Author: ralfbecker
New Revision: 55256
URL: http://svn.stylite.de/viewvc/egroupware?rev=55256&view=rev
copy 14.3 changelog to trunk to satisfy update checker
trunk/egroupware/doc/rpm-build/debian.changes
— trunk/egroupware/doc/rpm-build/debian.changes (original)
+++ trunk/egroupware/doc/rpm-build/debian.changes Fri Mar 4 16:17:16 2016
@@ -1,3 +1,22 @@
+egroupware-epl (14.3.20160304) hardy; urgency=low
- All apps: updated included Horde and PEAR packages (now including PEAR itself) to improve php 7.0 compatibility
- Filemanager: add ability to finally delete all old versions or deleted files from a versioned directory
- Filemanager: fix not working upload in idots template
- Filemanger: filemanager/cli.php wrongly reported wrong passwords for setup or config user with newer password hashes
- ActiveDirectory: fix creation of groups without description or removing of description of an existing group
- ActiveDirectory: fixed user who never changed his password get forced to change his password
- Bookmarks: respect Preference-Setting for defaultview (tree/list)
- Mail: fix drag and drop of folders for mail folder tree
- Mail: deny moving folders from one mailaccount to another as we are not supporting it
- Mail: fix for problem when retrieving and displaying an event from winmail.dat attachment
- EMailAdmin: new flag to allow users to change forwarding in EGroupware managed mail-servers (mandatory database update!)
- eSync: close session for ping requests to not block other requests
- PHP 5.3: fix PHP Fatal error when opening Addressbook app caused by using a PHP 5.4+ feature
- PHP 7.0: minimal support, full support will come with 16.1
- – Ralf Becker rb@stylite.de Thu, 03 Mar 2016 19:41:50 +0100
egroupware-epl (14.3.20160113) hardy; urgency=low
- All Applications: Fix missing Ckeditor in previous packages
eGroupWare-cvs mailing list
