_mobile.css (original)
+++ trunk/pixelegg/mobile/fw_mobile.css Fri Feb 26 13:04:24 2016
@@ -2190,7 +2190,7 @@
margin-left: 3em;
/.border_normal;/
@@ -4379,7 +4379,7 @@
line-height: 1em;
font-size: 12.1px;
@@ -4411,7 +4411,7 @@
line-height: 1em;
font-size: 12px;
@@ -7026,7 +7026,7 @@
padding: 0;
-@media only screen and (max-device-width: 700px) and (min-width: 321px) {
+@media only screen and (max-device-width: 736px) and (min-width: 300px) {
body #egw_fw_basecontainer.sidebar-toggle div#egw_fw_top_toolbar {
z-index: 0;
@@ -7104,6 +7104,33 @@
body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items {
padding-top: 8px;
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_logout:before {
- background-image: url(…/images/logout.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_home:before {
- background-image: url(…/images/home.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_prefs:before {
- background-image: url(…/images/setup.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_acl:before {
- background-image: url(…/images/access.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_cats:before {
- background-image: url(…/images/tag_message.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_password:before {
- background-image: url(…/images/password.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_manual:before {
- background-image: url(…/images/help.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_topmenu_items ul li a#topmenu_search:before {
- background-image: url(…/images/topmenu_items/mobile/search.svg);
- body #egw_fw_basecontainer #egw_fw_top_toolbar div#egw_fw_menu {
- background-image: url(…/images/topmenu_items/mobile/menu_active.svg);
body #egw_fw_basecontainer #egw_fw_sidemenu img[src$=".svg"] {
background: none;
@@ -7193,15 +7220,11 @@
background-color: #0c5da5;
border: none;
box-shadow: 0px 1px 5px 3px silver;
- background-image: none !important;
- background-image: url(…/images/topmenu_items/mobile/plus_white.svg) !important;
- background-repeat: no-repeat;
- background-size: 24px 24px;
margin: 0;
padding: 0;
- body button.plus_button:after {
- content: ‘+’;
- font-weight: bold;
- font-size: 34pt;
- color: #fafafa;
body button.plus_button:hover,
body button.plus_button:active {
@@ -7321,7 +7344,7 @@
width: 50px;
body .et2_nextmatch .nm-mob-header button.nm_toggle_header {
- background-image: url(…/images/menu_list_round.svg);
- background-image: url(…/images/menu_list.svg);
background-position: center;
margin-right: 5px;
@@ -7515,7 +7538,7 @@
bottom: 0px;
right: 0;
color: white;
- background-image: url(…/images/agt_action_success.png);
- background-image: url(…/images/topmenu_items/mobile/check.svg);
height: auto;
@@ -7800,6 +7823,7 @@
margin: 0;
top: 0;
outline: none;
- z-index: 100;
body .et2_searchbox.expanded span.ui-icon.clear {
top: 0px;
— trunk/pixelegg/mobile/fw_mobile.less (original)
+++ trunk/pixelegg/mobile/fw_mobile.less Fri Feb 26 13:04:24 2016
@@ -21,9 +21,9 @@
/Tablets Max-Width/
@tablet-max: 1024px;
/Smartphones Max-Width/
-@smartphone-max: 700px;
+@smartphone-max: 736px;
/Smartphones Min-Width/
-@smartphone-min: 321px;
+@smartphone-min: 300px;
@handheld: ~“only screen and (max-device-width : @{tablet-max})”;
/All devices portrait mode/
@handheld-portrait: ~“only screen and (max-device-width : @{tablet-max}) and (orientation : portrait)”;
@@ -254,6 +254,43 @@
padding-top: 8px;
ul {
li{
a#topmenu_logout{
&:before {
background-image: url(../images/logout.svg);
background-image: url(../images/home.svg);
a#topmenu_prefs {
&:before {
background-image: url(../images/setup.svg);
background-image: url(../images/access.svg);
background-image: url(../images/tag_message.svg);
background-image: url(../images/password.svg);
background-image: url(../images/help.svg);
a#topmenu_search{
&:before {
background-image: url(../images/topmenu_items/mobile/search.svg);
div#egw_fw_menu {
background-image: url(../images/topmenu_items/mobile/menu_active.svg);
@@ -344,15 +381,11 @@
border: none;
background-image: url(../images/topmenu_items/mobile/plus_white.svg) !important;
margin: 0;
padding: 0;
@@ -477,7 +510,7 @@
width:50px;
@@ -668,7 +701,7 @@
bottom: 0px;
right: 0;
color: white;
@@ -987,6 +1020,7 @@
margin:0;
top:0;
outline: none;
eGroupWare-cvs mailing list
