Author: hnategh
New Revision: 55670
URL: http://svn.stylite.de/viewvc/egroupware?rev=55670&view=rev
Dialog styling W.I.P.:
- Get all buttons fit into footer toolbar for calendar edit
- Fix tabs flicker when switching between tabs
- Fix padding right for td
- Fix general styling for buttons
trunk/calendar/inc/class.calendar_hooks.inc.php
trunk/calendar/templates/default/app.css
trunk/calendar/templates/default/edit.xet
trunk/calendar/templates/mobile/app.css
trunk/calendar/templates/pixelegg/app.less
trunk/pixelegg/css/mobile.css
trunk/pixelegg/css/pixelegg.css
trunk/pixelegg/less/def_buttons.less
trunk/pixelegg/less/etemplate2.less
trunk/pixelegg/less/layout_content_elements.less
trunk/pixelegg/less/layout_dialog.less
trunk/pixelegg/less/layout_table.less
trunk/pixelegg/less/layout_tutorials.css
trunk/pixelegg/mobile/fw_mobile.css
— trunk/calendar/inc/class.calendar_hooks.inc.php (original)
+++ trunk/calendar/inc/class.calendar_hooks.inc.php Thu Apr 7 14:42:27 2016
@@ -31,8 +31,8 @@
‘menuaction’ => ‘calendar.calendar_uiforms.edit’,
‘view_id’ => ‘cal_id’,
'view_popup' => '750x400',
'edit_popup' => '750x400',
'view_popup' => '790x400',
'edit_popup' => '790x400',
'list' => array(
'menuaction' => 'calendar.calendar_uiviews.index',
'view' => 'listview',
@@ -43,7 +43,7 @@
‘add_app’ => ‘link_app’,
‘add_id’ => ‘link_id’,
'add_popup' => '790x400',
'file_access' => 'calendar.calendar_bo.file_access',
'file_access_user' => true, // file_access supports 4th parameter $user
'mime' => array(
@@ -51,7 +51,7 @@
‘mime_data’ => ‘ical_data’,
‘mime_url’ => ‘ical_url’,
@@ -826,7 +826,7 @@
unset($data); // not used, but in function signature for hooks
return true;
- Mail integration hook to import mail message contents into a calendar entry
— trunk/calendar/templates/default/app.css (original)
+++ trunk/calendar/templates/default/app.css Thu Apr 7 14:42:27 2016
@@ -1302,9 +1302,6 @@
display: none;
-#calendar-edit select#calendar-edit_duration {
- width: 133px;
#calendar-edit_account + .chzn-container .chzn-results {
max-height: 195px;
— trunk/calendar/templates/default/edit.xet (original)
+++ trunk/calendar/templates/default/edit.xet Thu Apr 7 14:42:27 2016
@@ -43,15 +43,7 @@
<hbox disabled="@no_add" height="60">
<button id="add" image="add" background_image="1" novalidate="1"/>
<calendar-owner id="participant" allowFreeEntries="true" empty_label="Add new participants or resource" width="40%"/>
<textbox type="integer" label="Quantity" id="quantity" min="1" size="3"/>
<menulist>
<menupopup label="Role" class="selectRole" id="role"/>
</menulist>
</hbox>
<grid width="99%" id="participants" class="egwGridView_grid">
@@ -61,7 +53,16 @@
<row class="th"></row>
<row disabled="@no_add" height="35">
<button align="center" id="add" image="add" background_image="1" novalidate="1"/>
<calendar-owner id="participant" allowFreeEntries="true" span="2" empty_label="Add new participants or resource"/>
<textbox type="integer" align="center" id="quantity" min="1" size="3"/>
<menulist>
<menupopup class="selectRole" id="role"/>
</menulist>
</row>
<row class="th thb">
<description value="Type"/>
<description value="Participants"/>
<description align="center" value="Quantity"/>
@@ -88,10 +89,11 @@
<column/>
<column/>
<column width="50%"/>
@@ -102,28 +104,31 @@
<menulist class="et2_fullWidth">
<menupopup type="select-number" statustext="repeating interval, eg. 2 to repeat every second week" id="recur_interval" options="None,2,31"/>
</menulist>
<label/>
</row>
<row height="12">
<description for="recur_enddate" value="End date"/>
<menupopup type="select-timezone" statustext="Timezone in which recurrences have identical time" id="tzid"/>
</menulist>
<label/>
</row>
<row valign="top">
<description for="recur_data" value="Repeat days"/>
@@ -140,6 +145,7 @@
— trunk/calendar/templates/mobile/app.css (original)
+++ trunk/calendar/templates/mobile/app.css Thu Apr 7 14:42:27 2016
@@ -141,7 +141,7 @@
@package calendar
@version $Id$
-/ $Id: app.css 55640 2016-04-05 21:38:49Z nathangray $ /
+/ $Id: app.css 55652 2016-04-06 16:43:51Z hnategh $ */
/Media print classes/
@media print {
#calendar-view.et2_container,
@@ -1402,9 +1402,6 @@
.calendar_favorite_portlet .calendar_plannerScale a img {
display: none;
- width: 133px;
max-height: 195px;
@@ -1773,26 +1770,6 @@
#calendar-edit .et2_tabheader {
background-color: transparent;
-#calendar-edit input.hasDatepicker,
-#calendar-edit #calendar-edit_start {
- width: 129px;
-#calendar-edit #calendar-edit_whole_day {
- margin: 0 0.8em 0 23px;
-#calendar-edit label.et2_label#calendar-edit_calendar_edit_duration {
- /margin-left: 20px;/
- /margin-right: 49px;/
- width: 133px;
-#calendar-edit button#calendar-edit_freetime {
- height: 16px;
- background-size: 12px auto !important;
- margin-left: 32px;
- padding-top: 0px;
#calendar-edit #calendar-edit_id {
float: right;
@@ -2185,7 +2162,7 @@
-moz-transition-timing-function: linear;
-o-transition-timing-function: linear;
- background-color: #b4b4b4;
- background-color: #e6e6e6;
width: 16px;
height: 16px;
@@ -2433,7 +2410,7 @@
padding-left: 30px;
background-position: 6px center;
background-repeat: no-repeat;
@@ -2490,7 +2467,7 @@
padding-left: 30px;
— trunk/calendar/templates/pixelegg/app.css (original)
+++ trunk/calendar/templates/pixelegg/app.css Thu Apr 7 14:42:27 2016
@@ -1272,9 +1272,6 @@
display: none;
- width: 133px;
max-height: 195px;
@@ -1643,20 +1640,6 @@
- width: 129px;
- width: 133px;
float: right;
@@ -2049,7 +2032,7 @@
width: 16px;
height: 16px;
@@ -2297,7 +2280,7 @@
padding-left: 30px;
@@ -2354,7 +2337,7 @@
padding-left: 30px;
— trunk/calendar/templates/pixelegg/app.less (original)
+++ trunk/calendar/templates/pixelegg/app.less Thu Apr 7 14:42:27 2016
@@ -400,22 +400,6 @@
.et2_tabheader{
- input.hasDatepicker,
#calendar-edit_start{width: 129px;}
- //whole day
#calendar-edit_whole_day{
- //duration
- label.et2_label#calendar-edit_calendar_edit_duration{
/*margin-left: 20px;*/
/*margin-right: 49px;*/
- select#calendar-edit_duration{width: 133px;}
// ID
#calendar-edit_id{float: right;margin-right: 5px;}
— trunk/pixelegg/css/mobile.css (original)
+++ trunk/pixelegg/css/mobile.css Thu Apr 7 14:42:27 2016
@@ -158,7 +158,7 @@
.et2_button_icon {
height: 16px;
@@ -362,7 +362,7 @@
padding: 3px;
-webkit-border-radius: 5px;
-moz-border-radius: 5px;
@@ -960,7 +960,7 @@
textarea,
textarea.description {
- background-color: rgba(255, 221, 115, 0.1);
- background-color: #fafafa;
padding: 0.3em 0 0 0.3em;
border: none;
height: auto;
@@ -1451,7 +1451,7 @@
padding-left: 30px;
@@ -2140,7 +2140,6 @@
padding-left: 30px;
background-size: 20px auto;
@@ -2197,7 +2196,7 @@
padding-left: 30px;
@@ -2236,7 +2235,7 @@
padding-left: 30px;
@@ -2274,7 +2273,7 @@
padding-left: 30px;
@@ -2344,7 +2343,7 @@
padding-left: 30px;
@@ -2409,7 +2408,7 @@
padding-left: 30px;
@@ -2453,7 +2452,7 @@
padding-left: 30px;
@@ -2516,7 +2515,7 @@
padding-left: 30px;
@@ -2745,8 +2744,8 @@
button {
color: #000000;
/font-size:99%;/
- padding-top: 2px;
- padding-bottom: 2px;
- padding-top: 4px;
- padding-bottom: 4px;
padding-right: 0;
border-width: 1px;
border-style: solid;
@@ -3082,6 +3081,8 @@
-moz-user-select: none;
user-select: none;
min-width: 73px;
- border-bottom: 3px solid #e6e6e6;
- margin-bottom: -3px;
.et2_tabflag:hover,
.etemplate_tab > div:hover,
@@ -3506,7 +3507,7 @@
height: 24px;
padding: 0 5px;
@@ -5271,6 +5272,12 @@
.th {
border-bottom: 1px solid #e6e6e6;
+.th.thb {
- border-color: darkgray;
+.th.thb td {
- padding-top: 10px;
.innerContainer {
overflow: hidden;
/padding: 0;/
— trunk/pixelegg/css/pixelegg.css (original)
+++ trunk/pixelegg/css/pixelegg.css Thu Apr 7 14:42:27 2016
@@ -147,7 +147,7 @@
.et2_button_icon {
height: 16px;
@@ -351,7 +351,7 @@
padding: 3px;
@@ -949,7 +949,7 @@
textarea,
border: none;
height: auto;
@@ -1440,7 +1440,7 @@
padding-left: 30px;
@@ -2129,7 +2129,6 @@
padding-left: 30px;
@@ -2186,7 +2185,7 @@
padding-left: 30px;
@@ -2225,7 +2224,7 @@
padding-left: 30px;
@@ -2263,7 +2262,7 @@
padding-left: 30px;
@@ -2333,7 +2332,7 @@
padding-left: 30px;
@@ -2398,7 +2397,7 @@
padding-left: 30px;
@@ -2442,7 +2441,7 @@
padding-left: 30px;
@@ -2505,7 +2504,7 @@
padding-left: 30px;
@@ -2734,8 +2733,8 @@
button {
color: #000000;
/font-size:99%;/
- padding-top: 2px;
- padding-top: 4px;
padding-right: 0;
border-width: 1px;
@@ -3071,6 +3070,8 @@
user-select: none;
min-width: 73px;
.et2_tabflag:hover,
@@ -3495,7 +3496,7 @@
height: 24px;
padding: 0 5px;
@@ -5260,6 +5261,12 @@
.th {
+.th.thb {
+.th.thb td {
.innerContainer {
overflow: hidden;
/padding: 0;/
— trunk/pixelegg/less/def_buttons.less (original)
+++ trunk/pixelegg/less/def_buttons.less Thu Apr 7 14:42:27 2016
@@ -41,7 +41,7 @@
- background-color: @gray_30;
- background-color: @gray_10;
@@ -132,7 +132,7 @@
/background-color: @color_negative_action_hover !important;/
background-image:url(’…/images/delete.png’);
margin-left: 3em;
.Complete_Button_text_icon_before;
/background-color: @color-negative-action !important;/
/color: @gray_0 !important;/
— trunk/pixelegg/less/etemplate2.less (original)
+++ trunk/pixelegg/less/etemplate2.less Thu Apr 7 14:42:27 2016
@@ -921,7 +921,7 @@
textarea,
- background-color: @color_optional;
- .background_color_5_gray;
border: none;
height: auto;
— trunk/pixelegg/less/layout_content_elements.less (original)
+++ trunk/pixelegg/less/layout_content_elements.less Thu Apr 7 14:42:27 2016
@@ -24,22 +24,21 @@
body,
textarea {
#egw_fw_basecontainer {
- position: fixed;
- width: 100%;
- height: 100%;
- padding: 0px;
- margin: 0px;
- .basefontfamily;
- .background_color_0_gray ;
- position: fixed;
- width: 100%;
- height: 100%;
- padding: 0px;
- margin: 0px;
- .basefontfamily;
@@ -53,14 +52,13 @@
select {
- margin: 0;
- .rounded (3px);
- &:hover{.Complete_Button_select_hover;}
- &:focus{.Complete_Button_select_focus;}
- &.after{}
- margin: 0;
- .rounded (3px);
- &.after{}
:hover {.transition (0.2s, ease-out);}
@@ -71,76 +69,64 @@
li {}
// Headlines h1 usw in layout_headlines.less
// select
div.selectbox-wrapper {
select {
select,input,button
- .color_100_gray;
- /font-size:99%;/
- padding-top: 2px;
- .color_100_gray;
- /font-size:99%;/
- padding-top: 4px;
padding-right: 0;
- border-width: 1px;
- border-style: solid;
- border-color: @gray_10;
// Links
- cursor:pointer;
- color: @link_color;
- text-decoration: none;
- cursor:pointer;
- cursor:pointer;
- color:@link_color_active;
- text-decoration: underline;
- cursor:pointer;
.divLoginboxHeader,
.divSideboxHeader,
@@ -149,89 +135,79 @@
a.textSidebox,
.textSidebox,#fmStatusBar
.prefSection
- font-weight:bold;
- font-size:145%;
- line-height:40px;
- font-weight:bold;
- font-size:145%;
- line-height:40px;
#divAppboxHeader
- line-height:28px;
- font-size:125%;
- font-weight:bold;
- color:#666666;
- line-height:28px;
- font-size:125%;
- font-weight:bold;
- color:#666666;
#divGenTime,#divPoweredBy
- font-size: 80%;
- color: #ff0000;
- font-size: 80%;
- color: #ff0000;
#divPoweredBy
#sideboxdragarea {
- z-index:100;
- position:absolute;
- left:0px;
- top:105px;
- z-index:100;
- left:0px;
- top:105px;
#menu2handle {
#menu1close {
- position: absolute;
- right: 7px;
- top: 7px;
- right: 7px;
- top: 7px;
hr.clearer {
- clear: both;
- height: 20px;
- width: 100%;
- background-color: @egw_color_1_a;
- .rounded (3px);
- border: 1px solid @gray_100;
- clear: both;
- height: 20px;
- width: 100%;
- .rounded (3px);
-table.table_passord_change{
- margin: 1em;
- tr {height: 50px;}
- td:first-child{ padding-right: 4em;}
+table.table_passord_change {
- margin: 1em;
/////* Targetting Webkit browsers only. FF will show the dropdown arrow with so much padding. */
@media screen and (-webkit-min-device-pixel-ratio:0) {
select {
padding-right: 20px !important;
-webkit-appearance:none;
margin:0;
background: #ffffff url(../images/selectarrowdown.png) no-repeat center right;
background-size: 16px auto;
- select {
margin:0;
— trunk/pixelegg/less/layout_dialog.less (original)
+++ trunk/pixelegg/less/layout_dialog.less Thu Apr 7 14:42:27 2016
@@ -253,6 +253,8 @@
user-select: none;
min-width: 73px;
- border-bottom:3px solid @gray_10;
- margin-bottom:-3px;
&:hover {
.background_color_egw_lighter;
border:none;
— trunk/pixelegg/less/layout_table.less (original)
+++ trunk/pixelegg/less/layout_table.less Thu Apr 7 14:42:27 2016
@@ -33,7 +33,10 @@
.th {
border-bottom: 1px solid @gray_10;
+.th.thb {
- border-color:darkgray;
- td {padding-top:10px;}
.innerContainer{
overflow: hidden;
/padding: 0;/
— trunk/pixelegg/less/layout_tutorials.css (original)
+++ trunk/pixelegg/less/layout_tutorials.css Thu Apr 7 14:42:27 2016
@@ -80,6 +80,10 @@
[id^=“egw_tutorial_”][id$=“sidebox_list”] {
overflow-x: hidden;
overflow-y: auto;
- max-height: 200px;
+#list_grid_wrapper {
#home-tutorial_list {
float: left;
@@ -113,8 +117,8 @@
div.tutorial_iframe_wrapper {
position: absolute;
- left: 225px;
- right: 12px;
height: 90%;
span.egw_tutorial_title {
— trunk/pixelegg/mobile/fw_mobile.css (original)
+++ trunk/pixelegg/mobile/fw_mobile.css Thu Apr 7 14:42:27 2016
@@ -169,7 +169,7 @@
.et2_button_icon {
height: 16px;
@@ -373,7 +373,7 @@
padding: 3px;
@@ -971,7 +971,7 @@
textarea,
border: none;
height: auto;
@@ -1462,7 +1462,7 @@
padding-left: 30px;
@@ -2151,7 +2151,6 @@
padding-left: 30px;
@@ -2208,7 +2207,7 @@
padding-left: 30px;
@@ -2247,7 +2246,7 @@
padding-left: 30px;
@@ -2285,7 +2284,7 @@
padding-left: 30px;
@@ -2355,7 +2354,7 @@
padding-left: 30px;
@@ -2420,7 +2419,7 @@
padding-left: 30px;
@@ -2464,7 +2463,7 @@
padding-left: 30px;
@@ -2527,7 +2526,7 @@
padding-left: 30px;
@@ -2756,8 +2755,8 @@
button {
color: #000000;
/font-size:99%;/
- padding-top: 2px;
- padding-top: 4px;
padding-right: 0;
border-width: 1px;
@@ -2911,7 +2910,7 @@
@version $Id: layout_dialog.less 55652 2016-04-06 16:43:51Z hnategh $
@version $Id: layout_dialog.less 55667 2016-04-07 09:13:26Z hnategh $
/*body {
background-color: @gray_0;
@@ -3093,6 +3092,8 @@
user-select: none;
min-width: 73px;
.et2_tabflag:hover,
@@ -3517,7 +3518,7 @@
height: 24px;
padding: 0 5px;
@@ -5271,7 +5272,7 @@
@version $Id: layout_table.less 55652 2016-04-06 16:43:51Z hnategh $
@version $Id: layout_table.less 55667 2016-04-07 09:13:26Z hnategh $
- et2
@@ -5281,6 +5282,12 @@
/* TABLE STYLE */
.th {
+.th.thb {
+.th.thb td {
.innerContainer {
overflow: hidden;
eGroupWare-cvs mailing list
