Author: ralfbecker
New Revision: 55488
URL: http://svn.stylite.de/viewvc/egroupware?rev=55488&view=rev
fix search in addressbook allways searches for “pressed”, caused by now validated advanced search button having same id as search field, renamed it to “advanced-search”
trunk/addressbook/templates/default/index.xet
— trunk/addressbook/templates/default/index.xet (original)
+++ trunk/addressbook/templates/default/index.xet Tue Mar 22 12:16:11 2016
@@ -118,9 +118,7 @@
@@ -151,9 +149,7 @@
@@ -161,13 +157,9 @@
@@ -177,15 +169,11 @@
<buttononly align="right" statustext="Advanced search" image="advanced-search" background_image="1" id="search" onclick="egw(window).openPopup(egw::link('/index.php','menuaction=addressbook.addressbook_ui.search'),'850','440','_blank','addressbook',null,true); return false;"/>
<menulist>
<menupopup statustext="Select a view" id="org_view" no_lang="1" rows="1" empty_label="All contacts"/>
</menulist>
<buttononly align="right" statustext="Advanced search" image="advanced-search" background_image="1" id="advanced-search" onclick="egw(window).openPopup(egw::link('/index.php','menuaction=addressbook.addressbook_ui.search'),'850','440','_blank','addressbook',null,true); return false;"/>
<select statustext="Select a view" id="org_view" no_lang="1" rows="1" empty_label="All contacts"/>
Click to learn more.
http://pubads.g.doubleclick.net/gampad/clk?id=278785351&iu=/4140
eGroupWare-cvs mailing list
