Author: ralfbecker
New Revision: 55214
URL: http://svn.stylite.de/viewvc/egroupware?rev=55214&view=rev
docu update
trunk/egroupware/Gruntfile.js
— trunk/egroupware/Gruntfile.js (original)
+++ trunk/egroupware/Gruntfile.js Tue Mar 1 21:55:21 2016
@@ -9,21 +9,26 @@
- Please use only double quotes, as we parse this file as json, to update it!
- To install grunt to build minified javascript files you need to run:
grunt uglify:<target> # targets: api, et2, mail, calendar, ...
- app.js files can be added under apps target, api and et2 bundels are already there.
grunt uglify:<target> # targets: api, et2, pixelegg, mobile, mail, calendar, ...
- app.js files can be added like mail target or, if you want automatic dependencies,
- you need to add them in egw_framework::$bundle2minurl and egw_framework::get_bundles().
- To update files in Gruntfile after adding new js files you need to run:
- Please use only double quotes, as we parse this file as json to update it!
@param {object} grunt
eGroupWare-cvs mailing list
