Author: nathangray
New Revision: 55316
URL: http://svn.stylite.de/viewvc/egroupware?rev=55316&view=rev
Avoid some processing while hidden - fixes placeholders on first load when the widget is hidden
trunk/phpgwapi/js/jquery/magicsuggest/magicsuggest.js
— trunk/phpgwapi/js/jquery/magicsuggest/magicsuggest.js (original)
+++ trunk/phpgwapi/js/jquery/magicsuggest/magicsuggest.js Tue Mar 8 23:11:58 2016
@@ -966,7 +966,7 @@
$(window).resize($.proxy(handlers._onWindowResized, this));
// do not perform an initial call if we are using ajax unless we have initial values
@@ -1082,7 +1082,7 @@
ms._valueContainer.appendTo(ms.selectionContainer);
Click to learn more.
http://makebettercode.com/inteldaal-eval
eGroupWare-cvs mailing list
