Author: ralfbecker
New Revision: 55444
URL: http://svn.stylite.de/viewvc/egroupware?rev=55444&view=rev
use since 14.x unused set_box.php
Removed:
trunk/egroupware/set_box.php
trunk/egroupware/doc/rpm-build/egroupware-epl.spec
— trunk/egroupware/doc/rpm-build/egroupware-epl.spec (original)
+++ trunk/egroupware/doc/rpm-build/egroupware-epl.spec Sun Mar 20 16:25:20 2016
@@ -38,7 +38,7 @@
%else
# SLES 12 no longer sets sles_version, but suse_version == 1315: does contain broken php5-tidy, because no libtidy
%if 0%{?suse_version} == 1315
@@ -573,7 +573,6 @@
%{egwdir}/remote.php
%{egwdir}/rpc.php
%{egwdir}/share.php
-%{egwdir}/set_box.php
%{egwdir}/status.php
%{egwdir}/svn-helper.php
%{egwdir}/groupdav.php
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
eGroupWare-cvs mailing list
