Author: ralfbecker
New Revision: 55445
URL: http://svn.stylite.de/viewvc/egroupware?rev=55445&view=rev
use since 14.x unused set_box.php
Removed:
branches/14.2/egroupware/set_box.php
branches/14.2/egroupware/doc/rpm-build/egroupware-epl.spec
— branches/14.2/egroupware/doc/rpm-build/egroupware-epl.spec (original)
+++ branches/14.2/egroupware/doc/rpm-build/egroupware-epl.spec Sun Mar 20 16:25:46 2016
@@ -573,7 +573,6 @@
%{egwdir}/remote.php
%{egwdir}/rpc.php
%{egwdir}/share.php
-%{egwdir}/set_box.php
%{egwdir}/status.php
%{egwdir}/svn-helper.php
%{egwdir}/groupdav.php
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785231&iu=/4140
eGroupWare-cvs mailing list
