Author: hnategh
New Revision: 55698
URL: http://svn.stylite.de/viewvc/egroupware?rev=55698&view=rev
Styling dialogs W.I.P.:
- Fix alignments in infolog edit dialog
trunk/egroupware/api/templates/default/etemplate2.css
trunk/infolog/templates/default/app.css
trunk/infolog/templates/default/edit.xet
trunk/infolog/templates/pixelegg/app.css
— trunk/egroupware/api/templates/default/etemplate2.css (original)
+++ trunk/egroupware/api/templates/default/etemplate2.css Mon Apr 11 16:08:01 2016
@@ -693,7 +693,6 @@
margin-right: 10px;
div.et2_link_entry input.ui-autocomplete-input {
- width: 40%;
padding-bottom: 1px;
.et2_link_entry.no_app input.ui-autocomplete-input {
@@ -723,6 +722,7 @@
.et2_link_to.et2_toolbar div.et2_link_entry input.ui-autocomplete-input {
height:22px;
border-radius: 3px;
- width: 40%;
.et2_link_to.et2_toolbar .div_link {width:85%;vertical-align: top;}
.et2_link_to.et2_toolbar .div_link select {margin-right: 4px;}
— trunk/infolog/templates/default/app.css (original)
+++ trunk/infolog/templates/default/app.css Mon Apr 11 16:08:01 2016
@@ -31,13 +31,9 @@
#info_contact input {width: 134px;}
#info_subject {width: 100%;}
-/* date-duration styling in project manager tab */
-.infolog_date_duration:first-child input.et2_date_duration{
- float: left;
- width:137px;
.infolog_date_duration select.et2_date_duration {
- width: 69%;
margin-left: 2px;
@@ -47,10 +43,6 @@
background-position: 6px -2px;
-/Project Name/
-#infolog-edit_infolog-edit-project .et2_link_entry.no_app input.ui-autocomplete-input {
- width: 291px;
/get tags inside description in listview with no breakline/
.et2_nextmatch .egwGridView_grid tr td div.et2_vbox .infoDes a{
display: inline-table;
@@ -103,3 +95,4 @@
#infolog-index select#infolog-index_filter {
width: 150px;
+#infolog_edit_info_responsible_chzn { width:99% !important;}
— trunk/infolog/templates/default/edit.xet (original)
+++ trunk/infolog/templates/default/edit.xet Mon Apr 11 16:08:01 2016
@@ -30,18 +30,16 @@
<link-entry span="2" id="pm_id" only_app='projectmanager' onchange="app.infolog.submit_if_not_empty" blur="None" class="infolog_projectName"/>
<description/>
</row>
<row class="row">
<description value="Price"/>
@@ -51,17 +49,17 @@
@@ -89,7 +87,7 @@
@@ -101,33 +99,25 @@
<column width="78"/>
<column width="300"/>
<menulist>
<menupopup type="select-account" statustext="select a responsible user: a person you want to delegate this task" id="info_responsible" multiple="true" no_lang="1" tags="true" class="et2_fullWidth" account_type="both" empty_label="User or group" onchange="app.infolog.onchangeResponsible"/>
</menulist>
</row>
<row class="row" disabled="1">
<description value="Confirm" for="info_confirm"/>
<menulist class="et2_fullWidth">
<menupopup statustext="do you want a confirmation of the responsible on: accepting, finishing the task or both" id="info_confirm"/>
</menulist>
<column/>
@@ -177,23 +167,20 @@
<column width="88"/>
<column width="302"/>
<column width="122"/>
<column width="30"/>
<column width="12"/>
</columns>
<rows>
<row class="dialogHeader">
<description value="Title" for="info_subject"/>
<textbox statustext="a short subject for the entry" id="info_subject" class="et2_fullWidth et2_required" maxlength="255" span="5" tabindex="1"/>
@@ -202,8 +189,7 @@
@@ -211,10 +197,9 @@
@@ -248,10 +233,9 @@
<menupopup type="select-percent" statustext="Percent completed" id="info_percent" onchange="app.infolog.status_changed(this.id, form::name('info_status'), form::name('info_percent'), form::name('info_datecompleted'))"/>
</menulist>
@@ -263,16 +247,15 @@
— trunk/infolog/templates/pixelegg/app.css (original)
+++ trunk/infolog/templates/pixelegg/app.css Mon Apr 11 16:08:01 2016
@@ -102,23 +102,14 @@
#info_subject {
width: 100%;
-.infolog_date_duration:first-child input.et2_date_duration {
- float: left;
- width: 137px;
- width: 52%;
- width: 69%;
margin-left: 2px;
tr.infolog_rowHasParent > td:first-child {
background-image: url(…/…/…/phpgwapi/templates/default/images/egw_action/arrow_up.png);
background-repeat: no-repeat;
-/Project Name/
- width: 99% !important;
reduces your MTTR. Get your free trial! http://pubads.g.doubleclick.net/
gampad/clk?id=1444514301&iu=/ca-pub-7940484522588532
eGroupWare-cvs mailing list
