Author: ralfbecker
New Revision: 55307
URL: http://svn.stylite.de/viewvc/egroupware?rev=55307&view=rev
work in progress styling filemanager list: having now only one row with [+] button to upload, not yet giving path all remaining space
trunk/filemanager/inc/class.filemanager_ui.inc.php
trunk/filemanager/templates/default/app.css
trunk/filemanager/templates/default/index.xet
trunk/filemanager/templates/pixelegg/app.css
— trunk/filemanager/inc/class.filemanager_ui.inc.php (original)
+++ trunk/filemanager/inc/class.filemanager_ui.inc.php Tue Mar 8 14:55:26 2016
@@ -294,7 +294,6 @@
‘parent_id’ => ‘dir’,
‘is_parent’ => ‘mime’,
‘is_parent_value’=> egw_vfs::DIR_MIME_TYPE,
'header_left' => 'filemanager.index.header_left',
'favorites' => true,
'placeholder_actions' => array('mkdir','file_drop_mail','file_drop_move','file_drop_copy','file_drop_symlink')
@@ -492,9 +491,8 @@
// Set view button to match current settings
if($content[‘nm’][‘view’] == ‘tile’)
$tpl->setElementAttribute('nm[buttons][button][change_view]','label',lang('List view'));
$tpl->setElementAttribute('nm[buttons][button][change_view]','image','list_row');
$tpl->setElementAttribute('nm[button][change_view]','statustext',lang('List view'));
$tpl->setElementAttribute('nm[button][change_view]','image','list_row');
// if initial load is done via GET request (idots template or share.php)
// get_rows cant call app.filemanager.set_readonly, so we need to do that here
— trunk/filemanager/templates/default/app.css (original)
+++ trunk/filemanager/templates/default/app.css Tue Mar 8 14:55:26 2016
@@ -11,68 +11,32 @@
- CSS for new eTemplate filemanager UI
-.mimeHuge img { width: 64px; height: 64px; }
-.fileName input { font-weight: bold; width: 100%; }
-.previewImage img { max-width: 430px; max-height: 275px; border: 1px solid black; }
-.previewText div { }
-.pathSelection { font-weight: bold; }
-.pathSelection a { font-weight: bold; font-size: 120%; }
-.pathSelectionContainer { width: 640px; overflow: auto; }
- Get path input to take all remaining width
-#filemanager-index_filemanager-index-header_left {
+select#filemanager-index_filter {
- width: 160px;
+input#filemanager-index_path {
- width: 300px;
- font-size: 150%;
- padding: 1px 5px 3px 2px;
+#filemanager-index_filemanager-index-header_right .et2_hbox > *,
+#filemanager-index_filemanager-index-header_row > *,
+#filemanager-index_filemanager-index-header_left .et2_hbox > *
float: left;
- width: 100%;
- margin-bottom: 2px;
-div.filemanager_navigation {
- position: relative;
- width: 100%;
- white-space: normal;
+#filemanager-index_filemanager-index-header_left .et2_file,
+#filemanager-index_filemanager-index-header_left .et2_file input {
- width: 24px;
-div.filemanager_navigation > * {
- vertical-align: middle;
-div.filemanager_navigation > img {
- margin-top: 3px;
-#filemanager-index_buttons {
- float: right;
-button#filemanager-index_button[change_view] {
- margin-right: 20px;
-div.filemanager_navigation > label {
- position: absolute;
- left: 56px;
- right: 456px;
- font-size: 140%;
- white-space: nowrap;
-div.filemanager_navigation > label > input {
- width: 100%;
-#filemanager-index_buttons div.et2_file {
- margin: 2px 0 0 0;
- vertical-align: top;
- padding-right: 7px;
-#filemanager-index_buttons div.et2_file span, #filemanager-index_buttons div.et2_file input {
- width: 130px;
- height: 16px;
- top: 0;
- background-position: 3px 3px;
- margin: 0;
- text-indent: 22px;
- color: #666666;
-#filemanager-index_buttons div.et2_file .progress {
- width:auto;
- margin:0;
- overflow: hidden;
- text-overflow: ellipsis;
- max-height: none;
+#filemanager-index_filemanager-index-header_left .et2_file span {
- width: 22px;
- height: 22px;
- padding: 0;
- background-position-x: 3px;
- background-image: url(…/…/…/pixelegg/images/add.png);
- overflow: hidden;
- text-indent: 100px;
— trunk/filemanager/templates/default/index.xet (original)
+++ trunk/filemanager/templates/default/index.xet Tue Mar 8 14:55:26 2016
@@ -45,25 +45,24 @@
<hbox span="all" class="filemanager_navigation">
<buttononly id="up" statustext="Up" image="goup" background_image="true" onclick="app.filemanager.change_dir('..',widget);"/>
<buttononly id="home" statustext="Go to your home directory" image="gohome" background_image="true" onclick="app.filemanager.change_dir('~',widget);"/>
<vfs-name label="Path" id="path" onchange="if(widget.getValue() == '') { app.filemanager.change_dir('~',widget);} return true;" size="80" class="address"/>
<hbox id="buttons">
<button statustext="Go to" id="button[go]" image="key_enter" background_image="true"/>
<buttononly statustext="Tile view" id="button[change_view]" onclick="app.filemanager.change_view" image="list_tile" background_image="true"/>
<buttononly statustext="Rename, change permissions or ownership" id="button[edit]" onclick="app.filemanager.editprefs();" image="edit" background_image="true"/>
<buttononly statustext="Create directory" id="button[createdir]" onclick="app.filemanager.createdir();" image="button_createdir" ro_image="createdir_disabled" background_image="true"/>
<buttononly statustext="Create a link" id="button[symlink]" onclick="app.filemanager.symlink();" image="link" ro_image="link_disabled" background_image="true"/>
<buttononly statustext="Paste" id="button[paste]" onclick="app.filemanager.paste('paste');" image="editpaste" ro_image="editpaste_disabled" background_image="true"/>
<buttononly statustext="Paste link" id="button[linkpaste]" onclick="app.filemanager.paste('linkpaste');" image="linkpaste" ro_image="linkpaste_disabled" background_image="true"/>
<buttononly statustext="Mail paste" id="button[mailpaste]" onclick="app.filemanager.paste('mailpaste');" image="mailpaste" ro_image="mailpaste_disabled" background_image="true"/>
<buttononly statustext="File a file" onclick="window.open(egw::link('/index.php','menuaction=stylite.stylite_filemanager.upload'),'_blank','dependent=yes,width=550,height=350,scrollbars=yes,status=yes');" image="upload" background_image="true"/>
<file statustext="Select file to upload in current directory" id="upload" progress_dropdownlist = "true" drop_target ="divAppbox" multiple="true" onFinishOne="app.filemanager.uploadOnOne"/>
</hbox>
</hbox>
<vfs-name id="path" onchange="if(widget.getValue() == '') { app.filemanager.change_dir('~',widget);} return true;" size="80" class="address"/>
<!--buttononly statustext="Paste" id="button[paste]" onclick="app.filemanager.paste('paste');" image="editpaste" ro_image="editpaste_disabled" background_image="true"/>
<buttononly statustext="Mail paste" id="button[mailpaste]" onclick="app.filemanager.paste('mailpaste');" image="mailpaste" ro_image="mailpaste_disabled" background_image="true"/-->
— trunk/filemanager/templates/pixelegg/app.css (original)
+++ trunk/filemanager/templates/pixelegg/app.css Tue Mar 8 14:55:26 2016
@@ -23,86 +23,31 @@
-.mimeHuge img {
- width: 64px;
- height: 64px;
-.fileName input {
- font-weight: bold;
- width: 100%;
- max-width: 430px;
- max-height: 275px;
- border: 1px solid black;
-.pathSelection {
-.pathSelection a {
- font-size: 120%;
- width: 640px;
- overflow: auto;
- width: 160px;
- width: 300px;
- font-size: 150%;
+#filemanager-index_filemanager-index-header_left .et2_hbox > * {
float: left;
- width: 100%;
- width: 100%;
- margin-top: 3px;
- float: right;
- left: 56px;
- right: 456px;
- font-size: 140%;
- width: 100%;
-#filemanager-index_buttons div.et2_file input {
- width: 130px;
- height: 16px;
- top: 0;
- margin: 0;
- color: #666666;
- width: auto;
- margin: 0;
- width: 24px;
- width: 22px;
- height: 22px;
- padding: 0;
overflow: hidden;
- max-height: none;
Click to learn more.
http://makebettercode.com/inteldaal-eval
eGroupWare-cvs mailing list
